Question about Sony Handycam CCD-TRV608 Camcorder
Old tapes won't play in different Handycam
My Sony TRV740 Handycam died and I bought a cheap TRV608 on ebay so I could play my old Hi8 tapes into my computer and get them onto DVDs. But the TRV608 won't play any of the older tapes, just fuzz and some noise. However, it does record video and sound nicely using those same tapes, so the record and playback functions work fine.
I found a similar question on another website with the following response. Does this sound like my problem? ----
"These cameras had a common problem with the tape guides. The guides immediately before and after the video head have a tiny allen key set screw near the bottom which loosens, then the guide moves out of alignment one way when the tape is moving forward, and the other way when it's moving in reverse.
Aligning the guides is a complex process. It involves playing back an alignment tape while connecting an oscilloscope to a test point on the circuit board. The point is in a different place on each camera.
The problem is that if any tapes were recorded while the machine was OUT of alignment, they will no longer play when the machine IS properly aligned"
Me again-- If my tapes were recorded on my now-dead Handycam with the tape guides misaligned, am I stuck?
Is there anyway I can get them played
    Problem Solver:
  • 19 Answers
Were your tapes recorded in extended play? Sometimes that will make it impossible for a different tape deck to play it back correctly. The tolerences on Hi-8 are very small so it is possible that a tiny alignment difference will make it impossible to play back a pre-recorded tape. Try fast forwording and rewinding the tape and try it again. Also try playing it from different parts of the tape. Go to the middle of the tape and try it there.
Posted on Dec 30, 2008
    New Friend:
I found if you hit the camera (tap it lightly to moderately hard) it shakes the head or tape into alignment and the head then continues to stay into alignment generally. I read this works for older models of sony cams but decided to give it a try with this newer model and it appears to have worked.
Posted on Nov 10, 2014
How to play tapes not recorded by Sony Handycam DCR-TRV130 Digital-8 Digital Camcorder
It is my understanding that the camera won't playback those formats, timecode or not. There are VCR type units for the HI8 and other formats. They should be cheap on eBay now...
Nov 18, 2012 | Sony Handycam DCR-TRV130 Digital Camcorder
Sony ccd trv43 doesn't play hi8 after placing an old video 8 tape
Try to clean video head with cleaning cassette, if same position than video head need to be change
Mar 28, 2010 | Sony Handycam CCD-TRV43 Camcorder
Sony handycam video cassette
To the best of my knowledge 8mm VTR's have not been available for some time now. On the other hand there are plenty of Hi8 cameras and players available after market. eBay is a great source. Keep in mind that Hi8 cameras and decks will also play standard 8mm video tapes.
There are also many video tape transfer services that will transfer your 8mm tapes to DVD or other formats of your choice. Just Google "videotape transfer service"
Aug 28, 2009 | Sony Hi8 CCD-TRV138 Camcorder
Can't see how to play Hi8 tapes on this Sony dcr-trv340e pal camera
It's a Digital Hi8. Your tapes are Analog.
But it should play Analog also.
In the menu play with "PB Mode" settings.
Apr 14, 2009 | Cameras
How do I transfer 8mm & Hi8 tapes to DVD using my computer?
just go to this link:
download the usb driver for your camcorder. install. Set power switch to Camera or VCR. Select USB Stream to ON in the menu settings. then connect camcorder to pc.
Mar 31, 2009 | Sony Handycam DCR-TRV740 Digital Camcorder
Problems with playing cassettes recorded on a hi8 camera
DCR TRV140E is a Digital8 camera
CCD TRV87E is a Hi8 camera,
(Hi8 is an analog format)
the tapes are the same size, wont help, the recording systems are not compatible
send them to a lab service ?maybe if there are only a few
or ebay a Hi8 camera and transcode them yourself
its not a solution, at least it clarifies the problem
Oct 23, 2008 | Sony Handycam DCR-TRV140E Digital...
Hi8 Playback Problem
Clean the tape heads and see if that makes a difference.  If that doesn't work, it could be the tape motor is going out.  Thats typical behavior when that happens.
Oct 07, 2008 | Sony Handycam DCR-TRV350 Digital Camcorder
Problems with playback of HI8 tapes...
What's happening is that the tape in the cassette is being chewed on one side by the camera's tape transporting mechanism during playback, hence the distorted image and sound. The mechanism might be damaged (misalignment) or just dirty. Try not to play other tapes on this unit because they will become permanently damaged. The best way is to find another camcorder (if cleaning does not help). Note that some old cassettes of long recording time will exhibit this behavior more often because of thinner tape used.
Dec 06, 2007 | Video Cameras
Hi8 playback problem
your guides have come loose , probably - the digital sound will be next to go because the bottom edge of your tapes are being folded - open the cassette tape lid by pressing the small pin near one hinge and gently lifting the door - if there are any creases ? get the guides aligned ! to protect your library ; ( if there are no creases , try a sony d8 cleaning tape - once ! before getting a repair quote ) ;
Jul 27, 2007 | Sony Handycam DCR-TRV460 Digital Camcorder
Not reading Hi8 tapes
Fidus, I am not sure where you are located but the camcorder you're trying to use now is a PAL version of Sony's 8mm camcorder. If the tapes you recorded earlier were recorded in D8 (digital 8) or 8mm/Hi8 format NTSC, they will not play correctly in this unit. The NTSC and PAL formats are different and not compatible. Hope this helps you. Joe Weibel
Feb 28, 2007 | Sony CCD-TRV228E Camcorder
Sony Handycam CCD-TRV608 Camcorder Logo
530 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
