Question about Lexmark X2350 All-In-One InkJet Printer
Lexmark 2300 How do I remove and replace print cartridge?
  • 1 more comment
  • Anonymous Jul 26, 2008
    lexmark 2330 cartridge error when replacing ink cartridge
  • Anonymous Aug 12, 2008
    how do i change the cartiridge
    x2350
  • Anonymous Nov 28, 2008
    When I open the Scanner the cartridge container won't move. It stays on the side. So I am unable to reach the cartridge.
    Help?
  • 876 Answers
Go to www.lexmark.com and then click on Support>technical support>publications
There you will be able to find a set up guide for your printer. I believe it is in Pdf format, so you may need to download the free program Acrobat Reader at www.adobe.com/acrobat in order to read the publication. check it out and good luck!
Posted on Aug 18, 2008
5 Suggested Answers
Corysf62
  • 188 Answers
SOURCE: lexmark 2300 i
99% of the time, the cartridge is defective. Try another cartridge, even if the one giving you the error is new. If the other cartridge works, then return the new one to the manufacturer as defective.
Posted on Sep 28, 2008
SOURCE: Lexmark 2300 Printer/Scanner
Beat the **** out of it.
Posted on Dec 08, 2008
  • 41 Answers
SOURCE: missing stickeron cartridge
The Lexmark 2300 series should take the following cartridges:
Lexmark 12A1970 (Black)
Lexmark 12A1980 (Color)
Let me know if that helps!
Posted on Mar 24, 2009
  • 55 Answers
SOURCE: can't replace ink cartridge; can't acess old one
The following link has the setup instructions for the printer, hopefully they will help.
http://www.lexmark.com/publications/pdfs/2007/2300/setup-sheet.pdf
Posted on Apr 27, 2009
HP LASER JET 2300 52.00 ERROR
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
4. Replace the engine board.
Tallon41
Sep 12, 2012 | HP LaserJet 2300 Printer
When i try to print on my Lexmark 2300 it keeps saying scanner unit is open, but it isn't. I've turned it off and on opened and closed the unit but this hasn't helped
It could be the cartridges in the carrier. Please follow the steps below to identify and fix the problem:
1. Make sure the printer is on.
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
3. Remove both cartridges from the carrier.
4. Close the printer cover.
5. Unplug and re-plug the printer into the power outlet to reset it.
6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge. You may also try to insert a different known working cartridge to determine if the cartridge you are currently using is faulty.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 15, 2011 | Lexmark Z2300 InkJet Printer
MY LEXMARK 4505 LEAVES 3-4 BLACK BLOTCHES ON THE EDGE OF EACH PAPER IT PRINTS, TRIED CLEANING THE ROLLERS TO NO AVAIL, ANY SUGESTIONS
ADJUST THE COLOR AND PRINT SPEED You may need to adjust the color and print speed. CHECK THE LEVEL OF INK IN THE PRINT CARTRIDGES 1 From the Finder desktop, double-click the Lexmark X5400 Series folder. 2 Double-click the Lexmark X5400 Series Utility icon. 3 From the Maintenance tab, check the ink levels of the cartridges. If an exclamation point (!) appears on a cartridge, the ink level is low. Install a new cartridge. Improving print quality These are possible solutions. Try one or more of the following: CHECK PAPER • Use the appropriate paper for the document. If you are printing photos or other high-quality images, for best results use Lexmark Photo Paper or Lexmark PerfectFinish Photo Paper. Do not use Lexmark Premium Photo Paper. Your print cartridges are not compatible with this type of paper. • Use a paper that is a heavier weight or bright white. CHECK PRINT CARTRIDGES If the document still does not have the print quality you want, follow these steps: 1 Align the print cartridges. For more information, see "Aligning print cartridges" on page. If print quality has not improved, continue to step 2. 2 Clean the print cartridge nozzles. For more information, see "Cleaning the print cartridge nozzles" . If print quality has not improved, continue to step 3. 3 Remove and reinsert the print cartridges. For more information, see "Removing a used print cartridge" on and "Installing print cartridges" . If print quality has not improved, continue to step 4. 4 Wipe the print nozzles and contacts. For more information, see "Wiping the print cartridge nozzles and contacts". If print quality is still not satisfactory, replace the print cartridges. For more information, see "Ordering print cartridges". CHECK PRINT CARTRIDGES If the document still does not have the print quality you want, follow these steps: 1 Align the print cartridges. For more information, see "Aligning print cartridges" on page 124. If print quality has not improved, continue to step 2. 2 Clean the print cartridge nozzles. For more information, see "Cleaning the print cartridge nozzles" . If print quality has not improved, continue to step 3. 3 Remove and reinsert the print cartridges. For more information, see "Removing a used print cartridge" and "Installing print cartridges" If print quality has not improved, continue to step 4. 4 Wipe the print nozzles and contacts. For more information, see "Wiping the print cartridge nozzles and contacts"
Nov 10, 2010 | Lexmark X5495 All-in-One &USB...
Put new ink cartridge into my Lexmark 2300 and now it won't print
Make sure you remove the print head protective tape. Also try doing a head cleaning and cartridge alignment page. If it still does not print check the cartridge well, you will see a assortment of copper pint that contact the circuit tracing on the print head, with the printer off get some achohol and a Q-tip and clean the pins there may be ink residue on them.
May 25, 2010 | Office Equipment & Supplies
Just installed a new Lexmark 2300 series ink cartridge, printer
Hello Jeanete. First off, lets make sure that you have the right cartridge model number for your Lexmark Z-2300. Your printer cartridge number should be (Number 31 for black and white). 2nd, make sure that the clear plastic tab has been removed from where the ink comes out of your cartridge to strike the paper. 3nd, make sure that you have it installed properly. This shouldn't be needed, but once you have did everything reboot PC to see if this helps...
May 17, 2009 | Computers & Internet
Can't replace ink cartridge; can't acess old one
Apr 27, 2009 | Office Equipment & Supplies
Missing stickeron cartridge
Mar 24, 2009 | Lexmark X2350 All-In-One InkJet Printer
Lexmark 2300 all in one not scanning
I had this same problem.
For some reason when the printer installs, the scanner is disabled.
You will need to be on a user with administrative rights to complete this fix.
Also be sure you have downloaded and istalled the latest drivers from Lexmarks site.
  • Right click my computer.
  • Select manage from the dropdown menu.
  • Press continue if a UAC popup comes up.
  • In the left pane click Device Manager.
  • From the list of devices, expand "Imaging devices".
  • Right click on the lexmark xxxx-xxxx series.
  • Select enable.
Windows should automatically find the driver you installed and the scanner should would without a hitch now.
Hope this helps ya!
Sep 25, 2006 | Lexmark X2350 All-In-One InkJet Printer
Lexmark X2350 All-In-One InkJet Printer Logo
316 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
