Question about Minolta magicolor 2400W Laser Printer
How to remove the toner cartridges
I see the cartridge I need to remove but how do I do it?
It doesn't seem to be any way to pull it out
HELP - trying to replace the Cyan but pretty soon all including black
will need to be replaced.
    New Friend:
  • 16 Answers
Close the cover to the machine and make sure you aren't getting any other error messages other than the toner. When the printer is at the ready state press the rotate toner button. You should hear the printer rotate the toner and then the light over the cyan cartridge will come on. Keep pressing the rotate toner button until you get to the color you want to replace. Open the top cover and front door where the KM logo is. You should see the cyan cartridge in place. Pull the cyan tab back toward you. The front part of the toner should release. Now pull the tab and the toner straight up and out of the printer. If you are having problems getting the toner out it is probably not in the correct position. There is a slot on either side of the printer that he back end of the toner cartridge needs to be in before the toner will come out.
Posted on Jul 17, 2008
Where is the rotate toner buttom on my machine it does not have one on the top of the machine
Posted on Aug 20, 2008
Canon lbp7660cdn
Carol, Did you remove the sealing tape? There should be a small orange tab on the left side of the toner. Its integrated with the toner cartridge and easy to miss. Flip that tab over and pull. It will pull out the protective tape.
Aug 05, 2014 | Canon Imageclass Lbp7660cdn Laser Printer...
How to replace toner cartridge
-Open the front cover
-pull the old toner cartridge out.
-Remove the new toner cartridge from its bag
-Thoroughly shake the cartridge 5 or 6 times to distribute the toner evenly inside the cartridge.
-Thoroughly shake the cartridge to assure maximum copies per cartridge.
-Remove the paper protecting the toner cartridge by pulling the packing tape.
-Hold the toner cartridge by the handle and slowly insert the cartridge into the opening in the printer.
-Tabs on the sides of the cartridge and corresponding grooves within the printer will guide the cartridge into the correct position until it locks into place completely.
-close the front cover.Make sure that the cover is securely closed.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Dec 13, 2012 | Samsung SCX-6320F All-In-One Laser Printer
HP P4014n LaserJet Printer Close top cover won't close
the most common problem that causes the top cover not to close is the toner cartridge not being seated. Pull it out and reseat it.
Why did you open the cover in the 1st place. If it was to install a new cartridge, try putting the old one back in. If it works, the replacement has a problem.
If the cover doesn't close with the toner cartridge removed, then there probably is a linkage problem. Something may be broken, like the "print cartridge drive arm".
Go out to www.hp.com.
Oct 10, 2011 | HP LaserJet P4014n Printer
Printing blank pages
First step : Try to pull-out toner cartridge then shake it and insert again test print. if same problem appear.
Second step : change new toner cartridge.
third step : Try to contact HP service center.
http://www.hp.com
Jun 03, 2011 | HP LaserJet P2015 Printer
Where are the cartridges located to install new ones?
http://software.canon-europe.com/products/0010476.asp
try to download the manual from the above link and check there.
Howver you can also check it on the lid. instructions are given. This should be very easy as we need to pull out the tray and replace the cartridge. signs and signals are given on the printer itself.
Apr 29, 2011 | Canon iR 2022i Printer
How to remove the cartridge on Brother HP1440 printer
Hi seevram,
Follow the procedure below to remove and replace toner cartridges for your Brother HP1440 printer:
1. First, open the Front Cover of the printer.
2. Remove the Toner Cartridge(s) that has run out of toner. Pull the Toner Cartridge out slightly with one hand, then hold the Toner Cartridge with both hands and pull it out of the printer.
3.
After rocking each new Toner Cartridge 3 to 4 times from side to side, remove the tape labeled 'REMOVE' and the orange protective cover from the new Toner Cartridge.
4. Then,
insert the new Toner Cartridge(s) by positioning it in the correct guide(s). Slide it gently into the printer.
Reminder:
  • Do not try to lock or push it in; it should rest loosely in the guide rails.
  • Each color cartridge is individually keyed to prevent improper installation. Match each cartridge color label to the corresponding label on the printer.
5. Finally, close the Front Cover.
Also, I have included here a link where you can download a service manual for your Brother HP1440. Kindly click here.
Hope it helps.
Thank you for using Fixya.
Feb 16, 2011 | Brother HL 1440 Laser Printer
I wish to replace the black toner cartridge in the Dell 3010cn. How do I gain access to it. There is easy access to the cyan cartridge at the moment
if you want to replace black one only you should follow these steps Install or replace the toner cartridge while the printer is on (if the power is not on, the cartridge carrier does not rotate).
