Question about GE GSS20IEP Side by Side Refrigerator
Ge fridge gss20ieph ww
How volts is going to the heater ac or dc? thanks
    President:
  • 1,462 Answers
Ac volts
Posted on Jul 11, 2008
110 volts works but 12 volt does nothing, checked voltage 13.6 v. Any suggestions. Thanks.
RV Refrigerator Stop Working? - RVing - Fun Times Guide
rv-roadtrips.thefuntimesguide.com/2009/09/rv_refrigerator.php
If your refrigerator works on gas, but won't work on electric, you may have a burned out.... Cirtis, We are camping in Montana and our dometic refrigerator decided to stop ......Won't know until you can confirm you have proper voltage to the fridge. ... If you have confirmed both 12 vdc and 110 vac power at the fridge, I would ...
[PDF]Dometic Manual Refrigerator Diagnostic Service Manual
www.nationalserroscotty.org/resources/dometic-service-manual.pdf
Dometic Manual Refrigerators. ... 110 Volt Plug. 2. .... This is Dometic's Manual Refrigeration Diagnosis and Troubleshooting program. In this ... we will discuss the way an absorption cooling unit operates, and the ... gas, 120 volts AC and 12 volts DC .....In this condition we are still boiling ammonia but have no hydrogen for.
Dometic Fridge problems - RV mechanic
Dec 28, 2015 | Dometic CF-050DC CF-50 Waeco CoolFreeze...
My dometic rm2652 check light comes on after a the refrigerator is turned on with either gas or electric. What could be the problem?
First things to check would be the receptacle that fridge is plugged in to at back for power to it. You may have tripped breaker as well. Either way, you need to confirm that you have AC (hydro) voltage going to fridge, as well as test for min 11-12 Volts (DC) to back of fridge where the DC voltage connects. The check light coming on tells me you have 12 Volts DC, but just confirm. With propane on, make sure you have propane to stove etc, then try starting fridge on propane only setting, and listen or watch outside at burner for ignition. Let me know if you see it sparking, or hear it sparking.
Mar 24, 2012 | Dometic RM2652 Refrigerator
Wattage use
Your calculations is correct - 220 X 0.7 = 154 watts.
If your fridge only runs on 220 volts then you need solar panels that charge 12 volt lead acid batteries and then use a inverter to convert 12 volts DC to 220 volts AC.
Jan 13, 2012 | Kelvinator Refrigerators
Just bought a used 1987 Real-Lite truck camper. The roof air unit is Dometic as well as the LP/AC refrigerator. When turned to "cool" the air conditioner really draws down, dims the lights, and eventually...
To start with, if it's plugged in to a 15 amp breaker, and extension cord, the compressor starting up may just be enough to trip the breaker. It will draw close to 15 amps on start-up of compressor, and if there is a light extension cord used to plug it in, that only makes it worse. Make sure you shut all other breakers off in panel except AC, and try it. If you have water heater on hydro, fridge on hydro, and then try to start AC compressor, you'll be way over the 15 amps, especially if it's a light extension cord.
Keep in mind, in order for fridge to work, you need 12 volts DC (Battery) power going to back of fridge. If the controls aren't lighting up at top, you've most likely got no 12 Volt DC power going to fridge. Check all fuses as well.
Jun 02, 2010 | Dometic Rooftop RV Air Conditioner
GE Fridge - model gss25tgma ww - will not dispense water. Ice
solution part # wr49x10173. door heater. comes with instruction. install in 15 min. good luck.
Jan 19, 2010 | GE GSS25TGMCC / GSS25TGMWW Side by Side...
Diffrence bwetween ac in volts and dc
DC is direct current and AC is alternating current.
eg; 12 volts DC stays 12 volts constantly, positive or negative.
12 volts AC (at 60 Hertz or cycles per second) alternates from positive to negative then back to positive voltage again 60 times per second.
Sep 12, 2009 | GE JVM1790 Convection / Microwave Oven
Water dispenser will come on at random times
are you talking about the lever where you put your glass to get water or the ice compartment if it where you put your glass to get water it could be that if the pressure is not strong enough to close the valve after you have taken a glass of water or a defective solenoid vavle thanks from gilles
Jan 17, 2009 | GE GSS20IEP Side by Side Refrigerator
Water leaking out of freezer door water dispenser
The fill valve that supplies the water may not be shutting off completely. Also check to see that the lever is closing completely.
Apr 04, 2007 | GE GSS20IEP Side by Side Refrigerator
GE GSS20IEP Side by Side Refrigerator Logo
179 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
