Question about Karcher 2500 PSI Pressure Washer
Won't run with float valve on
We stored for 1 year, tried to start this spring, replaced float valve and cleaned carburator. Will run with float valve off, but will only run a few seconds with float valve on.
  • 33 Answers
Make sure when you put bowl back on carb the float isn't being jammed all the way up. if there is an o ring sealing the carb bowl shoud be no problem. don't know what type engine your talking about.
Posted on Apr 21, 2009
My 2002 ktm125sx runs awesome revs great until carb bowl fills up then it floods and runs terrible I turn the gas off and it'll scream until it starts running out I've cleaned carb checked float
Hi, Dewayne and the usual suspects are:
1. Dirt or other foreign matter between float valve and its seat.
2. Float valve sticking.
3. Float valve and/or valve seat worn or damaged.
4. Float misadjusted.
5. Float cracked, leaky or damaged.
6. Excessive "PUMPING" of hand throttle grip.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
KTM Flooding won start Why
How to Tune Adjust KTM 2 Stroke Carburetors
KTM Keihin Carb How To Jets Needle Clip Floats PART 1
1999 2003 KTM 125 200 SX MXC EXC Service Manual Moto Data Project
May 15, 2016 | GAS Motorcycles
My ryobi 2200 generator rebs hi and low over and over it works but i feel it might turn off
You need to clean carburator. The bowl float opens and closes the pin valve. The float may have a leak, if gas inside float, it needs replacing. Or the valve is sticking. Get a good carb cleaner product at parts store. If its very bad you may need to take carb apart and soak the parts to clean them. Make sure you are turning off gas valve when not in use. You should turn off gas valve and let the motor run out of gas before using kill switch to drain gas from carberator each time its run. Then this won't happen. If no gas valve, buy one and install. Its worth it.
Jan 20, 2014 | Electrical Supplies
Gentron 10000w generator has a leaking carburator
Your carburetor float valve may be stuck open. You'll have to remove the carburetor, remove the sediment bowl at the bottom of the carburetor (where the float is), and check the float. Is it filled with gas? Replace the float if it is. If the float is dry inside, then remove the float and clean the needle valve & seat. (be careful to note how the float pin, linkage, spring, etc. are positioned so you properly reassemble. After cleaning & reassembling, turn the carburetor upside down & try blowing into the gas line connection on the carburetor. You shouldn't be able to blow air. Turn the carburetor right side up & repeat. If you can blow air into the carburetor's gas line connection, the float valve & seat are properly working. Reinstall the carburetor. You should be good to go.
Dec 03, 2013 | Gentron 10,000W Generator with Electric...
Yamaha warrior bogs when i go over rough terrain and back fires
When the bike is on rough ground the engine is under more strain so this may be a sign that the spark plug, lead or coil is failing.
Feb 04, 2013 | Motorcycles
Carburator leaks gas when cycle is started or running from what looks like vent hose?
Sounds to me like your float valve is obstructed by some debris. This is causing it to stay open and leak fuel. Better it leaks to your vent hose than it leaks in your engine and contaminates your oil.
You need a proper carb cleaning. Not some run in the gas tank sh*t. If the tank wasn't full when parked, chances are there is rust in the fuel system to get this out you need to disassemble the carburetor and thoroughly clean it.
Try not to ride the bike til you do this. It's a fire hazard.
Oct 08, 2012 | 2005 Honda VT 600 C Shadow
Flymo 46s won't start. Starts to fire when turned
Possible blocked air filter, try as a test running the engine with filter removed, if ok replace with new filter.
May 02, 2012 | Briggs & Stratton Garden
I have an exmark hp yr 2000, 21hp kawa that's is hard to start due to carb is flooded visually when i take the air filter. and after it starts it runs exellent till i shut it off, when trying to...
You have a problem with your carburator.The problem is most likely the float, the needle valve ,or the needle valve seat. This isn't a difficult fix, you need to remove the fuel bowl under the carburator which is held in place buy a 1/2 inch bolt. There you will see your float, gently push up the float, it should be parallel with the upper section of the carburator. If not adjust float to make this happen. If float is off this is your problem, also float should not be full of gas, if so replace. If not we move on to the needle valve, remove pin that holds up your float and inspect your needle valve tip , if damaged replace. This could be your second problem,if not we move on to the third problem.The needle valve sits in a seat, it is about 1/4 inch round with a 1/32 inch hole in the center, top is flat, bottom is grooved. This seat can be removed with a pick tool. This problem can be fixed with carburator on the engine, but most of the time carburators are removed. You can do what ever you wish.
I believe the problem is with your float adjustment , you can fix this quick and get mowing again.
I am interested in how you make out. GOOD LUCK.
Aug 12, 2011 | kawasaki Fh641v 21hp 21 Hp Riding Lawn...
Where does the little spring go inside the carburator?
Hi loneoaktrail...
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indetion in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Your carburetor should be working properly to run now as long as you do not have other problems in the fuel system or electrical problems.
Free answer...Please rate me
Jun 18, 2011 | Ryobi 15" Electric Factory Reconditioned...
I have a 1999 yamaha royal star venture. I am continually having trouble with the engine running really sluggish (loading up)at slow speeds. It will load up and die in idle and either way it squirts gas...
What's most likely happened is some foreign debris (dirt, rust, fuel varnish, etc.) has gotten stuck on the float valve seat. The first thing you should try is draining the fuel from each float bowl. Turn the fuel petcock off, then loosen the drain screw on the bottom of each float bowl and let the gasoline drain out (catch it in a clean container, if you can, so that you can see what's come out).
Usually, this is enough to clean out whatever is hanging up the float valves. Also, locate the fuel strainer, usually located in a bowl on the bottom of the petcock, and clean it. Installing an in-line fuel filter might help, too.
If this fails to improve the situation, then your next step would be to remove the carburetors and take the float bowls off. Plan on replacing each float valve and, while you're in there, take each float and shake it next to your ear, listening for any signs of liquid inside. Replace any float that has taken on fluid.
Finally, check the float levels. Basically you want the float arms to be parallel with the float bowl gasket surface, just as the little metal 'tang' makes contact - but does not depress, the spring loaded plunger on the end of the float valve. Carefully bend the tang to adjust the float level.
Nov 08, 2009 | 2008 Yamaha Royal Star Venture
Can't start brisggs & Stratton 21in mower. I
Get some GUMOUT carburator cleaner GAS ADDITIVE. Put about 1/2 TEASPOON in the gas tank and about 1 tablespoon per gallon into your spare gas. The float pin is probably sticking from winter non-use. This will free it ip.
You can also remove the bowl from the carburator and spray everything to immediately dissolve the varnish. Be careful not to lose the pin spring.
Jun 13, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Karcher 2500 PSI Pressure Washer Logo
99 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
