Question about Frigidaire Refrigerators
Broken water actuator - Frigidaire Refrigerators
  • dheg Oct 27, 2008
    Any instructions on how to put it in? This is the 2nd time I've had to have this replaced in 18 months and don't want to pay someone to come out if I don't have to.
    Sergeant:
    Champion:
  • 330 Answers
Order the new part and put it in.
Posted on Jul 10, 2008
2000 oldsmobile bravada heater control valve location
If you are looking for some sort of water valve that diverts water to/from the heater core, forget it. They don't exist anymore. They went away shortly after the widely adapted use of air conditioning in today's modern cars. Now, hot coolant is routed thru the heater core at all times, but is controlled by a cable-operated, or vacuum operated "blend door" located inside the heater box. If you are not getting heat to the vehicle, there are a few possible problems:
1. Bad thermostat - thus low coolant temperature and lack of heat.
2. Clogged heater core - no water flow thru core, thus no heat.
3. Broken control head - loss of cable or vacuum actuation of blend door.
4. Broken heater box/vacuum tank - no actuation of blend door.
Of the items listed above, based on the age of the vehicle and the likelihood of occurrence, I would investigate them in the order of 2, 4, 1, 3.
Jan 20, 2016 | 2000 Oldsmobile Bravada
My GE Portable dishwasher won't fill.
Possibilities:
Water off.
Blocked water filter
Water solenoid valve not actuating
Water solenoid not getting power
Not getting power could be:
Stuck pressure switch,
Programmer not working
Broken lead
Feb 13, 2015 | GE GSC3500RWW Portable Dishwasher
Refrigerator trio water not coming out
the water actuator switch could be bad or the arm broken. The water line could be frozen in the door or the reservoir ion the fresh food compartment. the water valve in back could be bad.
Jul 15, 2014 | Kenmore 24.8 cu. ft. Trio French Door...
Why rainbow vac wont turn on
There are numerous reasons. If there was no smoke or burning smell, first try a different outlet. Then you can try wiggling the cord and check cord for damage, if you can get it to start and it turns off again cord is loose or damaged. Try the switch, sometimes switch wears out, if it is not making a click sound or is very loose it may be the switch. The most common reason for an E series to not start after working just fine is a broken actuator on the water basin or missing from the bottom of the vacuum. There is a raised part on the water basin that depresses a little black plastic actuator on the bottom of the vacuum. This is a safety switch to make sure the water basin is there so the vacuum will turn on. You can try pressing in on that and trying to start your vacuum, if it starts you will need to check and see if the part is broken off of your basin or if the little black actuator is missing. You can see pictures here.
GoodVac.com Technician
www.goodvac.com
1-800-775-6586
May 10, 2014 | Rainbow E series Canister Wet/Dry Vacuum
I have purchased a replacement water actuator to replace a broken
Remove the top freezer hinge cover , and disconnect the plug there . This removes power to the door , where you can disassemble the dispensor , without electricity to the door .
Nov 22, 2009 | Refrigerators
Cab air direction control is stuck on defrost
there are a couple possible problems 1 is the mod door an broke, the mode door actuator can be broken or the control head can be broken, although this rarley happens. it,s usually the door or actuator..........hope i helped if need more info feel free to ask.
Nov 22, 2009 | 2003 Ford F250 Super Duty Crew Cab
My ice cubes appear to be hollow. what is causing this?
The water valve is not letting enough water in . Replace the water valve .
Aug 06, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Hi this is tech crazy
the solution to the problem is
You should be able to replace this part yourself. Follow these steps to replace the water actuator:
  1. Unplug the refrigerator to completely disconnect electrical power. Turn off the water supply to the refrigerator.
  2. Remove the drip tray (Key 23 in the image below) from the bottom of the dispenser.
  3. Remove the screws (Key 43) from the bottom of the dispenser module cover (Key 4). NOTE: You model may not have screws at the bottom of the dispenser cover. If not, push down on the top of the dispenser cover and pry out on the bottom of the cover with a flat tip screw driver to remove it.
  4. Pull to dispenser module cover up to release the top clips and remove this cover and set it aside.
  5. Remove the screws (Key 17) that are on each side of the dispenser module (Key 8).
  6. Carefully pull the dispenser module out slightly from the door. It will have wires attached. Pay attention to how the water tube and the ice door assembly are positioned. Pull this module out far enough to remove and replace your water actuator (Key 24).
Reverse the above process for reassembly.
Jan 25, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Water Actuator is broken.
I had the same problem with my water dispenser and since they were willing to sell me a part but provided no directions and I couldn't locate any I decided to make my own for those who might need them. Here is a link to a PDF I made, hope it helps.
http://www.rharriman.com/SupportFiles/FridgeActuatorReplacement.pdf
Before starting this job I would also like to warn all to please be save and UNPLUG the fridge. The whole job took me less then 30 minutes and I doubt anything will go bad in that amount of time.
Jan 13, 2007 | Frigidaire FRS26R4A Side by Side...
Refrigerators Logo
109 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
