I can not install OfficeSuite. I have Windows Vista home Premium. I had downloaded updates all afternoon and it still shows error 1719 Window installer not correctly installed. Help!
Download:Windows Vista Service Pack 1
I tried personally in WIN-XP worked same applies to Vista.
Error Message:
Error 1719. The Windows Installer
Service could not be accessed. You may be running in safe mode or
Windows Installer may not be correctly installed.
Translation:
This
message might appear when you’re trying to add or remove a program that
installs via a Windows Installer MSI (Microsoft Software Installation)
package file. The Windows Installer Service is the standard method for
installing and uninstalling software on Windows XP. It keeps track of
all of the components that need to be installed for a particular
program to run and ensures that any files that are shared by programs
are not removed when one of those programs is uninstalled. The Error
1719 is an indication that some Windows Installer Service files are
missing or have become damaged.
Solution:
The
first thing to try is re-registering Windows Installer in the Windows
registry. Make sure that no other programs are running and then click
Start, Run, type msiexec /unregister in the Open field, and click OK. Next, click Start, Run, type misexec /regserver in the Open field, and click OK. Restart your computer and try installing or uninstalling again.
If
you’re still getting the error message, the next step is to try
reinstalling the Windows Installer files. In order to do this, you’ll
first need to rename the existing files.
First, click Start, Run, and type msiexec /unregister in the Open field, and click OK.
In
My Computer, click Search and locate the following three files:
msi.dll, msiexec.exe, and msihnd.dll. They are hidden files so you’ll
need to select Search Hidden Files And Folders under More Advanced
Options. When you’ve found the files, rename them, by removing the .dll
and .exe extensions and replacing them with an .old extension(for
example msi.dll becomes msi.old).
Once you’ve renamed the
files, WinXP will automatically replace them with a new copy from the
dllcache (a hidden folder where copies of important system files are
kept in case you mistakenly delete or rename critical system files).
Restart your computer and try to install or uninstall the program again.
Finally,
if neither of the above processes corrects the problem, boot into Safe
Mode, and go through the above steps again, first re-registering and
then reinstalling.
or
Go through the following links:
http://www.vistax64.com/vista-general/45784-windows-vista-error-1719-help-3.html
Hope this will be helpfull
Please rate me...
Thanks & Regards.
Nandu
