Question about BenQ DC E53 Digital Camera
Is there a way to get the DC E53 camera to accept a larger SD card than the 512mb that it currently accepts?
    Scholar:
  • 173 Answers
The following link describes the maximum SD card size for your camera.
http://www.mymemory.co.uk/compatible-memory/Digital_Cameras/BenQ/BenQ+DC+E53_Memory_Cards
The following is from their site:
BenQ DC E53 BenQ DC E53 Memory Cards (SD Card) & Accessories
The following digital camera memory cards are compatible with your BenQ DC E53. Every digital camera memory card we offer is manufactured to the highest standard and carries a 2 year minimum warranty.Your BenQ DC E53 accepts SD Card cards.The largest SD Card card you can use in your BenQ DC E53 is 2GB
So you can buy up to 2GB SD cards.
Posted on Jan 06, 2011
SOURCE:
Will 5 year old cameras take a 16gb card
Hi. Your camera is too old to accept that big a card. The camera will let you know what size it will accept. Just keep putting larger sizes until it stops. Hope that helps.
Dec 18, 2014 | Pentax Optio Cameras
Is there an up-date which will allow dimage Z6 to use a 4 GB storage card please. My camaera will only recognise up to 2GB SD card.
Sorry, no. SD cards max out at 2GB. Larger SDHC cards are electronically incompatible and will only work in devices specifically designed to accept them. It's a hardware incompatibility and no amount of firmware changes will make a SD device accept SDHC cards.
Jan 30, 2013 | Konica Minolta DiMAGE Z6 Digital Camera
What size sd card will kodak c533 accept
The C533 will accept any SD card. SD cards max out at 2GB. Larger cards are actually SDHC cards and will not work in the C533. So, use cards up to 2GB.
Sep 08, 2012 | Kodak EasyShare C533 Digital Camera
I can't find the memory card for it
According to the specifications the camera has both an in-built mmory, and also accepts an SD card with a maximum of 512 MB . Maybe it will accept a larger SD memory card but only record up to 512 MB? I do not know.
SD cards are common in camera stores, but these days they make them with 1, 2, 3 or even 8 GB ( 1GB about 1000 MB) !
Dec 24, 2010 | Creative Labs DiVi CAM 316 Digital Camera
What is the maximum gb card for a samsung 420
Your camera is definitely compatible with SD cards up to a maximum capacity of 512MB. It was never hardware tested by the manufacturer with larger capacities and definitely cannot accept any SDHC cards (4GB and upwards); I have also tried one in the past with a 2GB SD card and it was unusable. Unfortunately Samsung have never actually published any hard and fast data stating what the maximum capacity is for the Digimax 420.
In summary then, you're good to go with 512MB SD, 1GB SD is a gamble and will either work or it won't (but won't harm your camera or the card), 2GB and above are not suitable.
Oct 11, 2010 | Samsung Digimax 401 Digital Camera
I have a gateway dc-t50 camera and replaced the 32mb sd card holds only 12 pica to a 4gb sd card and getcard error message ?
Your problem is in trying to mix and match old and new technology.
Your camera can handle SD cards up to an absolute maximum capacity of 512MB (as per page 21 of the user manual). It's incapable of operating with anything of a higher capacity and totally incompatible with the SDHC card you appear to be trying to use.
Your only fix is to either limit yourself to 512MB maximum capacity SD cards, or to replace the camera with a modern SDHC compliant model which will accept your new card.
I hope that you have found my free reply to be clear and useful and that you can take a brief moment to rate my answer.
Oct 08, 2010 | Sanyo Xacti VPC-CG9 Digital Camera
I have bought an 8GB SDHC Video Card for my Vivitar DVR310 Digicam but when i try to switch the camera on to power it and format the Card nothing happens..there is a slight "whine" noise coming from the...
Your camera will accept a maximum SD card capacity of 2GB. It simply isn't capable of handling anything of a larger capacity and in particular is incompatible with the more technically advanced SDHC cards.
Your fix is to either replace your camera with a later model or to stick to using SD cards with a maximum 2GB capacity.
Please take a moment to rate my free answer.
Oct 04, 2010 | Vivitar DVR310 Digital Camera
It says this card cannot be used. what is the biggest sd card i can use?
The S1 uses SD cards. SD cards top out at 2GB, any larger cards are actually SDHC (Secure Digital High Capacity). SDHC devices will accept SD cards, but SD devices will not accept SDHC cards. They will fit physically but not electronically.
In fact, the S1 manual does not list any cards larger than 1GB.
Jan 26, 2010 | Nikon Coolpix S1 Digital Camera
Z3 will not accept a 2g card
The Dimage Z3 accept SD cards up to 1GB (Minolta says 512 Mb, and sold it with 16Mb). This camera is 4MP , and uses less memory on card, therefore a 512MB card will be enough for it.
SanDisk Flash memory card - 512 MB SD Memory ...
from $13 - 20 stores
PNY Flash memory card - 512 MB SD Memory Card ...
from $3 - 2 stores
SanDisk SD Industrial Flash memory card - 512 ... from $14
Here 1 Gb, try at your risk, but they normally work:
1GB micro SD memory card for Konica Minolta ...
£6.90 - www.mobile-laden.co.uk
1GB Flash Memory Upgrade Card for Konica ... £3.44 - Memory Express
Here review: Steves Digicams - Minolta DiMAGE Z3 -
Mar 31, 2009 | Konica Minolta DiMAGE Z3 Digital Camera
Option S4i > 512MB SD card Possible?
I have a friend who had an s4i with a 1gig sd card with no problems.
Aug 30, 2005 | Pentax Optio S4i Digital Camera
BenQ DC E53 Digital Camera Logo
421 people viewed this question
Top BenQ Cameras Experts
Damen Wong
Damen Wong
Vincent_G
Vincent_G
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a BenQ Camera Expert? Answer questions, earn points and help others
