Question about Danby Refrigerators
Danby dim1524w ice machine -pin on the shovel snapped off---I ordered and have received a replacement part-how do I install it? No directions and the original user manual has no help
4 Suggested Answers
  • 9 Answers
SOURCE: Continental electric ice maker CE-IE65151. The
Look at the far ends of the shovel near the attachment hinges. There should be a little plastic tab near the pin on each end and on each hinge. They commonly break off. This is made by e_wave and their model is MCIM30TS. Order parts from Repair Clinic.com
Posted on Jul 21, 2009
  • 9 Answers
SOURCE: Good Morning - I need to order a Ice Shovel Part
It's actually made by Magic Chef model MCIM30TS. Get parts directly from MagicChef www.mcappliance.com or www.repairclinic.com
Posted on Jul 22, 2009
tunde007
  • 2382 Answers
SOURCE: I need a contact to
Hi, you can order for parts at Repairclinic.com
Posted on Nov 21, 2010
Machine only makes ice cubes on a few coils
Without knowing the type of ice maker you have there could be several causes for this. Low charge, metering device problem, make up water constant fill or to warm. Need more info to help.
Jan 08, 2013 | Danby DIM1524W Ice N Easy Portable Ice...
Danby ice maker service manual
I took mine apart today and found the plastic armature that the motor connects to in order to turn the water tray right side up and up-side down was broken. Essentually the water tray has a plastic pivot arm on both sides. The one side has a slot that the motor fits into which allows the motor to turn the tray. When that little plastic arm breaks, the motor will be unable to move the tray thus causing the fault symbol. I have my tray out and trying to fabricate a part that will hopefully last a lot longer than the original. I hope this helps someone with their issue.
May 16, 2012 | Refrigerators
Need to download manuel
Hi randychaisso...
Go the following webpage answer a couple of questions and download your user manual for your user manual.
Please take time to rate me
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Sep 09, 2011 | Danby DIM1524W Designer Portable Ice Maker
I need to order aice shovel for my magic chef tabletop icemaker model #MCIM30TW
try this page - I have a similar model (MCIM30TS) - however, I can't figure out how to remove the pins to remove and replace the ice shovel...any ideas?
http://www.repairclinic.com/Shop-For-Parts?searchText=mcim30ts&Search=Find%20Parts
In case the link does not work properly, just go to the repairclinic.com website and enter your model number in the search box...
hope this helps
- Margaret
Sep 15, 2010 | Eastern Tabletop 7002 Stainless Steel 24...
Need Replacement Parts!!!!!
You can go to the sears web site and get it it should be under warrenty or you cna go to http://www.appliancepartspros.com and call and ask them they can give you where to locte it nearest to you and the list price for it. Hope this helps.
Dec 28, 2009 | Kitchen Appliances - Others
Jul 14, 2009 | Continental PortableCE-IM65151 Ice Maker...
Magic chef MCIM30TS table top ice maker shovel breaks
I took 4 small nails, cut them to the proper length, heated them up with a lighter, and pushed them into the plastic creating 4 metal posts that the motor could push against. Just did it and it is working. Not sure for how long.
Nov 21, 2008 | Eastern Tabletop 7002 Stainless Steel 24...
Refrigerators Logo
61 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
