My keyboard that i purchased 7/09/08 has a defective prong at the connector end
    Novelist:
    Scholar:
  • 96 Answers
There realy is nothing you can do with that short of buying a cable end and reterminating it yourself. The keyboard is still under store warranty. Turn it back in and get a replacement.
Posted on Jul 10, 2008
I washed an dried my blanket an now when I plug it in it just blinks. An now one of my prongs is shorter than the other ones?
the prong is defective and one end has sunk into the plastic shield. replace it, it is a hazzard
Dec 30, 2016 | Washing Machines
How can i tell if the hi limit thermostat in my maytag wall oven is bad
test with a multi meter on each end of the wire prong connector, place each end of ur meter prong on both 1 and 2 of the connectors, and test for continuity ohms or a close circuit. have ur meter on a low ohms setting as the level of ohms is low. if it shows an open circuit or no continuity, its defective. Infinity is the meter not showing anything like a number 1 and not moving?
Apr 26, 2015 | Maytag MEW6530DDW 30" Electric Single Wall...
How do you know if your invertor controlled compressor is bad?
To check ur compressor with multi meter:
Disconnect and remove the relay and capacitor from compressor , somes located next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes to ur srtart winding, 1 goes to ur run winding and the center goes to ur ground.
Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms.
Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short in ur compressor. It should show infinity
Oct 04, 2014 | Samsung RFG297AARS Bottom Freezer French...
Keyboardbroken..must hold keys down ,makes clickynoise,after 2nd click,letterappears,or functionoccurs
I recommended that you connect either a known good keyboard or a new one to your computer and see if that fixes the problem. Keyboards are not at all expensive and they are not worth fixing.
If the problem continues after you replace the keyboard, the keyboard controller on the motherboard is bad and you are faced with replacing the motherboard.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please return to the FixYa website and rate my response to your question.
Best regards,
Yavacotech
Jan 05, 2011 | E-Machines eMachines Desktop PC
Broken prong iside computer for mouse now mouse dont work how do i fix it thank you
If the prong is broken inside the computer then the best thing to do is to get a usb mouse or a wireless one. I ran into the same problem with my keyboard and purchased a usb keyboard and it works fine. Good luck!
Oct 25, 2010 | Computers & Internet
Not lighting up i do not think it is working
start your computer up with another keyboard attached to the computer.
Look at the cable of the keyboard, to determine which connenction it is. If the connector is round, then you need a PS2 keyboard. If the connector is a rectangle, you need a USB keyboard.
Connect the new keyboard to the computer and start up.
If the keyboard is working, then the old keyboard is defect.
If the keyboard is not working, then probably the connector or the mainboard of the computer is defect.
Sep 17, 2010 | Dell 0Y3740 Keyboard
Can't hook up mouse and keyboard
Okay, setting up the mouse and keyboard is very simple. The mouse should have a green end, and the keyboard has a purple end. They fit into the corresponding places in the back of the computer. Also both the mouse and the keyboard have flat sides. Try attaching them in the four different directions (e.g; up, down left, right). If that still doesn't work have them look at the wires to confirm that the wires are not bent, that could explain the problem, because the twisting could have caused bends in the PS2 Connector.
Thanks,
Ryan Frame
Creative Energy Associates Technical Center
Jul 28, 2009 | Computers & Internet
Jenn air bake element problem Model SVB46800w
At the family house we had an old counter top Jenn-air appliance and the connectors for the elements always burned until i put white sillicon grease on the contacts.This grease is intended to transfer the heat on transistors. Never had problem again.
Jul 29, 2008 | Jenn-Air Ovens
Keyboard to Laptop connectors
go to Amazon.com, and look up ps/2 (which is the official name for the connector type normal keyboards have) to usb adapter, and you should find a little green thing that adapts your keyboard to usb. Make sure that the usb is a male end, and the ps/2 is a female end, or you've got the wrong one.
However, before you do that, I want to let you know that I just did the same thing, and I cannot get my Gateway keyboard to work on my HP laptop through usb. I have no idea why, and I am currently trying to find a solution. So I wouldn't suggest buying it until you know how to fix it. If you figure it out let me know.
Dec 04, 2007 | Gateway 2520915 Keyboard
Computers & Internet Logo
David Payne
David Payne
