Question about HP OfficeJet 6110 All-In-One InkJet Printer
Carriage jam Copier says thre is a carriage jam. Says to open door and clear the jam. I don't know how to access the door to carriage.
  • 138 Answers
Most of these carriage jam errors actually have to due with one of two things:
A small white gear in the cleaning/purge service station gearing (non repairable or orderable part) or a spring wire dislodges in the carriage housing for the cartridges dislodges and punctures the flex contact ribbon in the rear of the slot that holds the cartridges. The second is easy to check. Remover the cartridges and look for the puncture marker in the ribbon tape that contacts with the cartridge. The gearing issue is far more difficult to visually inspect as most of the machine has to be disassembled to dig into the purge stations internal gears. The best way to diagnose is to carefully listen for a light clicking noise when the purge is moving back and forth to clean the cartridges. Either way if you have either malfunction, the machine IS NOT repairable as HP does not or will not sell the parts. Most of the used machines sold on the auction sights as non-functioning used parts machine also have these same problems so are pretty much useless to use as parts to fix your problem. Sorry the news isn't better but it's accurate as we have seen at least 75 to 100 of this model in for repairs at our printer service and repair company.
Posted on Aug 03, 2008
  • parkerguy Aug 04, 2008
    Lokked at the solution recommended by HP however its is a very very very small percentage of the machines that can be remedied by HP's suggestion. The above that I posted covers at least 95 to 98% of the machines. I am a printer technician with over 13 years experience and have seen at least 75 to 100 of this model.
  • parkerguy Aug 30, 2008
    Wow! That was a whole lot of work for a low rating. Guess I shouldn't have put out the effort. :)
  • 35 Answers
Hello..
- pls clcik the link below. it willl help you to troubleshoot the issue
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00300330&cc=us&lc=en&dlc=en&product=79477
Posted on Jul 30, 2008
Carriage jam
Hi
The carriage door is the cartridges access door.Access the cartridges and make sure they're properly installed.To open:
  • Turn the machine on.
  • Open the cartridges door by lifting from the front center of the device until the door locks into place on its own.
Feb 27, 2012 | HP C6250 InkJet Printer
I get a message carriage jam and told to clear jam. However there is no paper jam. It tells me door open and it is not open. It seem the door does not go all the way up. I keep getting the message that...
It seems you mistook Carriage Jam as Paper Jam, but they are different issues. Carriage jam means the carriage that carries the cartridges is jammed which needs to be moved or be cleared manually after opening the door.
Please follow the instructions mentioned here (Click Here) [source HP Support].
Good Luck.
Let me know if you need further help.
Thanks for using FixYa.
Jan 14, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Copier makes a noise when first turned on and then it tells me to open the door clear carriage jam and press enter. But that does not work. The printer has been sitting for a little...
Check the following steps for fixing Hp Carriage Jam Error :
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed paper out.
Nov 29, 2010 | HP PSC 1600 InkJet Printer
Where is the printer carriage access door located?
Hi
The door shown in this picture is carriage access door
2386b83.gif Let us know if in case you need any more information
All the best!!
Regards
Nov 01, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
My officejet 5610 says "carriage jam. Open Door etc. I can't find a door to the carriage.
Hi!
here are some solutions for your carriage jam error.
1. Clear any jam...remove loose paper.
2.Clear the jam from the back of the printer
turn off the printer...remove the rear access door..
pull the paper out of the roller and return the rear access door.
3. Clear the paper jam from the front of the printer..while printer is on.. open the carriage access door..
disconnect the power cable from the back.. remove the paper output tray.
look inside the product..check for torn papers..gently pull out the paper from the roller...return the paper output tray and the carriage access door. plug the power corn and turn on..
4. Make sure the carriages move freely...while the printer is on.. open the carriage access door.
disconnect the power cord from the back..remove the paper output tray...look inside if the carriage is stuck and if there is no papers or object that restrict the carriage to move..return the output tray.. return the carriage access door...
And lastly after doing this steps try to reset the printer and try to print..
To reset the printer....press the power button to turn on the printer..disconnect the power cord from the product..disconnect the power cord from the wall outlet.. wait for 15 seconds.. plug the power cord to the wall socket....plug the power cord at the back of the printer.. press the power on of the printer.. try to print the test page...
Good luck! hope this solve the problem
Much appreciated if you rate this help.. thanks
May 23, 2010 | HP Officejet 5610 All-In-One InkJet...
Paper Jammed. Have appeared to remove all paper. But I keep getting "Carriage Jam, open door, clear carriage jam then pres OK" message. Message on my computer screen says "The print cartridge carriage is...
HP support has extensive documentation for both paper and carriage jams for your model:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00304007&lc=en&dlc=en&cc=us&lang=en&product=391182
I hope this helps!
Dec 10, 2009 | HP OfficeJet 7310 All-In-One InkJet...
How do i clear a cartridge jam on my hp all in one printer
Is the paper feeding crooked and catching on the carriage? If so, remove the rear access door and clean the feed rollers with a damp cloth.
some other resion is The print carriage is the part that holds the print cartridges. Carriage blocked or jammed messages may occur for these reasons:
A paper jam was cleared from the front instead of the back on models that have a rear access door.
The print cartridges were installed incorrectly.
There is some obstruction in the path of the print carriage.
Open the print cartridge access door of the all-in-one so that the print carriage can be accessed.
Thanks,
Dec 03, 2009 | Computers & Internet
I do not know how to open the printer carriage access door to clear a paper jam
You can find detailed instructions on clearing paper jams, including carriage jams, here:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01618201&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=3752462
Oct 29, 2009 | HP Officejet Pro 8500 Wireless All-In-One...
HP Digital Copier 610 Carriage Error
Depending on where the paper jam happened and how you cleared it, you could have either "knocked the copier for a loop" or actually damaged the print carriage. The first thing I would do in your shoes is to turn off the copier and unplug the power cord from the back of the product.
Wait about 30 seconds or so to make sure any errors being held in the copier's memory by any residual electrical charge clears.
Plug the power cord back in to the back of your product and turn it on. My guess is that you'll be prompted to go through a cartridge alignment procedure. That may well clear up the problems you see.
Just in case, I'm posting a link to HP.com to instructions on how to clearn the electrical contacts on the print cartridges and print carriage. There are also instructions on this page regarding latching cartridges. These seem to be fairly easy processes, but if not done correctly, can result in continuing errors:
Resolving Print Cartridge Errors
Print back your results and good luck.
Nov 05, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP Officejet 5110 - Carriage Jam Message
I have an Hp Officejet 5110. I have an error message saying "Open door,clear carriage jam, then press enter". But where is its door? How can I clear the carriage jam?
I tried pressing the # & 6 at the same time, but the error message still there.
Mar 09, 2008 | HP OfficeJet 5110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
96 people viewed this question
Seeker5211
Seeker5211
