Question about RCA HD52W56 52" Rear Projection HDTV
Tv don't stay on
The power light turns on and off three times in a row and then don't turn on the tv sometimes we keep trying and it take about an hour before it turns on and stays
  • 2 more comments
  • Anonymous Jul 22, 2008
    what dose the fuse look like
  • Anonymous Jul 25, 2008
    none so far. Tv just started acting up.
  • gordon6996 Jul 26, 2008
    Mine takes like 3 or 4 tryies to start up. once it is up and working the tv works great. This tv is only 5 years old are they built to break down? Would like to know why this happens. My last tv lasted over 20 years no problems my parents still watch it.
  • nikkia_35 Jul 26, 2008
    same problem clicks on and off but mine won't stay on at all
  • RCA Master
  • 8,617 Answers
Try resoldering the flyback and the other components near the flyback. Common problem with that chassis. It will eventually kill the flyback if left unsoldered.
Posted on Jul 10, 2008
Powering on and off
I must say this is a wierd problem here. First of all, make sure that the T.V. has enough space, and the cables arent layed on each other, give each cable its space. Now, try to check the main T.V. cable, is it strongly plugged in? because it should be, might be that your cable is weak and gets loose sometimes, so try to plug it in in a strong way. Keep me informed.
Jul 22, 2007 | JVC AV-56WP30 56" Rear Projection...
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Power problem
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Jan 30, 2009 | Panasonic PT-47WX42 47" Rear Projection...
Rca will not turn on
16v 2200uf capacitor on the 6v power supply bad top of capacitor usually domed
Aug 17, 2008 | RCA HD52W58 52" TV
TV keeps turning off.
could be a couple of things
first i would guess to be convergance ic then IC831S (STR-X6456).and could be loose connection.
you could try this to narrow it down, purchase a can of freeze at radio shock and spray it on these ic one at a time see if it stays on longer or just replace them
Dec 20, 2007 | Samsung HCN4226W 42" Rear Projection...
TV KEEPS TURNING OFF ITSELF
how long does it stay powered on and do any of the lights flash if so how many times?
Dec 16, 2007 | Samsung HCN4226W 42" Rear Projection...
Samsung 46" DLP
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Nov 08, 2007 | Samsung HLN467W 46" Rear Projection HDTV
Zenith E44W46LCD turning off
That would be the first thing I would try as it is probably flakey.
Jul 06, 2007 | Zenith E44W46LCD 44" Rear Projection...
RCA HD52W56 52" Rear Projection HDTV Logo
46 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
