Question about Hotpoint Washing Machines
My hotpoint wf440 makes a very loud banging noise when on spin. could you tell me the problem please and how i could fix it? thanks
  • 225 Answers
Does it do this with no clothes in - or only when loaded? It could be that one or more of the springs or gas struts has come off, or broken. The springs are usually visible under the top cover, and the gas struts - they look like car shock absorbers - are usually visible down at floor level.
How to fix it depends on what you find, so please let me know before doing the rating bit :-)
If these suggestions do help you solve the problem, please give my reply a rating to help others judge my knowledge / guessing skills. If they do not, please delay the rating and add a comment
with more details so I can try to help you further. Cheers, D
Posted on Jul 10, 2008
Hotpoint 1100 banging very loud when spinning,can thi be repaired please?
the chances are its the bairings in the drum that have gone,can you move the drum towards and away from the door easily? if so its prob the bairns,just like on a bike wheel they make the drum spin free but if they break it wobbles out of true causing problems and loud noise
Mar 19, 2013 | Hotpoint Washing Machines
Hotpoint wf240 - jumps around when spinning laundry - the problem seems to be the drum turns too fast before the spin so the laundry is balled up before the spin - has anyone any ideas on how to fix...
Ensure that your machine is on a level surface with equal weight on the four legs. There are adjustable feet on these machines so as to balance the load on each support. These supports are adjustable by twisting them clockwise/anti-clockwise to get the correct balance.
Jan 05, 2011 | Hotpoint Washing Machines
Hotpoint wf740 aquarius 1400 v noisy banging during spin = dust
It could be a broken drum restraint spring, or a worn or broken. or loose shock absorber.
To check the springs, remove the top cover, and you will see the springs.
Another possibility is the concrete weight could be broken or loose.
You need to remove the lower rear panel of washer to check the shockers and concrete weight.
Please rate my solution.
Jan 31, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Need to replace the bottom weight on a hotpoint wt965 washing machine. When on full spin it makes an extremely loud banging noise and then the other night a piece of concrete fell off.
The concrete balance wieghts are replaceable, but you need to make sure the fixing points on the drum are o/k, as sometimes they fracture or wear, and if this the case, then you will have to replace the outer drum.
Please rate my comments.
Nov 03, 2009 | Washing Machines
Hi,i have a hotpoint aquarius wf340.which makes a very loud banging noise every time it spins,it works fine otherwise!
I had the same issue with a similar machine. Need to replace the spindle assembly (or otherwise make sure) that the belt is tight. Try replacing belt first.
Make sure machine is level. test it by putting some stuffed sockes in the machine, let them get thrown around. Listen for the banging noise, apart from the soft socks hitting the tumbler.
Aug 08, 2009 | Hotpoint Washing Machines
Loud banging
Several possibilities for noise. check concrete balance wieghts at top and bottom of washer, make sure they are not loose.
Check drum restraint spring(s) are not broken.
Check suspension legs for wear.
Check for loose motor fixings.
Finally, remove drum belt, and spin drum by hand, tjhere should be noise from bearings, if it feels rough or is rumbling , then main bearings have failed.
Jul 27, 2009 | Hotpoint Aquarius WD63 Front Load...
Drum will not move
Try to remove drum belt, and then turn drum by hand, if it does not turn , then you have either siezed drum bearigs, or some thing jammed between the inner and outer drum
If drum turns freely, then check motor to see if it is free to turn.
Jul 24, 2009 | Hotpoint Aquarius WD63 Front Load...
Loud banging noise when machine goes into spin mode. sounds like it is banging on the side. Please help !
Usually this is an out-of-balance condition caused by too much weight on one side of the tub, move the clothes around and try again.
Apr 26, 2009 | Washing Machines
I have a Hotpoint WF440 washing machine which makes a loud noise when washing, and an even louder noise when spinning. Sounds like bearing trouble. Any ideas, please?
this definatley bearing trouble. its one where you can fix yourself ONLY if your willing to take up the whole day doing it..
The problem with bearings is that once you get to them, it can be tricky taking them out of the shaft because they can crack and leave the outer shell of the bearing in the machine.
if you wanna try it your self then i have a similar solution you can use posted for a wma. the only thing diffrence is that its easier than the wma..
cheer washdoctor
just let me know if you need help
Aug 24, 2008 | Washing Machines
Washing Machines Logo
73 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
