Question about Canon DHD860 Copier
Paper curling from excessive heat.
When I make copies, the paper is coming out curled from what feels like excessive heat.
    Sniper:
  • 57 Answers
Paper get curled from excessive dampness in paper. The heat from a copy machine is always the same.
Try fresh paper from a new packet. Do not store paper in Humid areas. Paper not being used for a long time, remove from copy machine and store in it's own packet..
Posted on Jul 10, 2008
Why when printing or copying the paper come out to curved
If paper is damp from humidity etc. curling can occur. Try a fresh pack of paper and experiment which side curls less. Yes, there is a difference between the finish on the two sides of the paper.
Mar 05, 2014 | Brother MFC9340CDW Colour Laser Printer...
It curls all my cardstock!
You will get alittle curl on all prints with this unit, as the paper path is curled ** paper collected from the bottom tray will travel in a semi circle to exit the unit** but if the curl is excessive then it is possible the card stock is just alittle too think for the unit or the card stock is damp, if you are in a humid location its best to store you paper and cards in a dehumidifier box
Feb 09, 2011 | Brother HL-5370DWT Laser Printer
My copies come out curled. Is there an adjustment for that? Brad
Sound more like a paper incompatibility problem. Try another brand of paper, bearing in mind that a laser printer has heating rollers that do tend to put a bit of a curl in the paper.
Jan 25, 2011 | Brother MFC-8860DN All-In-One Laser...
Paper is curling when it comes out of printer
either your using a poor quality paper or the heating element of the printer is malfunctioning.
Sep 17, 2009 | Brother HL 5250DN Laser Printer
Paper curls on 8460 Brother
The following is Brother's take on your problem. All of their solutions have some merit but the one I'm leaning toward is overstuffing of the paper tray. It's common in most offices (and homes for that matter) to have a tendency to stuff the paper tray when it runs out.
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000000618&Sympt=The+faxes+I+receive%2c+copies+I+make%2c+and%2for+documents+I+print+from+my++computer+have+a+curl+or+wave+to+them+when+they+feed+out+of+the+Brother++machine.+What+can+I+do%3f+(paper+curl)&Model=270&ProductGroup=5&Keyword=paper%20curls&ProductID=MFC8460N
Apr 23, 2009 | Office Equipment & Supplies
Paper curl
Paper Curl. Does the paper have a curl on the trail edge? (The last part of the paper to exit the printer)
If it is the entire paper replacement of the fuser will likely resolve this.
If the paper curl is on the trail edge then replacement of the upper delivery roller should be done.
Nov 03, 2008 | HP LaserJet 4 plus Printer
Paper Curling
Your fuser roller temperature may be set too high or if the paper has been sitting for quite some time, you may have moisture built up in the copiter. Usually a service technician can adjust the temperature for you.
Aug 15, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
Paper curling due to condensation
All copiers have thermal fuses that should blow if copier gets too hot,so there's probable nothing wrong with the machine but the paper.When paper gets damp it curls. This is because when the paper feeds through the fuser a combination of heat & pressure dry the paper out causing it to curl!
Jul 13, 2008 | Canon imageCLASS D320 Digital Copier
SHARP AR-507 DIGITAL COPIER
Ckeck the glass on the left side it is about 1inck by 12 inch for white out on it also clean the optics.On your curling problem install fresh paper you can check your fuser temp. in sim 43-1 change it to 180.
Nov 07, 2007 | Sharp AR-507 Copier
Canon DHD860 Copier Logo
293 people viewed this question
old marine
old marine
