Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Wayne Dalton Quantum Model 3212 Quit working after opening door approximately 6". Worked for 6 months. Light on safety switch is not on.
  • vachristop Jul 31, 2008
    same problem, wayne dalton quantum 3212 stopped working half way up. when you push button to operate, you an hear a humming like it wants to work.
    any suggestions?
    thank you.
  • 4 Answers
SOURCE: wayne dalton garage door is humming but wont open
Likely the plastic gears are worn out. Unplug the unit from power source, remove the cover, look at the gears. If worn, it will be obvious from the shavings from the gears. You can buy the gear kit on EBAY for a little as $20 depending on the manufacturer and model. Before removing the chain drive, lock a pair of vice grips on the chain and metal chain rail to keep the chain from turning from its current position. The gears can be replaced without removing the opener. Even if you have to remove the opener, it is a simple task. Most have four bolts that need to be removed and it will be in you hands.
Posted on Jan 15, 2009
SOURCE: I have a wayne dalton garage door opener and the light stop worki
Try unplugging the unit for ten seconds.If that dont do anything youre have to call wayne dalton they should warranty the light socket replacement ,super easy to change out.
Posted on May 10, 2009
SOURCE: Wayne Dalton DoorMaster Model BDOR-2000/BIRW-2000
Check the contact at the bottom of the socket and (with the unit unplugged) lift (or pull) it up to make contact with the bulb easier or tighten the bulb a bit more than normal.
Does the light ever come on?
Posted on Jul 28, 2009
SOURCE: wayne dalton classic drive 3018, door goes 90%
wayne dalton classic drive squeaks and binds then stops
Posted on Aug 09, 2009
  • 3197 Answers
SOURCE: i have a quantum model 3212 serial #3000...fcc id
1. In the vehicle press and hold the two outside buttons until the indicator light begins to flash (after 20 seconds). Release both buttons. Note: Some vehicles may require the ignition switch to be turned to the second (or "accessory") position during the programming process.
2. Hold the end of your handheld transmitter between 1 and 3 inches away from the Homelink surface (located on your visor or overhead console) keeping the indicator light in view.
3. Using both hands, simultaneously push the handheld transmitter button and the desired HomeLink button. DO NOT release the buttons until step 4 has been completed.
4. Hold down both buttons until the indicator light on the HomeLink Wireless Control System flashes, first slowly then rapidly. When the indicator light flashes rapidly, both buttons may be released. (The rapidly flashing light indicates successful programming of the new frequency signal.)
To train your garage door opener.
1. Locate the smart/learn button on the garage door opener motor head unit.
2. Press and immediately release the smart/learn button.
Firmly press and release the programmed HomeLink button. Press and release the HomeLink button a second time to complete the training process. (Some garage door openers may require you to do this procedure a third time to complete the training.)
Posted on Feb 23, 2010
How do I reprogram a Wayne Dalton wireless keypad model 02-3039UH?
Usually by reading the instruction manual and doing what it says to do .at least it worked for my neighbor a few days ago .
Sep 07, 2015 | Wayne-Dalton Wayne Dalton 297138 or...
How do i reporgram a wayne dalton keypad
I would look into buying a liftmaster jack shaft its a much better unit but to get u buy just press the little red button on the opener type in your code
Feb 04, 2015 | Wayne Dalton Remotes Wayne Dalton 327308...
I cannot get my universal Clicker by Chamberlain KLIK1U to work with my Quantum 3212 garage door opener even though it says that it works with this model. I have followed the instructions and tried...
The klik1u does not operate at a 303mhz frequency therefore it will NOT program to the quantum 3212 but the actual remote from Wayne Dalton is only 2 dollars more than wal mart charged me for the klik1u when I bought it to try
Jan 10, 2011 | Sears Craftsman LiftMaster Chamberlain...
Don't have instructions for my wayne dalton door need spring instructions
Wayne- Dalton uses 4 different types of counter balance springs-extension, torsion, torquemaster 1, and torquemaster 2. I would need this information for a good answer. A photo would help a lot too. Thanks BB
May 16, 2010 | liftmaster Chamberlain Garage Door Opener...
Programming car remote using garage door opener remote control fo
GOTO HOMELINK.COM
THEY MAKE THE SYSTEM AND HAVE INSTRUCTIONS YOU CAN DOWNLOAD.
PLEASE NOTE: NOT ALL BRANDS/MODELS OF OPENER WILL WORK WITH THIS SYSTEM.
HOPE THIS HELPS
Jul 03, 2009 | 2003 Lexus ES 300
I have a wayne dalton garage door opener and the light stop working after and over ride or over use I let the motor rest and work again but the light stop working I replace the light bulb and nothing...
May 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remotes won't work
Sounds like a frequency issue. A remote work like the radio in your where each station is on a different frequency. Some signal is interfering with you frequency (390Mhz) You could try another brand external receiver with new remotes or with that old of an operator you might just think about replacing the operator (don't go with "Wayne Dalton")
Nov 27, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,876 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
