Question about Kenmore Dryers
Kenmore Gas Dryer
My dryer won't heat up at all. I checked out all of the trouble shooting things in the manual but that's not it. I think that there is a fuse on the inside, I am going to check that but i thought I would try here too. I did run it with the door open and my hand inside and it never heated up at all.
  • 6amscripps Jul 10, 2008
    I am going to go buy the fuse right now! Thanks a lot! The only problem is that on my model where there would be continuity like on an old car fuse it is encased in like black plastic so i can't tell if it is bad. I will replace it nonetheless and test it.
  • 6amscripps Jul 11, 2008
    I bought it, installed it, and it worked. Apparently I didn't have to take apart the entire dryer like I did but I vaccumed the whole thing and found 3 bucks in change.
    Novelist:
  • 177 Answers
You probably burnt out the thermal fuse.
This is located in the back of the dryer. First unplug the dryer then remove the back panel. Remember once you remove an part of the dryer you have to watch for sharp edges be careful!
Now on the back of the blower housing is a white thermal fuse, usually two wires, check to see if it is good, like a fuse it should have continuity. If it is open you have the problem. you can buy these anywhere on line, I would start with Sears.com.
While you have your dryer open vacuum it out and clean the venting this is probably when the fuse opened, its there to protect you and the dryer.
Ask more questions if you have them.
T
Posted on Jul 10, 2008
Hello our gas dryer won't heat it's getting gas as far as we know but still wont heat up, what do you think it could be?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 14, 2011 | Kenmore 63942 Dryer
We have a Kenmore 80 series dryer. When we use it their is no heat and it takes more than 3 cycles to dry the clothes. We can not find the manual to trouble shoot.HELP
heatman101
Jul 02, 2011 | Kenmore Washing Machines
I have a maytag electric dryer and it will not heat and dry clothes. The type number is DWSR-ELE-2406026-CV54. Mod # MED5800TWO SER - MV4920498 The owners manual does not have any trouble shooting...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 21, 2010 | Maytag Dryers
Kenmore dryer not heating up
heatman101
Nov 15, 2010 | Electrolux AEQ8700F Electric Dryer
My maytag dryer runs but no heat is coming out. What trouble trouble shooting problems can it be?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 19, 2010 | Dryers
Kenmore Dryer Model 417.92142101 does not heat up. It looks like the element is getting hot but the gas does not light
Hi, Hey, that thing can get red hot and still not be working right... If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 20, 2010 | Kenmore Dryers
My Kenmore elite electric dryer will not heat. I
Hi
Thanks for using FixYa. No Heat issue in an electric dryer is usually caused due to three things mainly: Thermal Fuse, Wiring Harness and/or Heating Element. Start with checking the Thermal Fuse which is mounted inside the back cover panel to the exhaust duct and is mounted in white plastic housing. If that’s fine then the Heating Element should be checked. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 03, 2010 | Kenmore Elite HE4 Electric Dryer
Dryer heats up then pilot lght turns off, dryer
Hi, If you have a gas dryer2_bing.gif.
heatman101
Oct 20, 2009 | Kenmore 63942 Dryer
Kenmore elite dryer no heat
You may want to check if the heating element needs replacing. Most Dryers have 2 heating elements that are found by taking the back off, some of the newer dryers have 3.
Jun 08, 2009 | Kenmore Dryers
Dryer not getting hot
if you not technicail dont try,,,unit needs to be plug in for some tests...warning,,to start im thinking unit runs but dont heat..chech your operating thermastat first ,,next check yiur hi limit thermestat..they should be closed,,if good check your ignitor there should be 110 present..
Dec 26, 2008 | Kenmore 63942 Dryer
Dryers Logo
55 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
