Question about Vacuums
Merlin Automatic Inground Pool cleaner (onboard bag, no hoses)is no longer picking up debris. Bag is clean, it still moves across pool all seems as it should be -- EXCEPT he's not picking up the dirt!?
The belts need to be replaced
Posted on Jul 28, 2008
Why is the vacuumed debris skipping the bag and landing straight in the canister?
damage to the hose end or the rubber on the bag isnt lining up with the hose end,,,in backwards?????????
May 08, 2015 | Miele S8390 Calima Canister Vacuum Cleaner...
Does not pick up at all there is no suction
Check that the hose is not blocked. Also check the dust channel air ways (see the orange trapdoor on the underside and push your fingers through to see if there are any debris blocking the suction.). Also check that the filter on board is clean - if it is completely dirty it needs replacing as well as the dust bag.
Nov 21, 2013 | Sebo Automatic X1 Bagged Upright Vacuum
My Miele S3141 canister began acting strange this morning. No I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 | Vacuums
Model UH60010, Series X12.0, Mfg code K09A. While attempting to use the hose and the extensions to clean shelves, my wife reported no suction. I removed the brush roller and the plastic piece just below...
There are six different reasons a vacuum can lose suction, a plugged vacuum hose, bad motor, full vacuum bag, or cracked or damage hoses. Purchasing a vacuum cleaner can be a costly expense while repairing the suction on the unit can be virtually free. Most suction loss problems on a vacuum can be easily fixed or remedied with common house hold tools and very little technical expertise.
If your vacuum cleaner losses suction, the first and easiest solution is to check the bag. If the vacuum cleaner bag is full suction will be greatly reduced and the unit will become ineffective. A vacuum cleaner works by passing air through the bag fibers leaving dirt and debris behind inside the bag. If the refuse bag becomes full, airflow is restricted, limiting the amount of air passing through the vacuum bag resulting in loss of suction. When replacing the vacuum bag always consult your owners manual to insure that the vacuum bag seals with the vacuum inlet hose. If your vacuum cleaner bag is not tightly sealed to the vacuum inlet hose you will decrease the air flow through the bag resulting in loss of suction.
The second and sometimes most common reason for loss of suction on a vacuum cleaner is a plugged vacuum hose. If the hose becomes plugged, air flow will become restricted. To unplug a vacuum hose detach it from the machine and inspect the inside. If there is a restriction in the hose, remove it with your fingers and replace the hose onto the unit. If the hose is long and the debris is hard to get too, a broom handle or other long object can be passed through the hose to dislodge the debris. Most vacuum cleaners contain more that one suction hose, so make sure to check each one by process of elimination. Another area that can become easily plugged on a vacuum cleaner is under the lower base of the unit by the roller brush. Large debris can get caught in this area and restrict air flow to the hose.
If your vacuum refuse bag is not full and the suction hoses are not plugged the next thing to check is the condition of the hoses. Many hoses are made from plastic which can easily tear or crack. If your vacuum cleaner shows signs of wear or are cracked they need to be replaced. Even the smallest hole in a vacuum hose can leak enough air to greatly diminish the suction potential of your unit. Replace your vacuum cleaner parts with OEM parts from the original manufacturer to ensure the tightest fit.
Most vacuum cleaners contain filters. Filters are used as a last line of defense to remove dust and smaller debris particles before the air is recycled back into the environment. If vacuum cleaner filters become dirty or plugged they also can decrease the amount of air traveling through the unit. Some filters can be easily rinsed with water whereas others need to be replaced. It is important to check your owners manual before rinsing a vacuum filter.
The last and probably least common problem for a vacuum cleaner to loose suction is a bad or failing vacuum motor. Over time vacuum motors lose power due to worn carbon brushes or long term damage. A vacuum cleaners worst enemy is moisture. If water or moisture is sucked into the vacuum motor it will greatly diminish the amount of suction the unit has. Replacing a vac motor can be a costly and time consuming ordeal. In some cases, replacing a vacuum motor can outweigh the cost of buying a new vacuum. Vacuum suction is measured in water lift which can easily be measured by using a water lift gauge. If the water lift measured in inches, falls below half the original water lift specifications for the unit, it is time to replace your motor. Most vacuum cleaner repair shops carry this type of equipment and can easily tell you if it is time for a new vac motor.
Jul 25, 2010 | Vacuums
I received my dirt devil canister vacuum - vision pet for Christmas and have only used it several times. I am having trouble with it not suctioning very well. I have the max suctioning turned all the way...
Change out the bag. Check the internal air passages for blockage. Check air flow without the bag and pick--up hose in place--should be quite forceful. Attach the bag and try again. If ok, attach the hose and try again. At some point, you should find a large blockage of debris. Hope that helps!
Feb 20, 2010 | Vacuums
Doesnt ****
If the vacuum sounds like it usually does and still doesn’t pick up, you probably need to replace the belt. To check this, turn the vacuum on and lay it down sideways. Check to see if the roller is spinning. If it's spinning, turn the vacuum off. Stand it up and turn it back on. Do you hear the roller spinning. Some belts stretch over time. If the roller was spinning when the vacuum was on it’s side and stops when the roller has some pressure on it (your carpet), change the belt.
A clogged vacuum cleaner usually sounds "clogged". The noise the vacuum normally makes will seem muffled. First, Unplug Your Vacuum. Then change the vacuum bag or empty the dirt cup. If the bag is filled up more than halfway, this could reduce your suction. Throw out the bag. Look at the area that holds the dirt cup or vacuum bag. Remove any debris. Look for a filter in this area. If you find a filter make sure it's relatively clean. A clogged filter will shorten the life span of your vacuum. Make sure your filter is back in place or replaced, and reinstall the vacuum bag or dirt cup.
A lot of the current style upright vacuum cleaners have attachments and a hose on board. If you have a vacuum hose on your upright, pull it out like your going to vacuum with it. Look at the area you removed the hose from. Remove any debris. I recommend wearing gloves, and try not to use any sharp tools like a needle nose pliers that might puncture your vacuum hose.
For the final step in this vacuum cleaner repair, place the vacuum in a position where you have a birds eye view of the bottom plate. You can usually see if there is any debris that requires removal.
Here is a link that will take you to a site that shows how to access your machine to change belt or look for clogs.
Hope this helps
Jan 30, 2010 | Hoover U6311-930 Power Drive Bagged...
My Electrolux Upright vacuum cleaner will not suction. Motor will run to turn roller, though.
sounds like the hose is clogged.take off bag and look in the hose.or you may need a new bag
Oct 19, 2009 | Vacuums
Cleaner is not picking up debris from pool bottom
Have you check the filter/baskets to make sure that you don't have a large piece of debris that is preventing suctions? You will also want to check each section on the vaccum systematically to make sure that there are not cracks or noticable areas of damage that would prevent the pool cleaner from working. Is is not moving at all or just not sucking properly? Can you give me more details as to what it, exactly, it is doing?
Apr 19, 2009 | Dirt Devil Rampage Robotic Pool Cleaner...
Vacuums Logo
321 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
