Question about Car Audio & Video
Kenwood kdc 241sa "Demo" is not comming up on display menu in order for me to turn off the demonstration mode setting.
  • JTIPPER1 Nov 10, 2008
    I have the same probllem.. It tell s you that Demo mode should come up on the diplay and you can turn it off, but it doesnt come up, dim OFF ETC DOES ,BUT NOT DEMO !!!
You have to do this all in standby mode. When you scroll up there should be a "Demo-ON" then push the am/fm tuner to the side like you are changing the channel. It will say then "Demo-Off".
Posted on Dec 26, 2008
Kenwood w-3537 how to turn off demo mode
To turn off the Demo mode you need to:
Press source button, then select stand by mode.
Using the FM/AM button select Demo display
To set the demo mode hold the source button for 2 seconds
it will switch from on and off.
If this doesn't help I have included a link of the manual, it's on page 25.
http://www.kenwood-electronics.co.uk/WebFiles/File/uk/download/Instruction%20Manuals/KDC/KDC-W3037_W3537_W4037.pdf
Jan 09, 2011 | Kenwood Car Audio & Video
Tip
How to Turn Off Demo Mode
<span style="font-weight: bold;">Blaupunkt:</span><br /><br /> <ol> <li>Press the (PWR) to turn the unit off.</li> <li>Press the (DIS) and (1) simultaneously for more than 3 seconds to activate the demonstration mode.</li> <li>Press both buttons again from more than 2 seconds to cancel this mode.</li></ol>or<br /> <ol> <li>Try pressing and holding menu for 10 seconds to turn it off.</li></ol><span style="font-weight: bold;">Bose:</span><br /> <ol> <li>Unplug the unit and wait ten seconds.</li> <li>Plug it back it and press repeatedly on the eject button.</li> <li>The demo disc will eject.</li></ol><span style="font-weight: bold;">Clarion:</span><br /> <ol> <li>Press and hold the "D" button to enter the settings menu.</li> <li>Use the next track button until SCRN SVR is displayed, use the rotary knob to select "OFF".</li> <li>Press the "D" button to exit the settings menu. </li></ol><span style="font-weight: bold;">Garmin:</span><br /> <ol> <li>DO NOT DO THIS TO A FUNCTIONING UNIT. Hold down your MENU key, Go to your SYSTEM tab, SYSTEM INFORMATION.</li> <li>When the software version window come up, hit ENTER.</li> <li>Press RANGE UP 3 time, Range DOWN 3 times, RANGE up 1 time, RANGE down 1 time.</li> <li>The system should reset, when asked to use RETAIL mode say NO.</li></ol><span style="font-weight: bold;">JVC:</span><br /> <ol> <li>Hold down the SEL button for 2-3 seconds.</li> <li>Use the &lt;&lt; or &gt;&gt; buttons to find DEMO.</li> <li>Turn the VOLUME knob until it says OFF or DEMO OFF.</li> <li>Press SEL again.</li></ol><span style="font-weight: bold;">Kenwood:</span><br /> <ol> <li>Go into standby mode, hit menu and then press "hold". A menu should pop up.</li> <li>Use knob to select demo.</li> <li>Press in on the knob and hold until it says "demo OFF".</li></ol>or<br /> <ol> <li>Switch to Standby.</li> <li>While holding down 5, press Reset with a paperclip or similar and continue to hold down 5.</li> <li>Demo mode should now be off.</li></ol><span style="font-weight: bold;">Magnavox:</span><br /> <ol> <li>Press and hold the menu button for 5-10 seconds until the normal menu pops up and then go to the section that says demo and turn the demo mode off.<span style="font-weight: bold;"></span></li></ol><span style="font-weight: bold;">Pioneer:</span> <ol> <li>Turn the vehicle's key to the Accessory or ACC position.</li> <li>Press the "Source" button, located on the left-side of the radio, and press the "Off" button that appears on the screen to turn off the unit.</li> <li>Locate the "Volume/Mute" button, located on the left-side of the unit.</li> <li>Press and hold the "Volume/Mute" button until the demo mode turns off.</li></ol>or<br /> <ol> <li>Turn the radio off.</li> <li>Push "Memory 5" or "Memory 6" (depending on your model) for just a second.</li> <li>When you hear a beep, demo mode is off.</li></ol><span style="font-weight: bold;">Pioneer Premier:</span><br /> <ol> <li>With the unit Off and the car ignition On and Running, press button number 5 and release that button to turn off Demo mode.</li></ol><span style="font-weight: bold;">Sharp:</span><br /> <ol> <li>When the unit is in the power stand-by mode (demonstration mode), press the X-BASS/DEMO button.</li> <li>The demonstration mode will be cancelled and the display will disappear.</li></ol><span style="font-weight: bold;">Sony:</span><br /> <ol> <li>Press display twice to turn off Demo mode.</li></ol>or<br /> <ol> <li>Press and hold the select button.</li> <li>Press the select button repeatedly until the desired item appears.</li> <li>Rotate the control dial to select the setting DEMO.</li> <li>Rotate the control dial to select the setting DEMO-OFF.</li> <li>Press and hold the select button.</li></ol><br />or<br /> <ol> <li>Press the STOP and the EJECT buttons simultaneously for 5 seconds.</li> <li>UNLOCKED should now appear in the display and you should be able to eject the disc.</li></ol>If Demo mode comes back on every time you turn off the ignition and back on, you have a wiring problem with your Constant +12 Volt Memory wire.
