Question about Gateway SL1450-30145063 Notebook
Gateway solo 1450 won't power up
Hey guys I got a gateway solo 1450 that just displays a orange battery charging light even with no battery in. I tried reset button and pulling hd and the ram. still the same any Ideas of what it might be?
    Scholar:
  • 29 Answers
Fix for Gateway Solo 1450
If you are comfortable soldering and opening the laptop, then this is your day.
I was fixing a Gateway Solo 1450 that shown only red light indicator. Push the power on botton and didn't respond. Did all sorts suggested reseating no availed. Here the solution I made:
1. Go to Gateway website and look for taking out the keyboard. That's the only support I got as far as user/service manual I need.
2. Take the 5 silver philip screws and 4 black screws from the CPU heat sink. Take out the CD-ROM with one screw.
3. Take out the palm besel cover. Note, the screws while taking them out by drawing on the paper their location.
4. Take out the metal that covering the 5 bottons. Again draw the location of screws.
5. Take out the remaining screws from the motherboard.
The main event.
1. Check the 3 soldered legs of the DC jack. If they are loose then Resolder them. If not still resolder them anyway.
2. I found out the Power botton was intermittent. So with a fine soldering tip (30 watts from Radioshack) and Soldering braid. Clear the soldering tip (pile it until no solder on it). With a steady hand use the braid each leg of the Power botton, then pull it with tweezer. Note the orientation is very important. Mark the front face of the power button. The good news you have 4 available switches to use. Next do the same to the last switch botton (a person icon from the dash board). I chose the last right botton. I switched their place.
3. Assemble the unit backward as you first disassembled it.
4. Check the memory. Use eraser from the pencil and rub the memory fine pins back and forth until they look shiny. Insert/reseat it/them.
Hope this helps you. Good Luck.
Roan
Chapel Hill, NC
Posted on Nov 24, 2008
What is correct battery for gateway solo 1450 laptop
You can find the correct battery here - http://www.battdepot.com/us/model/Notebook+Battery/Gateway/Solo+1450/LHP016.aspx
Feb 08, 2015 | Gateway Computers & Internet
Gateway 1450 Solo - power light on amber , won't boot
hi Does the laptop come on at all or just the light comes on
Mar 15, 2008 | Gateway SL1450-30165297 Notebook
Gateway Solo 1450 will power up but the screem/monitor is blank. You can hear it loading up, Could someone tell me if its my motherboard? Thanks
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
May 26, 2012 | Gateway Computers & Internet
My battery is not charging. i bought a new battery, hoping this would solve the problem but it too has failed to charge. when i insert the battery into its slot on the notebook the level indicator...
if all connections are good check the voltage output of the power pack which is the charging unit
That is more than likely at fault instead
New ones are found very inexpensive on Ebay everyday under $10
just type in on any ebay page in the search line.... gateway 2150cs power pack
Aug 08, 2010 | Gateway Solo 2150CS Notebook
Video adapter driver for windows 7 for gateway 1450 solo. drivers in gateway site do not recognize win 7.
Your laptop has not support for Windows Vista or Windows 7. Other components of the system could not be recognized due to lack of drivers. Unfortunately you have to stick with Windows XP as it was originally thought.
Apr 10, 2010 | Gateway Solo 1450 Notebook
How do i take apart my solo 1450 laptop
Device Manuals provide Gateway Solo 1450 Notebook Service Manual free download for you. The Gateway Solo 1450 service and repair guide, Gateway Solo 1450 service and repair manual, Gateway Solo 1450 service and repair instruction hardcopy was packaged with the product box at no cost. The original digital copy of service and repair guide or manual can be downloaded from Gateway. Gateway is one of the main manufacturers of Service and Repair.
Link to solo 1450 manual: http://www.devicemanuals.com/guide/Service%20and%20Repair/Gateway/Gateway-Solo-1450-Notebook-Service-Manual-==TXpBNU9EQXc=.html
Hope this helps FixYa! Please leave feedback if you find this information helpful. Thank you for using FixYa.com
Apr 06, 2010 | Dell 1450 802.11a, 802.11g/b (U7186)...
Cmospwd does not work in resetting the HDD (BIOS?) pwd for a Gateway Solo 1450 with a Phoenix 4.5 Bios. I cannot get into DOS without the password. I have also tried all the backdoor passwords and they do...
u may need to "FLASH" BIOS with a new firmware/software that goes into the BIOS chip, that will require a hardware engineer to do, else to reset BIOS you can try removing the COMS battery from the Motherboard and reinstalling it after 2 - 3 hrs, also in that time keep pressing the power switch of you PC for few minutes without the power supply and without the power cable attached to the PC.
Dec 06, 2009 | Gateway Solo 1450 Notebook
How do I replace the hard drive on a gateway solo 1450 laptop? I need to get the black plastic piece off so I can put it on the new drive
Hard drive replacement instructions (from the Gateway site) for your notebook are here.
http://support.gateway.com/s/Manuals/Mobile/8508627/8508627o.htm#1024735
The entire User Guide is here:
http://support.gateway.com/s/Manuals/Mobile/8508627/index.htm
Good Luck
Oct 21, 2009 | Gateway Solo 1450 Notebook
Gateway SL1450-30145063 Notebook Logo
731 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
