Question about Vizio L32 32 in. LCD HDTV
How to fix my paint on vizio tv
I need help on what to use to fix the paint on my vizio tv. I was cleaning the tv screen with film cleaner and i accidently sprayed some on the frame. Now the cleaner ate away at the paint, and it looks like a bunch of scratch marks. So if you can help me out with what product I could use to repair it back again, that you help me out a lot. Thanks!
    Sergeant:
  • 280 Answers
This may sound dumb but it has worked for me at times.. USE BLACK shoe polish the kind that comes in the little round can. Don't try to touch it up with paint because some paints eat plastic.
Posted on Jul 10, 2008
How do I take off and clean inside of 32"vizio lcd led tv screen?
I have a Vizio 32 inch HDTV . You will have to place it on a flat surface and take all of the back screws off then pull the ( the back cover) backing of the TV. then is what i did was take it to a low pressure air (for tires) then held it away from the electronics in the back of tv and blew it out . then take it home and put it back together then use a cleaner and a non-abrasive rag for your screen
That got rid of those nasty dust bunnies and i am still using that tv as my monitor . ( I hope that helps you out )
Oct 05, 2014 | Vizio Televison & Video
The flat screen tv was sprayed with paint right across the screen we need to know if there a way to get it off.....my email address is chiefgabriel@hotmail.com
buy a solvent called paint thinner from paint selling shops .............. using this paint thinner easily paint on your tv screen can be removed without any damage to screen .......remove tv powercord from power socket ......take thinner in small cup ...... take a small piece of soft clothe ..... dip in that cup such that soft clothe becomes just wet ....then slowly clean that particular place where paint is there .....same time keep another soft dry clothe in your other hand ......while cleaning with thinner paint on screen becomes thin then immediately clean it with other clothe..........remember while cleaning thinner's drops should not fall down & go inside tv through edges of screen ....... since this thinner smells like a paint after cleaning tv screen will have paint like smell ..............so again you have to repeat above steps but this time you have use soap water or any ordinary cleaning solution ....................................... click below shown link for images of thinner..... http://www.google.co.in/search?hl=en&q=paint%20thinner&rlz=1R2SUNC_enIN399&gs_sm=e&gs_upl=0l0l0l156l0l0l0l0l0l0l0l0ll0l0&bav=on.2,or.r_gc.r_pw.&biw=1024&bih=418&wrapid=tlif131594078475010&um=1&ie=UTF-8&tbm=isch&source=og&sa=N&tab=wi
Sep 13, 2011 | Samsung Televison & Video
No problems. I just cannot find the instruction manual (can you send me one) and what is the best way to clean the screen?
http://www.vizio.com/m221nv.html
That's VIZIO's page for the manual. There are many good screen cleaners available and are sold at just about any electronics store. Usually 15-20. and all are about the same. Hope this helps.
Jul 07, 2011 | Vizio M221NV 22 in. HDTV LCD TV
How do I fix a fuzzy picture on my Philips 53" Widescreen Projection HDTV
A fuzzy picture could be almost anything. You may have to dust the three picture tubes. Use a soft paint brush first and then use a LCD cloth wipe to clean. You can find these clothwipes at any super discount store. And you may dust the inside of the screen itself. Try to dust the screen inside without removing it...removing it, will be almost impossible to reinstall! . Donot clean the mirror inside this TV..as it is a thin piece of film..If you must clean use a new feather duster and be gentle, do not use a cleaner! If this does not clear up the picture..you may have a contaminated picture tube..these are not easy to flushout and replace. And yet there may be a small signal module that may need replaced! This is the board that contains all your RCA jacks and RF connections! Hope this will help. Thanks for asking!
Aug 20, 2010 | Philips 51PW9303 51" Rear Projection...
How do i clean my vizio tv without damaging it?
There is a screen cleaner you can buy at any store like the source, future shop , best buy that sells it, it is called monster screen cleaner it is a bit expensive but will not damage your tv screen
Apr 08, 2010 | Vizio L32 32 in. LCD HDTV
The picture on my Vizio 42" flat screen suddenly shifted to a whitish pale color with ghostly looking images that look like negative film.
This is the fix for the Main board repair :
Locate IC 32 small 8 pin surface mount near top of Main Board and remove. Short pin 2 to pin 5. (pin 5 through 8 are together and pin 2 and 4 are together)
You will need a good TV Tech to do this for you.
Aug 04, 2009 | Vizio VO42L 42 in. LCD TV
Replacement lamp not bright
as i previously posted, my picture was dim, muddy looking after replacing lamp with osram lamp. i fixed mine by taking the screen off and cleaning the small mirror. it had a thick layer of dust on it, cleaned with a microfiber cloth. no water, no glass cleaners. i also used a very fine new small paint brush and dusted the projector lens which also had a dust film. brightness, contrast and clarity returned!
Mar 05, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Cleaner
Pretty sure you aren't supposed to use any chemical cleaner. I just use one of those pieces of fabric you are supposed to clean your glasses with and it has served me and my VIZIO XVT very nicely! But don't wipe to much because you can damage the pixels and screen. Gently. Hope that helps
Oct 24, 2008 | Vizio L37 Television
Vizio tv clean screen
HI sam one have Screen of this TV ? VIZIO screen
MODEL NO VIZIOVX32L
HDTV 10A 100-240V-1.5A 60/50HZ
SERIAL NO LSSABBH 1919067
MFG. DATE MY 2007
MY TV SCREEN IS BROKING SO LOLES HALP ME !
MY MAIL IS YOUSAFTAREEN818@GMAIL.COM
OR YOU CAN CALL ME AT 818-744-3794
I AM FROM U.S.A CA ZIP COD IS 91601 I NEED SCREEN FOR THIS TV ......>>>1c26157.jpg
Jan 12, 2008 | Vizio L37 Television
Cleaning Scratches on TV screen
there is an antiglare film on the tube. the only way to fix this is to replace the crt itself, but this cast more than the tv. i would find a strong cleaner and rub off as much as you can. it is possible i have done this myself.
Nov 04, 2007 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Vizio L32 32 in. LCD HDTV Logo
221 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