on Jun 22, 2011 | Audio Players & Recorders
My kdc 138 is acting weird
CLICK HERE for your owners manual.
To exit DEMO mode - (see page 12)
And also pull the radio and check the brown TEL mute wire is not touching ground to activate the Telephone Mute option.
It should be taped off or terminated and is not used in your installation.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Aug 08, 2009 | Kenwood KDC-138 FM / AM Receiver
Kenwood excelon kdc-x589 demo mode makes me mad
CLICK HERE for your owners manual in PDF format.
Cancelling the DEMO MODE is explained on page 29... as follows....
Select the Demonstration mode
Push the Control knob to [FM] or [AM].
Select the "DEMO" display.
Set the Demonstration mode
Press the Control knob for at least 2 seconds.
Each time the knob is pressed at least 2 seconds,
the Demonstration mode switches "on" or "off"
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 21, 2009 | Kenwood KDC-X589 CD Player
The function DEMO MODE can´t be set off. I want to set any wall paper and the DEMO MODE stay ON.
CLICK HERE for a PDF version of your manual.
To turn OFF DEMO mode - go to page 50 of the manual.... and find the following-
1 Select the Demonstration mode
Select the "DEMO Mode" display.
2 Set the Demonstration mode
the Demonstration mode switches as shown
below.
Demo Mode "ON"
Demo Mode "OFF"
Apr 10, 2009 | Kenwood KDC-MP7028 CD Player
How to turn demo off kdc-mp3035
1. Be sure the unit is in the stand-by mode (ie: turned off)
2. Push the control knob towards FM or AM. Select the DEMO display
3. To set the DEMO mode, do this:
Press the control knob for at least 2 seconds. The demonstration mode alternates between DEMO ON and DEMO OFF.
Although it doesn't say, i would imagine you need to press the MENU button to exit this screen.
This information came from the instruction manual that I was able to download from the internet. Shoot me an e-mail and I'll forward it off to you.
Mar 09, 2008 | Kenwood KDC-MP3035 CD Player
KENWOOD KDC-W6537U
Hi there
You can get the instruction book from here
http://www.kenwood-electronics.co.uk/WebFiles/File/uk/download/Instruction%20Manuals/KDC/KDC-W6537U.pdf
Page 29 tells you how to turn off Demonstration mode. Blue toothe operation is well detailed also. Good luck. Any problems, I have downloaded the manual to help you. :)
regards
Graeme.
Feb 14, 2008 | Kenwood KDC-MP4032 CD Player
Kenwood Exelon 891
Check for dry joints in the display unit
Jan 15, 2008 | Kenwood KDC-X891 CD Player
Demo mode problem
From the user's manual (pg.23): 1. Select the Demonstration Mode. Push the Control knob towards [FM] or [AM]. Select the "DEMO" display. 2. Set the Demonstration Mode. Press the Control knob for at least 2 seconds.
Feb 13, 2007 | Kenwood KDC-MP232 CD Player
Car Audio & Video Logo
282 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
