Question about Kenmore 24032\24036 Top Load Washer
Washing machine is not rinsing and spinning
The tub fills with water, then agitates, but it isn't emptying and rinsing....so now i have a washing machine full of dirty water. Help.
  • Anonymous Jul 14, 2008
    Dirty Water. Have issue with Kenmore Series 60 not rinsing and spinning problem. Agitator works through wash cycle but leaves tub full of dirty water. Please assist.
    Genius:
  • 1,122 Answers
LID SWTICH BAD,THANKS-MIKE
Posted on Jul 23, 2008
Roper washing machine does not fill for rinse cycle. Goes directly to rinse agitate without water.
Without Model number I am only guessing but I suspect you have a blocked sensing tube that travels from the Level selector switch to the side of the tub somewhere. It is possible for this plastic tube to become partially clogged and not allow trapped air to vent when tub is drained of water. Usually this problem manifests itself as an overflow of the tub. Check the full length of this clear hose and see if the end nearest the tub looks like it may have debris or dirty detergent clogging it.
This hose is pushed onto a nipple mounted to a reservoir on the side of the tub. Push a thin copper wire 4-5 inches into the those after removing from nipple and also down into the nipple an inch or two before reinstalling the hose to the nipple. You MIGHT even blow into the hose while you have it off and you SHOULD hear a clicking sound coming from the level selector switch body.
Good Luck. Come back with Model number under lid if that doesn't help.
Nov 28, 2015 | Roper Washing Machines
Whirlpool washer model lsr8233eqo
So when the cycle first starts, it will fill and agitate and spin. But then on the rinse cycle it stops?
Feb 03, 2013 | Whirlpool Washing Machines
Frigidaire FWT647GHSO when it gets to rinse first rinse cycle, it doesn't stop filling with water. It won't agitate or spin. It works well in the wash cycle, agitates and spins and advances
probably you've got something blocking the water pump from doing its job properly so check that the water pump is free running emptying all the water if not then there is a blockage in the pump normally ist a button, paper clip or other debris out of a trouser pocket eric
Dec 25, 2017 | Frigidaire Washing Machines
Washer is getting stuck at rinse cycle-
sorry to keep asking questions but i just need to know a little more information. are you using auto fill? have you tried manual water level settings? is your machine the one with the LCD DISPLAY?when it stops at rinse, is it agitating? if you have the LCD display have you tried the- traditional wash mode? please reply 4 further help.
May 21, 2010 | Fisher and Paykel GWL11 Top Load Washer
My washing machine is stuck on agitate. It filled and agitated then stopped. I can set it to spin only and it will spin and empty the tub, but for a regular wash cycle it starts on agitate and stops...
You may have broken teeth on the gears in the timer assembly. Do you have a habit of "whipping" the timer around? In other words, turning the timer fast.
Dec 14, 2009 | GE Washing Machines
Does washer drain before the spin cycle starts?
Normally yes. There are around 12 to 20 gallons of water in the tub after the wash cycle, which will be anywhere from 63 to 110 pounds of weight in addition to the weight of the clothes. For the machine to start the spin cycle to remove this water would place a heavy load on the motor, gearcase, pullys, belts, gears, ect. With the water drained, the load is lighter, and much easier to start spinning the excess water out of the clothes. The normal cycles are: Fill, Agitate, Drain, Spin, Rinse Fill, Agitate for rinse, Drain, Spin Cycle and off. Imagine trying to spin a 5 gallon bucket of water over your head, full of water, and then empty. Which one do you think would be easier to do? And safer for you.
Sep 26, 2009 | Admiral AW22 Top Load Washer
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
I have a whirlpool model LSR 8233JQ0 washing machine. The tub will fill and agitate but will not empty out or spin. I replace the lid switch without success. The machine makes a sort of ticking sound...
you say it wont drain the water??? if it fills, agitates , and doesnt advance past the first rinse cycle, it does sound like a lid switch issue, can you hear the switch "clicking" when the door is just about closed??? if not then its not recognizing the door and wont advance for safety reasons.and when you replaced the switch were you sure to remember ot replug the harness before reassmbleing the unit
Mar 25, 2008 | Washing Machines
Washer go though all cycles but no spin
the motor operates off the timer cams inside the timer. in the wash mode the agitator turns in one direction. when it calls for tub empty the motor reverses direction and actuates the pump. at this stage the tub should spin. sounds like the timer is bad for this one function. timers cost around $120. (mechanical timers)
Aug 22, 2007 | Frigidaire ATF6000ES Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
220 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
