Question about Refrigerators
Freezer & Fridge not cooling
Thanks - it is possible that the motor is not working correctly - there is a mild humming sound so I assume it is...
As a brand new fridge it should work without having to add/restart anything, correct?
  • 214 Answers
Yes, you are right!
swich off the fridge for 2 minutes and switch on again. monitor the sound and the load it takes, initially there will be slight jerky sound and vibration as the compressor starts. you can also touch and feel the vibration on the body of the fridge. also humming sound can be of the internal fan which is woking inside the vegitable compartment.
let me know after this
Posted on Jul 10, 2008
My kenmore 253 upright freezer/fridge is not cooling the fridge part correctly. It's cool but not cool enough to keep the food fresh. The freezer works well sometimes. And sometimes it seems that it's not...
Try this test. Set a window fan behind the fridge to constantly blow air across the lower coils at the floor. If the fridge works well after a while of this, then the lower fan on the fridge needs replaced. Sometimes though, after a while, the fan will finally start working again because the cycle has finally corrected itself with the test. Leave the window fan run on low for a few days before removing it. The hum you hear is the compressor moving the coolant and is supposed to do the hum sound. That's good. Now once the fridge is working, and you still have a good freezer section and not cool enough below in the fridge for you, there is a knob that sets the cool lower by opening flaps under the freezer to let more cold down to the fridge area. Set this knob to colder and the flaps will open more.
Nov 11, 2014 | Refrigerators
Fridge/freezer not cooling
check the door switch ok or not
if the door switch not ok replace it if ok ch the cooling cycle
Mar 16, 2014 | Siemens KG34NA13GB
Whirlpool refrigerator not cooling after storm
Assuming that both freezer and refrigerator temperatures have risen and the humming sound that you heard was followed by a sudden click more than likely the start device on the compressor has gone bad. This is a common problem with all Whirlpool refrigerators (KitchenAid is Whirlpools top of the line product and suffers the same problem).
May 11, 2012 | Refrigerators
Both fridge and freezer are turned up to maximum cooling but they just aren't cold enough even though the weather is mild. Icecream is very soft - barely frozen and fridge temp is about 8 degrees...
Sounds like a failure to defrost.
Look on the freezer rear wall inside the freezer for ice bukdup.
If there is ice the defrost components ,must be replaced.
Dec 01, 2010 | Fisher and Paykel Active Smart® E522BR...
Our frig is not cooling but the freezer works fine, it is a hotpoint side by side fri freezer... it made a humming noise for a while but that has stopped.. any help would be appriciated... what the trouble...
In side by sides if the fridge side not working correctly it means that the air vent from the freezing unit has stuck in the closed position which causes the fridge to not be any where near as cool as it should be and if it is too cold then the vent is stuck in the open position. The vent is controlled by a small sync motor and either the motor has become faulty, the control module is faulty or the vent is iced up, which can be caused by putting too many hot items in the fridge so the steam condenses and freezes the vent in position and then the motor cannot open or close it causing it and / or the control module to become faulty. Other times it is just old age that causes the motor and / or the control module to fail. Best call a service engineer asap.
Oct 07, 2009 | Hotpoint Refrigerators
Fridge not working but freezer is working perfectly.It makes the usual humming sound after I switched it off and defrosted it but still the fridge didn't cool down.Any answers would be gratefully received....
try checking your evap fan motor if it is not running you will need to check to see if it is getting power if it is then you will need to replace the motor also check your settings make sure th freezer setting is not set over half way the freezer setting controls the air flow to the ref
Jul 03, 2009 | Hoover HCA391FFK Bottom Freezer...
Maytag MFD2561HES Reefer not cooling
hello frooska,
kindly look at the back panel of the freezer section. if you can hear the humming sound, find out where it is coming from. if the sound is coming from the compressor, that means the evaporator fan is not running.
but, take note that u need to press the door switch of the freezer in order to check the fan. the fan stops every time the door is open. if the fan is not running, you have to remove the middle panel, above the evaporator, the fan would be there. ( in the freezer section)
but if the fan is running and the back panel of the freezer is full of frost, then that would be a defrost issue.
defrost heater, bi-metal or defrost controller.
Tnx 4 uisng Fixya,
Dec 16, 2008 | Maytag MFD2561HE Stainless Steel Bottom...
Trio: humming and temp in freezer rising
It sounds like the condensor fan motor is seizing up. This is the fan that cools the compressor down. Does the outside of the fridge feel excessively hot to touch? Can you feel air being circulated under the fridge or behind the fridge? It could also be a faulty defrost timer. Try to identify where the buzzing is coming from and if it is the condensor fan you can put a normal standing fan behind the fridge, blowing onto the compressor untill the repairman can get to you.
Oct 29, 2007 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Refrigerators Logo
113 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