1. After confirming the Insert Yellow Toner(Y) message, open the front door.
2. Hold the tape on the protective cover and pull it forward to remove the cover from each cartridge slot.
NOTE: You need to remove the protective cover only the first time that you install the toner.
NOTE: Dispose of the protective cover after you remove it.
NOTE: The protective cover is attached to each toner cartridge mount.
3. Make sure the color of the toner cartridge matches the slot on the toner cartridge carrier. The order is Y, M, C, K. Gently shake the cartridge to distribute the toner evenly.
4. Lift the tab up 90 degrees and pull the toner seal straight off, keeping it parallel with the toner cartridge.
5. To insert the toner cartridges, align the arrows on the cartridge with the corresponding arrows on the printer. Guide the cartridge in until it snaps into place and then push down the handhold to lock the cartridge in place.
6. Close the front door.
NOTE: Make sure the toner cartridge is installed correctly. Otherwise, the front door cannot close firmly.
7. The toner cartridge carrier rotates to the next empty slot. When the color of the newly inserted cartridge appears on the display, followed by the Insert message, insert the next toner cartridge.
8. Repeat steps 1 through 7 when inserting the remaining cartridges.
plz do rate the solution if got help
Nov 25, 2010 | Dell 3010cn Laser Printer
I have followed the instructions exactly for replacing the black toner cartridge on my Magicolor 2300 DL, but i still have the error message "Replace Toner Black." I tried taking out the cartridge and...
If you have changed the toner cartridge, the printer must complete a calibration cycle (up to 150 seconds). If you open the door before the Ready indicator on the control panel lights up and the Error indicator turns off, the printer stops and repeats the calibration cycle.
1. Open the Status Display (double-click on Status Display icon in the system tray on the lower right-hand portion of the task bar, OR click Start/Programs/KONICA MINOLTA magicolor 2300W Utilities/KONICA MINOLTA magicolor 2300W Status), and then check which toner color is empty.
2. From the Print menu choose Toner Replace...
3. In the Color list box, select the color of the toner cartridge to be replaced (CYAN, MAGENTA, YELLOW, or BLACK).
4. Select the capacity of the new toner cartridge (1500 or 4500).
5. Click OK.
6. When the toner indicator on the control panel starts flashing, open the printer's front door. The carousel is automatically repositioned so that the appropriate toner cartridge can be removed.
2300-0.gif 7. Insert your thumb and index finger into the two holes in the front of the toner cartridge, and then pull the cartridge straight out about 6" (15 cm).
2300-1.gif8. Support the middle of the cartridge with your left hand, and then pull out the cartridge.
2300-2.gif9. Remove the new toner cartridge from its shipping carton.
10. Remove the protective cover clearly marked 'Remove'.
Each toner cartridge has a colored end that corresponds to a color inside the cartridge slots. Always install the toner cartridge in the slot of the same color.
2300-4.gif11. Support the middle of the cartridge with your left hand, insert the thumb and index finger of your right hand into the two holes in the front of the toner cartridge, and then insert the cartridge so that the guides on the cartridge fit into the rails in the cartridge compartment in the carousel.
2300-5.gif12. Gently push the new toner cartridge into the printer.
13. Close the printer's front door.
The printer must complete a calibration cycle (up to 150 seconds) after any consumable has been replaced. If you open the door before the Ready indicator on the control panel lights up and the Error indicator turns off, the printer stops and repeats the calibration cycle.
Sep 01, 2009 | Konica Minolta magicolor 2300DL Laser...
How do you remove toner cartridge from a Dell 3010cn color laser printer correctly.appears to be stuck trying to remove
This is how to Install or replace the Toner Cartridge.
Cheers!!
Apr 21, 2009 | Dell 3010cn Laser Printer
Installing new black print cartridge
Manually Removing Toner for magicolor 2400W
1.  Hold down the Cancel button for 10 seconds or longer.
2.  With the Cancel button still held down, also simultaneously hold down the Rotate Toner button for 10 seconds or longer.
3.  When all LED indicators are blinking rapidly, release both the Cancel and Rotate Toner buttons.
4.  Then hold down the Rotate Toner button again for another 10 seconds or longer.
5.  The Cyan toner cartridge moves into the proper position, so it can be removed.
6.  Remove and/or replace the Toner Cartridge if necessary.
7.  Open and close the covers. Each time you do this, another toner cartridge moves into the proper position, so it can be removed and/or replaced (in this order: cyan, black, yellow, magenta).
The link is located here
Oct 21, 2007 | Minolta magicolor 2400W Laser Printer
Minolta magicolor 2400W Laser Printer Logo
314 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
