Question about Ricoh Aficio 450 Copier
Black lines on the paper
I keep getting black copy lines on my copies. Where do I clean my machine to get rid of them?
Thanks
I have a Ricoh Aficio 1515
  • Anonymous Jul 13, 2008
    I have two identical copy machines. Both have the same problems. I have multiple lines on both of my copy machines copies. I have attempted to clean the green security plastic lock. After a clean up, I still have the streaks on both units.Thanks Waltduke@gmail.com
    Problem Solver:
  • 19 Answers
If its not fuser roller or cleaning blade problem, it could be a broken gear inside the Drum Unit.
Posted on Dec 24, 2008
  • 37 Answers
Hi , if you make a copy through the document feeder and there is a line it is on the mirrors , they need to be cleaned , but if you do a printout from your pc or a config psge from the copier , it could be only one of two thing , either your hotroller is getting worn (it normaly wares were the thermoster touches the roller )or tour pcu unit has made its hield and needs to be replaced , you can open the pcu to see if there is any dirt , but i would not recomend this as it is a very dirty job and if you are not experienced you will end up scratching the drum and you;ll end up having to change the pcu in anycase .
Posted on Jul 10, 2008
There is a Black line on the Ricoh Aficio 3045 Drum Help for Remove ????
if you can clean the black line with a cloth, than you need just to replace the cleaning blade, but if the black line is not removing without a cloth, then you need to replace the opc drum and the cleaning blade or both blades, some machines of this type have only one cleaning blade but some have two cleaning blade.
Sep 28, 2016 | Ricoh Aficio Office Equipment & Supplies
Black line on copies
Check the drum history? If the yield is not yet reached, you should clean the charge roller, cleaning blade brush and cleaning blade. Remember to vacuum beneath the cleaning blade! See if that works, otherwise you should call a techie to replace the drum. If yield is not reached they will charge you for a new drum.
Jul 21, 2014 | Ricoh Aficio Office Equipment & Supplies
How do I get rid of the black line when I scan or make copy's
I had a professional to clean the scanner and copy machine. The line was gone. He had special tools to clean the machine parts.. Hope that helps.
Jul 17, 2014 | Brother MFC 8950DW
Maintenance
Time for a new drum.
Jan 07, 2014 | Ricoh Aficio MP-C4000
Photocopies are not clear even after increasing image intensity.
if you have over approx. 60-100k copies on the machine it sounds like you may need regular maintaince on the machine.
to check how many copies you have press the user tools/counter button and then press counter.
Jul 13, 2013 | Ricoh Aficio 1045 Black and White Copier
How do i get rid of black lines on copies? please advise. thanks.
Hello!
You need to clean the litlle glass on the scanner. If that doesnt help you need to clean the scanner mirrors. For that you need to unskrew the glass of the scanner. (I think it is five of them)
Aug 15, 2011 | Ricoh Aficio 450 Copier
Making a black line on copies top to bottom right in the middle
maybe your scanning glass have a dirt! try to open the document feeder and clean it! or it possible that the problem was coming from the cartridge.. =)
May 17, 2010 | Ricoh Aficio 1515F Plain Paper Laser Fax
Ricoh copy machine 3025 paper jams every time we try to print
Make sure the paper that is in the drawer matches the orientation and size indicated on thje Op Panel Display, If NOT, MAKE IT MATCH.
Mar 31, 2009 | Ricoh Aficio 3025P Black and White Copier
AFICIO 551 BLACK AND WHITE
Which feeder? Is it in the document feeder or the paper tray?
Could need a pm to replace the drum, cleaning blade, and possibly developer to get rid of the dirty copy and/or the scanner section should be cleaned as well by cleaning the glass as well as the mirrors underneath the glass.
Dec 10, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio 450 Copier Logo
331 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
