Question about Maxon MCB-30 40-Channels Base CB Radio
Maxon MCB 30
I bought this already converted to work with a Honda Goldwing 1500's intercom system. The problem is it cancels the ear phones when the push to talk button is pressed. I would like it not to cancel the headset. Is this possible?
  • Kevin May 11, 2010
    Most two way radios are setup to cut off the speaker (internal or external) when the radio is transmitting.  Are you looking to continue to receive intercom traffic from the passenger while transmitting on the CB?
  • AnyMHz.com
    AnyMHz.com May 11, 2010
    could be. possible.
Shuttle83
  • 1139 Answers
SOURCE: looking for a Maxon mcb-30 manual
I think I have the service manual for this radio please send me your email so I can send it to you
I believe the MCB-30 Crosses with the SM2500 from what I have been reading.
Posted on Nov 03, 2008
Shuttle83
  • 1139 Answers
SOURCE: When I Press the mic to talk, others hear me key down, but no sound is transmitted
Hello lummox30,
Check you mic first to see if it is indeed working. Then if it is the below advice is applicable.
It sounds as if your TX audio amplifiers might be malfunctioning or the TCXO might be bad. If you have a background in Electronics I would suggest that you open up the unit and using a dummy load on the antenna check the two TX audio amps to see if when you key the mic and speak into it the amplifiers are amplifying your voice and sending it to the modulator. If the problem is not amps or the filters in between the amps, the modulator and the VCO buffer are suspect. If the TCXO is being modulated I would check the PPL IC and the Drive amp to see if the modulated signal is getting through. The last two checks I would perform are on the final amp and the TX switch prior to the antenna jack.
If you do not have a background in electronics, still check your mic, but the rest of the above advice can be done by a qualified Radio Technician.
I hope this helps,
Thank you,
Shuttle83
SOURCE: Maxon MCB-30 CB Raido
what do you mean program it? swr?
Posted on Mar 19, 2009
  • 3289 Answers
SOURCE: is my maxon mcb-30 pa capible
According to the page below, it does not have PA capabilities.
http://www3.dealtime.com/xPF-Maxon-MCB-30
Posted on Sep 17, 2009
  • 1274 Answers
SOURCE: Hello there, I have the maxon mcb 30 and I have
Try the stock mic from cobra, the regular 4 pin mic, its a great mic..... enjoy.... hope this helps....
Posted on Mar 13, 2010
1998 Honda GL 1500 Aspencade Gold Wing no speaker sound
Hi, Anonymous for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Radio volume GL1500 Information Questions goldwingdocs com
Hardly no sound from GL1500 front speakers
Honda GL1500 Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda GOLDWING GL1500 Owner Manual
Honda GoldWing GL1500 1993 Troubleshooting Manual
May 06, 2013 | 1998 Honda GL 1500 Aspencade Gold Wing
Maxon wire fuses
If a inline fuse in a holder the old one will aside from length have the amperage printed on it---very few mobile radios use larger than a 3 amp fuse-----look on metal ends of old fuse if have it for markings like 3ag 3 250---3AG is size, 3 is 3 amp, 250 is max working voltage (120 is fine).
Oct 24, 2012 | Maxon MCB-30 40-Channels Base CB Radio
Microphone din pin wiring for mcb30
Look at Defcom Radio mods or other sites. Snake doctors radio mods. Look up Microphone wiring for Maxon MCB-30. Just type it in to WWW.Google.com
May 01, 2011 | Maxon MCB-30 40-Channels Base CB Radio
Hello there, I have the maxon mcb 30 and I have lost the mic. Do you know what kind of mic I must use to work good?
Mar 13, 2010 | Maxon MCB-30 40-Channels Base CB Radio
Is my maxon mcb-30 pa capible
Aug 22, 2009 | Maxon MCB-30 40-Channels Base CB Radio
Maxon mcb-30 manual
Try CBtricks.com......hope this helps....enjoy.....
Aug 06, 2009 | Maxon MCB-30 40-Channels Base CB Radio
Mar 18, 2009 | Maxon MCB-30 40-Channels Base CB Radio
Looking for a Maxon mcb-30 manual
Oct 29, 2008 | Maxon MCB-30 40-Channels Base CB Radio
Meter Shows Signal, no noise
when you have no RX or TX at the same time, that most often means the pre-driver audio transistor is bad.
Thanks,
Dodgem
http://dodgem250.angelfire.com
May 06, 2008 | Maxon MCB-30 40-Channels Base CB Radio
Maxon MCB-30 40-Channels Base CB Radio Logo
134 people viewed this question
Top Maxon Radio Communications Experts
Steve
AnyMHz.com
AnyMHz.com
Mike Charette
Are you a Maxon Radio Communication Expert? Answer questions, earn points and help others
