Question about Brother IntelliFAX 4100 Laser Fax
PLS Open cover "ONLINE'
I have brother Intellifax 4100
with this error
PLS OPEN COVER ONLINE
  • walkerrivas Jul 10, 2008
    I need help with this
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Brother Master
  • 1,362 Answers
Intellifax 4100e ..not receieve fax
Look at the front door that you open when you change the toner/drum. You will see that it has not closed properly at one end. Give it a gentle whack and the error should go. Very common problem as the catches can be stiff.
Mar 11, 2014 | Brother Intellifax 4100 Business Class...
RESET DRUM LIGHT ON BROTHER INTELLIFAX 4100
1. Open the front cover. 2. Press the "CLR" buttone. 3. Press 1 to reset.
Done.
Mar 25, 2010 | Brother IntelliFAX 4100 Laser Fax
Resetting after replacing Drum
should be in the box with the drum. if not open front cover touch clear key touch number 1 key
Oct 01, 2009 | Brother IntelliFAX 4100 Laser Fax
Open cover show in fax - means what is the problem
this is telling you that the fax has encountered an error if you open the scanner cover this is where you put the doc in to send and close then open the front covers check that the cartridge is set properly and lastly check the paper path to see if there is a jam.. hope this help if you get an errror message describing fault let me know may be able to help more
Jun 06, 2009 | Brother IntelliFAX 4100 Laser Fax
Intellifax 4100 e series- we replaced the drum
clear the drum counter.
open the front cover leave it open and then press clear button hit number 1 for yes and that's it.you can close the front cover. :-)
any other questions please let me know.
Mar 03, 2009 | Brother IntelliFAX 4100 Laser Fax
Brother Intellifax 2800
Pls open cover = Please open cover. Probaly has a jam - Open the cover remove the drum/toner unit and check for jammed piece of paper under of in the drum unit.
Jan 24, 2008 | Brother IntelliFAX 2800 Laser Fax
Brother intellifax 4100
open front cover, press "clear" and 1, that will clear the change drum soon error
Jan 14, 2008 | Brother IntelliFax-2820 Laser Fax
Brother intellifax 4100e
Hi, the error code refers to the heater thermistor short circuited or heater thermistor disconnected or broke when the power was turned on, front cover is open or closed or when the machine exits from sleep mode.I hope this help!!
Dec 04, 2007 | Brother IntelliFAX 4100 Laser Fax
"Offline"
which cover are you opening? You must pull open the bottom cover not the one under the keyboard. It's the bottom front cover not the top front cover.
Sep 26, 2007 | Brother IntelliFAX 4100 Laser Fax
Brother IntelliFAX 4100 Laser Fax Logo
487 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
