Question about Kodak EasyShare M1033 - black Digital Camera
Kodak m883 turns on and them makes weird sound and the zoom goes out then in and it shuts off
  • 6 more comments
  • edwardc7 Jul 16, 2008
    I have the same problem! Lens comes out. There is a beep. Lens tries to focus. Lens goes back in and another beep.
  • eestti Aug 09, 2008
    have the same problem... camera didnt fall down or anything, just happened suddenly when i tried to take a pic...and now when i turn it on it beeps, tries to focus and turns off......
  • ihvvet2 Aug 16, 2008
    We have the same problem also. Anyone have a fix yet?
  • ptissem Sep 24, 2008
    i have the same problem
  • Gillkaulitz Nov 26, 2008
    ****. Mine does the exact same thing, and I can't figure out how to fix it. I don't want to tell me dad about it.. cause, well, just yesterday I managed to accidently put my cell phone in the washer, and he'll think I did something to break the camera too. ):
  • brad bennet
    brad bennet Dec 03, 2008
    lens zooms in and out then camera shuts off?????? help!!!!
  • little_rodeo Mar 20, 2009
    This is so frustrating! I am having the same problem and I dont even know why it started doing this. I went to the Kodak website and it will be a minimum of at least $80 to repair it. Thats not including shipping and handling either. Any solutions yet?? Its almost easier to just go out and buy a new camera at this point.
  • Anonymous Apr 20, 2009
    this stinks! mine is doing this too. :(
Beat the camera with a hammer and buy a new one because it cost 98 dollars to have it fixed
Posted on Dec 03, 2008
My Kodak Easyshare M883 camera wont stay on. I turn it on and it makes a buzzing sound then turns off. It cant be because of the battery because I have full battery. So what is the problem and how can I...
The camera is shutting off because on start up there is an error on the main controller . Remove the battery and if possibel check if the current capacity of the battery is good enough. Most often the voltage will be shown but the current (Ah) will be less. So use a load to check if possible or try on a similar camera just to make sure. Remove the memory card , check for virus , format and reset.
Try the battery back, if fault recurrs then you will have to open to check if the electronic board is not getting the correct data on switch on but has some errors -- possible load factors in circuit- to switch off.
Might have to disconnect flash unit to check, if not the lens or shutter drive could be faulty.
hope this helps.
Aug 21, 2010 | Kodak EasyShare M883 Digital Camera
Today I turned on my camera to take a picture and while it was turning on it made a weird noise, zoomed in and out, and then turned off. Why does it do this?
Are you using Li-ion batteries as recommended by Kodak?
Also, are they charged up sufficiently?
Many people try to use Alkaline or even NiMH batteries without success in Kodak digital cameras.
I would suggest using charged up Li-ion batteries.
Jul 10, 2010 | Kodak EasyShare M883 Digital Camera
HELP!! I am having a real Kodak moment. I have a Kodak M883, The wall charger says the battery is full but when you put the battery in the camera the camera turns on, the lense extends, battery reads...
Hello :
It seems that the battery is dead or the battery base is rusty or there's isolation stuff on it . Try to clean the base first . If that didn't help , then I recommend you to replace the battery .
good luck .
please don't forget to rate !
Apr 04, 2010 | Kodak EasyShare M883 Digital Camera
The camera turns on, zooms then goes off
Looks like your zoom button is stuck. Try pressing both the W and T sides several times keeping the camera off. If this doesn't work, you'll have to go for a service center.
Feb 15, 2010 | Kodak EasyShare M883 Digital Camera
My m883 turns on for 1 second then shuts off??
Make sure that you are installing a fresh/ full charge battery
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 18, 2009 | Kodak EasyShare M883 Digital Camera
When i turn on my camera the lens goes out, makes a noise, zooms in, makes another noise, then goes off. the number of the camera is kodak easy share m883
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Contact KODAK:
Nov 02, 2009 | Kodak EasyShare V603 Digital Camera
My camera will turn on and shortly turn itself off
Fixing your problem could be as simple as cleaning the battery contacts in the camera, or the solution could be a lot more complex and expensive. Here's a link to the Kodak Help Center - it provides a simple Q&A format to diagnose the problem and propose a solution.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Jul 29, 2009 | Kodak EasyShare M883 Digital Camera
Lens only goes thru zoom cycle then shuts off
Your fix could be as simple as cleaning the camera's battery contacts, or it could be something more serious and expensive. Before you pay for expensive repairs that you may or may not need, check the Kodak Help Center by clicking on the link below. It uses a simple Q&A format to diagnose problems and propose solutions.
Jul 15, 2009 | Kodak EasyShare M883 Digital Camera
Kodak EasyShare M1033 - black Digital Camera Logo
396 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
