Question about Gateway GT4010 (RBGT4010) PC Desktop
Hey man hows it going
We just came up on a gateway gt4010 desktop, The second we plugged it in we were unable to get any responses from the computer. tried changing the power supply but were unable to due to the 20+4 adapter for the motherboard. i have no clue what could be wrong. if u can please give me a call 209-467-0787 i would greatly appreciate. thnx man
  • mrelmo Aug 09, 2008
    ok mine is a gt 4016 but the same problem the fan on the power supply is not working, the on/off switch does not work, but the case fan works, the fan on the video card works, as soon as i plug the power cord in the fans start up i can only power down by pulling the cord, i did replace the power supply but it did not make any difference, there is no beeps from the motherboard
  • Lucy Kramer Aug 18, 2008
    So, my Gateway GT4022 does the same thing. When I can it to turn on, the monitor wants to switch off after just a second or so. Every now and then it will stay on for up to 15 minutes. My fan also works, but no other lights. Not sure where to go from here.
Ok i have the same problem, the fan on the power supply does not turn, but the case fan and the video card fan turn, the are no beeps from the mother board and the on/off button does not work, as soon as the power cord is plugged in the fans power up but nothing else and no beeps from the mobo, i replaced the power supply but no difference help
Posted on Aug 09, 2008
    Sergeant:
  • 329 Answers
Have you test the power supply for voltage, Is it good, if it is then the problem of course is not power supply. Some power supplies have a light on them. Also does the power supply fan work, If not almost always sure sign power supply is gone. Old power supplies are still available Every time I junk a computer P4 or older I save to power supply, What wattage?
Posted on Aug 01, 2008
Gateway gt4010: Had to format with a generic windows xp cd, not the gateway recovery cd. The computer runs, but cant connect to the internet. It wont even recognize that an internet cable is plugged in....
Hello
Here is a link for your pc with the drivers listed you want the modem drivers.
Im assuming your using another pc to make contact to Fix ya.Download and burn the drivers to a cd or floppy,then install to your gateway.
Hope this helps
Thanks for using fix ya
Feb 06, 2011 | Gateway GT4010 (RBGT4010) PC Desktop
Gateway GT4010 boots then starts beeping and shuts off
First check your power supply section and check your power fan that is running properly. if ok then the suspected area is your processor section. please check it if its collar fan nor running properly then clean up or change that. and the other advice is please check your processor pin which are too tiny. be careful about these.
Apr 08, 2010 | Gateway GT4010 (RBGT4010) PC Desktop
Gateway gt4010, wont power on.
The fan turning off will be the cause of the PC shutting down.
This could be caused by a faulty fan or bad connection to motherboard.
1. try reseating the fans power plug on the motherboard
2. if that doesn't help, try replacing with new fan.
3. if that doesn't work then most likely motherboard problem
Feb 11, 2010 | Gateway GT4010 (RBGT4010) PC Desktop
Gateway gt4010 usb ports are all failing.
It's your hard drive going bad! I had the same problem in my company. Could not figure it out but when i flopped the hard drives they started working agian.
Mar 26, 2009 | Gateway GT4010 (RBGT4010) PC Desktop
Screen wont stay on
We have already noticed that the cables are securely connected?
If yes may be the graphics card! if you have a friend who can lend to test was the best. Or try with another monitor
Dec 22, 2008 | Gateway GT4010 (RBGT4010) PC Desktop
Gateway stays 10 min at BIOS splash screen
I would say there a minor corruption in your hard drive. How old is this computer?? May time to reformat it.
May 15, 2008 | Gateway GT4010 (RBGT4010) PC Desktop
My gateway GT4010
check the power plug first and see if it is properly plug in and turning on the power button, if does not work, get a new power plug and try as i've said again and if does not work the power system has problem and should be changed.
Uzowuanya
e-mail:uzowuanya@yahoo.ca
Feb 12, 2008 | Gateway GT4010 (RBGT4010) PC Desktop
Gateway GT4010 (RBGT4010) PC Desktop Logo
120 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
