Question about Mitsubishi WS-65513 65" Rear Projection HDTV
Mitsubishi WS-65513 Flashing green light
Please send me the fix for the DM board. I unplugged the unit for 2 days and then plugged it back in. The green light flashed for several hours then went off. I was able to turn on the tv but after turning it off later on it would not come back on and the green light started flashing again. I tried the same technique but it didn;t work. I am a certified Critical Soldering Tech so I should be able to handle any board repair.
  • 12 more comments
  • Charles Knight Jul 18, 2008
    thanks for the help. It worked fine!!!!
  • jimbizzman2 Aug 01, 2008
    JUST WANT TO THANK BIG IRISH ON YOUR BEST SOLUTION FOR
    MITSUBISHI WS 65513 FALASHING GREEN LIGHT YOU RESPONDED
    ON JULY 19 08 i USED YOUR INPUT TO REPAIR MY SET AND IT IS A WS 65613 WORKING GREAT TOTAL COST 2,40 CENTS .THIS WAS NOT AND EASY TASK IT TOOK ME ABOUT 6 HOURS TO FIX ABOUT 1 HOUR TO FIND THE RIGHT CAPS.BUT I AM JUST AND INDUSTRAIL ELECTRICIAN WITH 25 YEARS EX .SO THANKS AGAIN I COULD NOT HAVE FIX THIS WITH OUT YOUR POST JIMBIZZMAN2@COX.NET
  • Anonymous Aug 02, 2008
    green light is flashing
  • pedroza1977 Aug 16, 2008
    Hi, please send me the fix for the DM board and how to revome it along with the capacitors. I unplugged the unit for 2 days and then plugged it back in. The green light flashed for several hours then went off. Thanks a bunch
  • Anonymous Aug 18, 2008
    ws-65513
    ws-65513
  • shinsatob Sep 29, 2008
    I am having the same problem, I need help how do I fix this please someone tell me.
    e-mail me at shinsatob@rush-enterprises.com
  • Thomas Bonfiglio
    Thomas Bonfiglio Sep 29, 2008
    My problem is related to model WS-55511 manufactured in Oct. 2003. First issue was with the convergence module that was repaired at a hefty sum.
    Current problem is that the set won't turn on. When the reset button was engaged the green light flashed as normal and after several minutes of its self test went out. The set was then powered on and in an instant went off and the green light began flashing again.
    Went as far as to unplug the unit for several hours with the same result when power was put back to the unit. Even went as far as leaving it unplugged for a month.
    I have seen posts on the net that indicate that this particular set has been plagued with problems and when Mitsubishi Customer Service was contacted they didn't seem to care.
    This set replaced a very reliable Mitsubishi Rear Screen that gave many years of service without a problem. I don't want to discard this set but the estimated price for the repairman to come out and pop in another board is a bit on the rediculous side.
    If you have any answers on a reasonable fix please let me know.
  • bbuchmiller Oct 17, 2008
    I have model ws- 65713 is it the same as the 65513. I've read several post and have taken my tv apart. The fuses look ok but will have someone test the board any way. please e-mail me if there are any other solutions. bbuchmiller@pacbell.net
  • motojunky29 Nov 26, 2008
    The TV was working fine, then one day I went to turn it on and the green light was flashing and would not turn on... I unplugged it for about 10 minutes and then it worked... I turned it off later then the next day tried to turn it on and the green light was flashing again... I tried the samething again, but this time no luck, even after leaving it off for many hours, still the same results... Please let me know how I can do a home repair on it?
    Thanks,
    Mark
  • bigdior Nov 29, 2008
    Please advise what the fix to this problem may be. I have model WS-65513, have had this problem in the past. Unplugging for many hours worked in the past but this time it's been unplugged for 2 days and not powing on just blinking light....
    Please e-mail me the fix at bigdior@yahoo.com. I would certainly appreciate it. Happy Holiday's...
  • sramse05 Dec 06, 2008
    Guess I'm in the same boat, if you could send the fix instructions to scott_ramsey@hotmail.com I would greatly appreciate it.
  • HANDS0METim Dec 13, 2008
    Hello, Im having the same problem. Could someone please send me the info at Tim.Keenan@insightmediapro.com
  • Anonymous Dec 18, 2008
    Apparently all Mitsubishi Wide Screen (WS model prefix) have an inherent problem. In my case I own a WS55511.
    About a year ago the convergence circuit went bad and cost me $400.00 to fix. Authorized Mitsubishi Repair Service, Ross Electronics in Cherry Hill, NJ, stated that this was common as the units were not engineered to provide adequate ventillation. They said they were replacing a board and had to special order it. Repair Ticket said a part was soldered on the board the tech took with him....Anyway that is the start. Now to the point of current problem.
