Question about Whirlpool Washing Machines
Washer make grinding noise - Whirlpool Washing Machines
    Sergeant:
  • 225 Answers
Hi, Unfortunately this sounds like the drum bearings have failed. Does the drum move around when you try to lift it up and down? Were there greasy spots on your white clothes lately? Any metallic debris in the removable filter? These all point to drum bearing failure.
If these suggestions do help you solve the problem, please give my reply a rating to help others judge my knowledge / guessing skills. If they do not, please delay the rating and add a comment
with more details so I can try to help you further. Cheers, D
Posted on Jul 10, 2008
Grinding noise before spin cycle
Good Morning John,
I see that you are hearing a grinding noise before the spin cycle in your Frigidaire washer, model# GLET1031CS0. A certain amount of "grinding" or gear sounds are normal in a heavy-duty washer. If you notice that the grinding sound appears to be getting louder, I suggest contacting either the manufacturer or your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
Mar 16, 2014 | Frigidaire Washing Machines
Washer makes grinding noise when it agitates
check back of unit as the concrete on the back may of been dislodged check not over loaded also the belt maybe loose or streached
Jan 02, 2014 | Crosley CAWC529JQ Top Load Washer
My washer makes a grinding noise and leaks out the bottom
washer makes a sqeeling noise where fan belt is attatched but only in one direction.could the machine need rebalancing?
Feb 21, 2013 | GE WBSR3140DW Top Load Washer
Washer won't drain. Makes grinding noise
check your water pump. there maybe something in it. If there is you may have to replace the pump
Nov 06, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Whirlpool washer grinding noise when draining
there could be something in your pump.....remove the pump and see if there is not something inside...
Jul 04, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Will not spin and making grinding noise
a grinding noise sound i think it come from ballbearing you can chang by qualified person
Apr 17, 2009 | Whirlpool LSN1000LW Top Load Washer
Kenmore 60 series grinds when spin starts
try taking the pump off the motor and see if the grinding noise stops could be something in your pump or a bad pump
Dec 20, 2008 | Kenmore 24032\24036 Top Load Washer
Grinding noise when washer starts some spin cycles, washer stoped and game my wife a f-33 reading. whirlpool told me to unplug(reset) the washer for 30 mins. i did this and the washer still has the...
hi there,
the grinding noise may be coming from either the pump or you have something caught between the drums.
the f-33 error is the pump drive system error. it indicates that you have lost communication between the CCU board and the pump. the CCU board is the main control board that you see in the front of your washer.
i would recommend that you call a technician to check it out, as you will have to do some checks that require technical knowledge.
Oct 11, 2008 | Whirlpool Washing Machines
Noise in wash cycle
This is normal, because your washer will make sounds that you may not have heard from other washer.
Jun 07, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
100 people viewed this question
Dan Webster
Dan Webster
Sal De
