Question about Sharp Aquos LC-20B2U 20 in. LCD Television
Component connection does not support progressive scan DVD
Trying to use progressive scan/component connection on my Sharp LC-20B2UB. I have the operation manual but cannot locate my problem. I get a double picture like a TV with no component input. I am useing correctly colored cables connected to same color coded RCA connectors. DVD switch in "progressive" position.
Thank You,
Mike in Tucson
  • ranchn Jul 11, 2008
    What are the component inputs for?
    Sergeant:
  • 280 Answers
No can do the set cant deal with that signal. turn off prgressive scan on the DVD the signal is still a preaty good one. Only blue ray or HD DVD will get the real HD.
Posted on Jul 10, 2008
  • coyotedave Jul 11, 2008
    They are better than the cable connectors and carry digital better. HDMI is the best but not all Players have them.
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
Dvd, sound, no picture
If your DVD is external, I'd check TVs input settings: if your DVD on "progressive scan" mode, it delivers video signal via "component" connections: green, blue, red plus 2 separate red/white for the sound. If you trying to use 3 wires: yellow, red, white( composite), good chance, that the only sound is delivered. Try to switch DVD off 'progressive", if you only have 3 wires. It will deliver "picture". Or, verso-visa: using "component", 5 wires, but DVD set off "progressive scan". I've seen that confusion many times! Unless you have 'built in" DVD player. no matter what, it's must be broken! Use external DVD player, instead! $30 and trip to the store, will solve your problem. Don't want to fix TV, if everything else is alright. Myself, I never liked those "combo" units. You got stuck with mediocre TV and lousy DVD player. Better: separate them!
Good luck,
Alex.
Dec 25, 2011 | Toshiba Televison & Video
Toshiba SD-V55HT stuck in Progressive scan mode.
Hello
Progressive Scan Video provides the highest resolution
pictures with less flicker and line structure
If you are using the COMPONENT/PROGRESSIVE
SCAN VIDEO OUT jacks, but are connecting the
DVD/VCR Receiver to a standard (analog) television,
set Progressive Scan to Off
If you are using the Component Video jacks for
connection to a TV or monitor that is compatible with a
progressive scan signal, set Progressive Scan to On.
To ON and OFF this function, Press "Setup" to display the setup screen.
Surf through, and hilight "Progressive scan" and press "Ok or Enter"
Here you can set this function ON or OFF. If you wnat to get it OFF, select OFF and press Enter.
OK.
Jun 25, 2011 | Toshiba SD-V55HT DVD/VHS Home Theater...
I have a dvp 3960/37 player I am trying to hookup to a Sony KV 32fs120 TV using YPrPb as a component. The Sony manual says the DVP must be Setup before connecting. The Phillips manual says to use the TV's...
If you are using the component output from the dvd player (3 wire video) progressive scan connect corresponding cable to tv . Besure to match colors. If you are getting a black and white double image you need to set the output of the dvd player to progressive scan. See owners manual for dvd player to set this. The yelow color jack on the tv is composite video and is not compatible with the 3 wire video .
Nov 20, 2009 | Car Audio & Video
Need to hook up a TV,VCR-DVD player,and CD player
Progressive scan video output would be available on Component Video terminals of dvd player so set connections between TV and dvd player via Component Video cable.
Please intimate model and brand of product that you need instruction manual.
Thanks.
Aug 31, 2009 | Sanyo Cinematic Progressive Scan DVD...
How to set the "Progressive Scan" to "off"
I did the same thing. Hit progressive scan and now I have sound but no picture. I can't get to the menu to turn progressive scan off! Help!
Feb 23, 2009 | Sony DAV-SB100 System
Split screen on DVD player
This sounds like a progressive scan issue (unit in P.Scan Mode) here is a C&P from the manual
Set "Alt Video Out"
Highlight "Alt Video Out", then press the RIGHT button to select
one of the following options:
• S-Video - Select this if you are using the S-Video OUT jack on
the rear panel to connect to a TV.
• Component - Select this if you are using the COMPONENT
VIDEO OUT jacks on the rear panel to connect to a
Progressive(480p) or Interlaced (480i) TV.
• See your TV owner's manual to determine what type of TV you
have.
- Interlace : Interlaced Scan mode will work.
- Progressive : Progressive Scan mode will work, and Video
and S-Video will not work.
• Press the Progressive button on the front panel if you have a
Progressive scan TV only. Otherwise, the picture will be
disturbed.
Feb 04, 2009 | Samsung DVD-V3650 DVD Player/VCR
Stuck in progressive scan mode.
Based on your description, it seems that you set the DVD to progressive scan output, but have it hooked up to a TV (CRT) that cannot accept this signal. Because the TV can't accept the signal, you can't view the DVD menu to change the setting back to interlaced.
On the back panel you have "Component Video Out" for output via component cables, but there is also a yellow RCA connection labeled "Video Out". This is a "composite video" connection which does not support progressive scan. Try disconnecting the component cables and connect the composite video to a TV. The DVD will likely (hopefully) send a compatible signal (480i) through this connection, which will give you access to the menu.
May 12, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
No progressive scan from component input
Sanyo DS27930 does not support progressive scan
DVD player must be set to interlaced scan
Nov 24, 2007 | Sanyo DS27930 27" TV
Sharp Aquos LC-20B2U 20 in. LCD Television Logo
153 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