    Turned the set on one morning (set was working fine the night before) Picture appeared for a brief second, set shut down and the green light was flashing. After the Green Light ceased flashing I attempted to power the set up a second time. Again with same result.
    I referenced the owners manual and the only help it offered was to reset the system by using a paper clip or other small object to depress the reset button on the front of the set. Again the Green Light was flashing and the set wouldn't power up.
    Removed the power cord and left it out for an hour, 2 hours, day, week etc. No luck.
    As the set was purchased in 2003 I was quite concerned about the problems and also was reflecting on the repairmans comment that Mitsubishi sets are not reliable since their parts are substandard.
    I have placed several calls to Mitsubishi in an effort to find out (given all the posts on the internet) if there was ever a recall or technical bulletin released. Won't go into details but you can pretty well fill in the blanks.
    They kept reminding me that the set was out of warranty after I had told them, up front, that I was aware of this. Obviously all sets in the class, regardless of screen size have this and other problems.
    I have 99.00 no name TV's that have been performing flawlessly.
    What gives?
    Tom
    Problem Solver:
  • 6 Answers
Http://www.jyerdon.com/tv/
Just did mine last week and working like a champ. e-mail me with any questions, Darren
Posted on Dec 17, 2008
Please send me info on cap replacement, to fix flashing green light problem.
fitzz47@comcast.net
Thanks in advance.
Posted on Sep 26, 2008
Please send info. on how to fix flashing green light on mitsubishi 65513 uteh20mesa@aol.com thank you
Posted on Aug 18, 2008
  • 927 Answers
Good Day, charliek1;
This a very common problem with model. Don't listen to other comments unless the use the correct replacement parts.
SYMPTOM: Power LED does not stop blinking after plug in.
CURE: replace C9B01, C9B02,C9B10, and C9B11 (1000 uFD 16V) on the DM PCB. Replace them with part # 181P734030 (680uFd 16V).
The DM Board (PCB) is located on the very left side of the TV looking from back. Caution on removing Board and note what cables you disconnect to access the Metal Shielded Board.
Good Luck, big IRISH.
Posted on Jul 18, 2008
  • MICHAEL MULLINS Jul 19, 2008
    I am glad to have been able to help you, and by using the proper replacement, recommend by the manufacture, your TV should not experience this failure again.
Mitsubishi 65513 TV, dm board
I dont have a pdf but I have something that can help your problem.
Just click below for the solution related to your problem of DM board.
http://www.fixya.com/support/t1012464-fixed_blinking_light_but_still_no
Hope it may help you;
Regards;
VOTIT
Jan 28, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Mitsu 65513
I also have the blinking green light problem with my WS-65513 Mitsubishi TV. I would appreciate any information you could send to help fix this problem. Thank you, Keith. elitemachine @netnitco.net
Nov 04, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Constant green blinking light Mitsubishi tv WS-65513
Unplugged my Sony for 36 hours from wall and it solved the problem
Oct 20, 2008 | Mitsubishi WS-65869 65" Rear Projection...
WS-65513 Blinking Green Light
I have a Mitsubishi MITWS-65813.
The green led light constantly blinks. I tried the reset button and green light is still blinking. I unplug the tv, waited a few days, then plugged the tv back in, the green light still blinks. I have a lot of experience with soldering. Do you have any suggestions or can send repair directions/protocol for the DM board.
via email? Thank you in advance for your help. Your help is much appreciated!
Sep 29, 2008 | Mitsubishi WS-65513 65" Rear Projection...
You can get the V23 DM repair kit at the following link which has the replacement capacitors and the instalation instructions on Cd which has pictures of the repair. Its listed under the repair kit category.
http://servicemanuals.vstore.ca/
Aug 29, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65513 green blinking light
Good Day, nixonam;
Jul 08, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Blinkink light
Good Day, jcarnell;
Jul 05, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi TV WS-65713
Please send me the instructions on how to remove and repair the dm board in my mitsubishi ws-65513 tv. The green light keeps blinking. thanks
samzlades@yahoo.com
May 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Please study the procedure at the following address.....
www.chrisandnat.com/projects/blinkingtv/blink.htm .....
use 1000mf 25v or 35v 105 degree capacitors to replace
original four 1000mf 16v..............if new ones are a little
too high,just lay them over on board........
Look it over..........let me know......................T.
Jan 07, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi ws-65513
Have you looked at the DM board fix yet that's available here. http://www.fixya.com/howto/h154057-mitsubishi_dm_board_repair Check it out. If the inside of your TV set does not look like this, you will need to get the service manual to disassemble the set and get to the DM board, but use the rest of the guide to repair the board. If you are successful, you will save almost a 1000 bucks! Good Luck
Jul 14, 2007 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
548 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
