Question about Cell Phones
Alarm goes off repeatedly. - Cell Phones
  • 983 Answers
The firmware might have got corrupted this might of happened due to virus attack or due to sudden removal of the battery when the phone is on or due to sudden switch off of the phone when the battery charge was low ...
this firmware problem can be solved by giving the restore factory settings(reset) ...
after this your problems will be solved ....
if the same problem persists then you must take your cell to flashing .....(there is a less chance to do this , 99% sure your problem will be solved in the previous step only )
any doubts you can reply me
i am always here to assist you
thank you
bye
rate my solution
Posted on Jul 10, 2008
Doro 626 alarm
Alarm 1. Press Menu Organizer Alarm On. 2. Enter the alarm time using the keypad. • For a single occurrence, select Single. • For a repeated alarm, select Repeated. Scroll through the list of days and press On to enable or Off to disable the alarm for each day. 3. Press Save to confirm. Snooze or turn off • When the alarm goes off a signal will sound. Press Stop to turn off the alarm or press Snooze to repeat the alarm after 9 minutes. Note! The alarm will work even when the phone is switched off. Do not press Yes to power on if wireless phone use is prohibited or when it may cause interference or danger. Tip: To edit an alarm, press Edit or Off to stop the alarm.
Dec 16, 2017 | Doro Cell Phones
How do I reset the alarm on a 2005 hyundai Santa 2.4l
Not sure about yours, but many will reset by: turn key to "on" and wait 15 minutes or so; shut off, then try to start.
Apr 15, 2016 | Hyundai Cars & Trucks
Gemini 7200 car alarm replaced battery fob not working no tx to alarm. please help and many thanks. natec
The problem seems to be the key fob on these alarms goes out of sink with the alarm unit (thats if you have changed the battery and its not responding), but 7200/7300 have the ability to "self learn" the new frequency your key fob has changed to .I dont know why they change frequency but they do.I have had to do this a few times myself. if you have a manual for this alarm it tells you how to do it in there but you will need the round key that comes with the alarm that fits in the top of the alarm unit (siren). Anyway to do it : 1.using the key switch alarm off. 2. switch on again. 3. turn ignition for 1 second then off. 4. push the key fob.within 30 secs. 5. switch dim dip (6) back to off. if it dosent work repeat.(dim dips are in the siren where the wire goes in) and if the alarm goes of while your doing it dont worry but just try and be quick. Hope this helps. Chris 13.
Apr 14, 2011 | GPS
I can't turn the alarm off so that it won't go off daily. Right now it goes off everyday and I don't want it to.
If you click the "alarm" button repeatedly you can pick what you want to wake up to. Do this until the only little picture lit up is the alarm clock picture. That will turn of the alarm.
Jan 09, 2011 | GPX CI109 Clock Radio with Dock for iPod ...
Car alarm goes off for no reasoln
Check all ground connections (black wires) from alarm module,may be loose.Also pin switches in door jams,under hood and trunk.While alarm is going off have a friend push and wiggle pin switches to see if alarm resets.Common problem
Sep 11, 2009 | 2004 Volkswagen Jetta
ALARM GOES OFF ON ITS OWN. IT DOES NOT RESET.
try this:
1. find the trunk (boot) sensor (plunger) and tape it in the down position.
2. recharge the battery.
3. close the trunk and rearm the alarm.
4. listen for the alarm to go off. if it does proceed to step 6. if not see step 5.
5. the travel is too large for this trunk sensor. must have been caused by the accident. you can build up the area with some velcro or tape where the plunger meets the metal to make the travel less, thus making the alarm system think the trunk is not opened when the trunk is closed. or this sensor was damaged by the accident which will to be replaced.
6. the trunk sensor is not the problem. untape it and proceed to the hood (bonnet) sensor. tape it down and repeat steps 1-4 for the hood sensor.
7. keep repeating on the other sensors (doors, fuel door) until you find the sensor causing the problem.
good luck
Jan 01, 2009 | 2001 BMW Z3
I have a Timex 1440 sports watch. I have Parkinsons and must take medicine on a specific timed schedule. For a while all was well with this watch; the alarm rang when set. However, I think I inadvertently...
I think you just turned off the alarm. You need to press the MODE button until you are in the alarm mode. (AL or ALARM on screen), then I believe that you just need to click on the upper right hand button (strat/split or stop/reset) repeatedly until the alarm goes back on. Hope this helps.
Dec 29, 2008 | Timex 1440 Nylon watch
Viper 5701 2 way alarm and remote start
Most ford need the door triggers double diode isolated. When the GEM module goes to "sleep" it will set of your alarm . Cut the factory wires where you hooked up the door triggers determine which side goes to the door and which side goes to the GEM module. If it is a negative trigger solder in a 3amp diode with stripe towards the door then solder the door trigger from the alarm to the door side of the diode. Repeat for all door triggers.
Dec 18, 2008 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Vw beetle alarm keeps going off...2000 beetle
rip out the boy racer sunday mechanic alarm and invest in a decent padlock and chain round seat and steering wheel
Nov 20, 2008 | 2000 Volkswagen Beetle
Cell Phones Logo
50 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
