Question about Behringer EUROPOWER EP2500 Amplifier
Proper mode settings
What is the proper/best mode settings for Bridge mono to push Low mid and Stereo to push Highz
  • 1,512 Answers
Hi bongodboss
The user manual for this amp has good instruction on how to connect it. You can download a copy from here.
Page 9 has info about using the amp for "bi-amping" The amp is only a stereo unit, so to do a 3-way system, you will need at least 1 amp mono in bridge mode for lows, and other stereo amp for mods, and another stereo amp for highs. You could use the internal low pass filter for the bottom end, and a 2 way crossover for the mids and highs. Much simpler doing a 2 way system with composite bins for mids and highs, and subs for lows. You only need the 2 amps and use the low and high pass filters inside the EP2500. If you need anymore help on this, I am happy to talk to you more.
regards
robotek
Posted on Jul 14, 2008
Accidently had peaker connect to A side while in bridge mode wud mixer be damaged
Hi, When an two channel (stereo) amplifier is connected in bridge mode the polarity of one channel is reversed, for this example say channel B. An identical (mono) signal is applied to both channel inputs.
The output is now connected between the two channel +ve outputs. As channel A's output goes +ve , channel B's output goes -ve, thus doubling the output voltage.
On this Behringer powered mixer, the bridge switch simply connects the power amp section inputs, the required way.
The bridged output is wired to the B output between pins 1+ and 2+ of the 4 pole Speakon connector. (Because usually pins 1+ and 1- are used, stereo operation is unaffected.)
So.... If you connect a speaker from the A output alone then I would expect it to work, BUT if there is already a speaker connected from the bridge output, then what happens will depend on the amplifier design.
At best the A channel will see too smaller impedance, and hopefully shutdown.
This is a Behringer, it has digital (class D) power amps, and it does Not claim any amplifier protection !!!
If the powered mixer works in normal stereo, then it is probably OK.
If it then does Not work in bridge mode it is likely to be the connector wiring.
All the best.
Apr 07, 2014 | Behringer Pmp4000 Europower 1600-watt...
I have a QSC RMX 2450 in which both channels are driven even though the amp is in stereo mode and I am only sending a signal into input channel one. It acts as if the amp is in parallel mode but I have...
My thoughts are that the amp has a poor channel separation but usually you can only hear a very quiet trace of the sound through the undriven channel. I agree with Taurus and make sure that the switch is making contact and moving all the pins to the proper points. This is a Home stereo amp, it comes with an extended 6 year warranty if you register it, I would check into getting a warranty repair before doing anything to it! Looks like a nice quality piece, those dip switches are a little bit confusing but the way it's built it is necessary to have them. It has a Dual Mono amp section so there is no way that any sound can be crossing over unless the swithches are directing it. The only way that can happen is in Parallel or in Mono. You could be in Stereo / Mono which would input both channels and output 3 settings a 1, 2 in Stereo & a Mono, Try hooking a speaker up to the Mono/ Bridge outputs and see if it's louder than just hooked up to 1 or 2. Parallel inputs will give you Mono 1 & 2 with Bridge off, and might give you Mono 1 & 2 with a bridged Mono if the bridge is on, like 3 channels all mono with one getting twice as much power as the 1 & 2 will put out. Although they have it labeled to not use it in those settings it's possible to do. I can see why you would be checking the switches.
It may actually be labeled incorrectly , as strange as it seems, many Chinese products have been made with labeling errors. Plus and minus have been wrong on Asian Made car amps so it's not that inconceivable that this may have some incorrect settings shown?
Apr 03, 2013 | Car Audio & Video
What should i set the micro switch on the back at?
Power:
2 ohm stereo (per channel): 975W
4 ohm stereo (per channel): 660W
8 ohm stereo (per channel): 400W
4 ohm bridge-mono: 1950W
8 ohm bridge-mono: 1320W
Load Impedance: Safe with all types of loads. Rated for 4 and 8 ohms in Stereo mode, 4 ohms in Bridge-Mono mode
Voltage Gain to 1-kHz, 8-ohm rated output,
CE 1000:
30.5-dB gain at 1.4-volt sensitivity;
26-dB gain at 2.34-volt sensitivity.
CE 2000:
32.1-dB gain at 1.4-volt sensitivity;
26-dB gain at 2.83-volt sensitivity.
Required AC Mains: 50/60 Hz (North American units are 60 Hz only); 100, 120 and 230-240 VAC (+/-10%) units are available.
AC Line Current,
100 Volts: 11.4 A;
120 Volts: 9.5 A;
230-240 Volts: 5.0 A;
At Idle: All amps draw no more than 90 watts.
AC Line Connector: NEMA 5-15P (15 A).
Sep 07, 2012 | Crown CE2000 2-Channel Amplifier
How do I wire up my 4subs in bridged to my peace 2600
Please state the subs impedance, but assuming 4 subs with 8Ohm Voice Coil you CAN'T run them in parallel in Bridge Mono because this amp's minimum impedance is 4Ohm in bridge and 2Ohm stereo, maybe a series/parallel connection work, but what's the advantage to run them in Bridge mode? This amp delivers 900W per channel at 4Ohm, you can run a pair paralleled for each channel in a safe way and without the high-risk of your amp being destroyed, besides, amp power at 4Ohm Bridged is NOT recommended for continuous use, let me know your results...
