Question about Refrigerators
Having had to transport afridge/freezer on its side for Half an hour, how long should I leave it before switching it on . Thanks Mike
  • 828 Answers
Leave it standing for about 8 Hours. If the refrigerator is not that old it would not have built up much sediment in the bottom of the crank case. Transporting a refrigeration system on its side is a no, no. If solids work their way out into the system it can plug up dryers and sometimes the capillary tube that feeds the refrigerant into the system. I wish you luck.
Posted on Jul 10, 2008
Can I transport one of your 2 door Fridge/ freezers laying on its side.
only transport a fridge or freezer on it's side if the upright transport is NOT an option.
any chiller using compressed liquid/gas and placed on it's side should be left for 24 hours to settle before powering at the mains, this will allow the coolant time to sink where it should be and prevent the pump (& chiller) from failing.
Nov 23, 2017 | Refrigerators
Can this freezer be laid on it's side or back to transport? Thank you.
Lay down a shipping blanket or an old blanket and transport the freezer on it's back.
Aug 07, 2015 | Freezers
I have to transport a refrigerator - Model # ED25PWXBW00 (side by side) approximately 100 miles. Can I lay it down? What will happen if I do?
As far as I know, you can transport a refrigerator laying down but you should leave it upright for 24 hours BEFORE you plug it in.
Aug 22, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
The fridge isn't cooling though the freezer half is working fine. It was recently transported quite a distance in its side (well braced and padded), and left to stand 20 hours before being plugged in. We...
There are 2 reasons. While transporting if they lifted with won wards to discharge side, chances are there to oil entering. And while switch on it starts pumping the oil.Secondly, chance for gas leak.
It's advisable to remove gas and check for leak. If no leak, flush out the system and replace drier.
Vacuum and do gas charging. Please write if it's helpful.
Dec 31, 2010 | Heating & Cooling
Will the freezer work after being plugged in 6 hrs after transporting it on it's side?
yes it should be fine how ever you may need to run the unti for about fifteen minutes then shut it off four half hour or so then start it back up you should not have nay problems with it./
Nov 12, 2010 | Frigidaire FRT18G4A Top Freezer...
What causes my fridge to run hot? It thinks its an oven! It was working fine prior to transportation, after which it was left for three hour prior to switching on when it ran hot.
I believe it may have been laid down during transport. Leave it unplugged for another 24 hours and allow the compressor oil to return back down to the compressor. This is a very common problem if laid down on side during transport. After this time replug the power cord and listen and feel to insure warm air blows from bottom of refrigerator and cold air in freezer. The oil is to thick and heavy to be pushed through the capillary tube. Just be patient and not try to push the time getting it to cool again as the compressor will continue to overheat if oil remains in the cap tube. Thanks Sea Breeze
Mar 12, 2010 | Maytag MSD2454G Side by Side Refrigerator
I need to know if it is possible to transport side by side refrigerators laying flat. or almost flat. This will be a short move for about 1/2 hour.
Hello, Yes you can move your side by side laying on it's is most important though that when you have it in it's new place you leave it unpluged for 24 hours so the oils can run back into the compressor. If you have any other questions please feel free to comment again...Mike
Aug 24, 2009 | Refrigerators
Can Model PACR12-GE be transported on its side with no problems?
Most ac or refrigerators and freezers can not be moved moved in any position other than in the upright position. The few that can will tell you in the owners manuel. The ones that can after you move them you must put them in the upright position and leave set not plugged in for between 12 and 24 hours.
Jul 02, 2009 | Genie Aire PACR12 Air Conditioner
Kenmore 14CF upright freezer will die after a day or so
The defrost timer is faulty or you have a defrost circuit short, unplug remove back panel inside the freezer and check for a short in the heater and defrost thermostat.
Dec 30, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Refrigerators Logo
384 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