May 13, 2012 | Peavey Pv 2600 Power Amplifier
How to bridge a kenwood kac-9105d
Are you referring to something like this, using two different amps? It is a mono amp, meaning there's one amp in the box.
"KAC-9105D also has a Dual Mono Drive connection that allows you to strap two KAC-9105D amps together to power a single subwoofer."Quoted fromhttp://www.kenwoodusa.com/Car_Entertainment/Amplifiers/KAC-9105D
Here's a link to a page out of the Yamaha Sound Reinforcement book. the top shows a stereo amp (1 box, two different amps inside) hooked up to drive two different speakers, which is known as 'stereo' mode.It then shows the two amps hooked to the opposite sides of the same speaker, which is known as 'bridge' mode.http://books57.net/ampOuts.gif
Any help?
Feb 24, 2012 | Kenwood Car Audio & Video
Can't change from MONO to AUTO mode
Hello
Can't make sound from mono to auto is your problem I thinks and posts this solution.
Hit the "Menu" button and surf through, come to "Sound Adjust" window.
The settings allow you to change and adjust sound in your TV. There are Bass, Treble and Balance control to adjust to your individual taste.
To adjust them
1. Press Menu button.
2. Press UP or DOWN button to select the desired item.
3. Press => or 4. Press EXIT button when finished.
When adjusting the parameter of "Balance" control, always set it to mid position to get stereo sound from both speakers. If it is set to any extreme end, there will be no output from the speaker of that side, and will hear as mono.
If you press "0" [Zero] button, you can reset the sound settings to it Factory settings.
To select 'Streo mode;
1. Press "Menu" button.
2. Press UP or DOWN button to select MTS [Multi-channel Telivision Sound].
3. Press => or [The ON AIR arrowtells you if a broadcast is in stereo AND/OR contains the SAP.
Press "Exit" button when finished.
Keep the TV in stereo mode to get the best sound quality. The sound will work in stereo
mode even if a certain broadcast is in mono sound only.
Choose the mono setting to reduce excessive noise on a certain channel or broadcast.
Selecting SAP will allow you to hear an alternative soundtrack, if one is available.
Apr 01, 2011 | JVC AV32F476 32" TV
Epiphone BB King Lucille guitar treble pickup in mono mode
Realize that when you plug into the one jack it disconnects the fingerboard pickup from the mix.
DO NOT USE "stereo" cables as it is intended to use TWO MONO cables, one for each side of the stereo.
IF you plug into the one jack that will connect to the bridge pickup, it will disconnect the fingerboard pickup from the mix BUT leave the fingerboard on its own jack.
That same jack will have BOTH fingerboard and bridge pickups IF the second jack (bridge) is not plugged into.
This is according to the schematic. If you find that yours works backwards, then either the schematic is wrong OR your guitar pickups may be electrically swapped.
Apr 19, 2010 | Epiphone B. B. King Lucille Electric...
Installing two amps
No, thats what you don't what to do. Even if you have 2 matching amps you don't do that. Every amp puts out different, and for 2 subs, you want to play at the the same time. If your only running 2 10's, I personal would just run the alpine (it's a mono amp made especially for subs) thats plenty for what you have. make sure you bridge them to get the full response. And your other amp i would use for your highs or mids, but run it @ stereo , which is 300 w @ 4 ohms. (Note: 600w @ 2ohms would be bridged and would play in Mono)
Building Competition stereo's is a big hobby of mine.
May 04, 2009 | Alpine MRD-M605 - V12 MONO AMP 600WX1 RMS...
No stereo signal out from yamaha p 2500 s
It's unclear what type of connectors are on the end of the cables(s) coming from your computer.
This amp only works with mono 1/4" TRS and XLR connectors, not standard RCA connectors.
Did you try the Right one in the Left Channel to see if the Left Channel worked?
Refer to the following manual and read up on the connectors (page 7) and the use of the Stereo/Parallel/Bridge Switch (page 8). When it is NOT in Stereo Mode the unit only uses the Right Channel controls and input.
http://img3.musiciansfriend.com/dbase/pdf/man/m_480824.pdf
STEREO/PARALLEL/BRIDGE switch
Use this switch to select the operating mode.
• STEREO mode
Channels A and B operate independently (as with a conventional
stereo amplifier). The Channel A input goes to the Channel
A output jacks, and the Channel B input goes to the
Channel B output jacks.
• PARALLEL mode
The Channel A input signal is output through both the Channel
A and Channel B output jacks. The Channel B input jacks do
not function. Channel A and B volumes can be independently
adjusted.
• BRIDGE mode
The Channel A input signal is output from the BRIDGE output
jacks. To adjust the volume, you must use the Channel A volume
control knob.
Apr 03, 2009 | Yamaha P-2500 Amplifier
Is that ok to do mono on Thump TA1001
yes, it is a bridgable amplifier, if that is what you are talking about. Look at the speaker output terminal and it should have markings on it for stereo output and it will have a line between the 2 terminals to use for bridging it. When you bridge an amplifier it is mono. There may also be a switch on the amp for stereo or bridged. Put that switch in the bridged mode. Connect one speaker to the speaker output and you have your bridged mono amplifier. If you plan on using 2 woofers, it is better and safer to use it in stereo mode with one speaker on each channel.
Let me know if you need any more help,
Dave
Aug 08, 2008 | Thump TA1001 Car Audio Amplifier
Behringer EUROPOWER EP2500 Amplifier Logo
183 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
