Question about Hitachi FDX Series 43FDX10B 43" Rear Projection Television
Blue convergence i cant get the blue convergence to auto or manually aligne. is it possible to tell if it is adjustment or part replacement easily?
  • 1 more comment
  • bailey3218 Aug 02, 2008
    I believe this is the same problem I am having. Basically i am getting blue shadows behind everything, and when I go to realign the blue gun in the digital array setting, I can't get the targets to line up or stay lined up. Is this the same problem, and do I need to replace the same parts as reccomended?
  • Jake the man Sep 17, 2008
    Hitachi 43 inch Projection tv model 43fdx10b. I can not manually aligne blue convegence. It bows on top and bottom. I think I need to replace both ICs but do I have to change any resistors.
    Thks Jake
  • Anonymous Oct 21, 2008
    I have the same problem. The blue projection tube is displaying in a warp (in a curve on top and bottom from the corners toward the middle).
  • Hitachi Master
  • 8,617 Answers
Thats the classisc sign that you need to replace both convergence ICs. You will need two Convergence ICs STK392-120 and then six resistors they are RK42 3.3 ohm 1watt, RK46 1.5 ohm 1watt, RK50 2.7 ohm 1watt, RK54 1.5 ohm 1watt, RK58 3.9 ohm 1watt, RK62 1.8 ohm 1watt. You can get replacement ICs and resistors at the following link and they provide free instalation instructions with pictures so you can repair the set yourself. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Jul 10, 2008
I hav a RCA model D52W25 its 52" it has convergence problems dont know how to setup the color things can u help??
Click on the following link :
http://www.riddledtv.com/repair/RCA.html. Go to the following section
(2) (3) (4)
(5) Stretched Image at top and bottom edge very distorted. Reheat all the surface mount solder points on the Small Signal Board. Then realign the set including convergence menu. To enter service mode: power off the set for 10 sec, then hold down Vol- and Ch- buttons for 10 sec. See this link: Alignment Procedure (pdf)
Also download the Alignment procedure pdf file. Hope this will help you. Please let me know if the information was of any help to you or you need further assistance.
Thanks
Oct 08, 2008 | Televison & Video
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Apr 23, 2010 | RCA HD52W58 52" TV
Convergence Problem
Unfortunately you will have to replace the convergence board in this unit. it has failed. this particular board regulates the alignment procedure that you are having issues with. replacing this board will fix this issue.
May 21, 2009 | Mitsubishi VS-5047 50" Rear Projection...
Auto Digital Convergence Adjustment blue to aligning
Ur convergence is dead.Buy the convergence kit,replace what in that kit.Tries these websites Tv Repair World.com Shopjimmy.com Ebay.com or Partstore.com.
Mar 16, 2009 | Hitachi 57G500 57" TV
Green tint on Samsung Television
Hi sbatsch,
Not to worry - this problem is very common with projection TVs and is easily fixed:
The reason for the green shadows (and the resulting wrong colors) is that the three color tubes (red, green, and blue - the three colors of light that combine to form all the other colors) are not lined up exactly - this lining up is known as "convergence." You can fix convergence automatically or, if it doesn't work to your satisfaction, manually. Here's how:
Automatically:
1) Press MENU.
2) Go down to CONVERGENCE (using the up and down arrows)
3) Select it (usually with the left or right arrow)
4) Go down to AUTO and select it - the process should take about a minute.
If this doesn't work, then try manually:
1) MENU
2) CONVERGENCE (as above)
3) Select MANUAL
4) Using the number keys, SELECT, and the arrow keys, adjust the alignment of the different color crosses - the goal is to make them appear white (meaning that the red, blue, and green are exactly aligned on top of one another).
Here's a link to the JVC user manual that will explain the manual convergence adjustment in more detail.
http://resources.jvc.com/Resources/00/00/96/52105ien.pdf
I hope this helps - please let me know if I can be of any further assistance.
Dec 11, 2008 | JVC AV-48WP74 48" Rear Projection...
Convergence problem
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
You can download the manual here. Insrtuctions for auomatic convergence are described. I copied the instructions below.
Automatic Convergence
Your HD Monitor’s picture tubes might have been disturbed during delivery or
after you moved the HD Monitor, causing the color in your HD Monitor to be
out of alignment. The colors adjust by starting auto convergence.
IMPORTANT: Auto convergence works best once the HD Monitor has
warmed up for at least an hour. If you've just unpacked your HD Monitor,
it's a good idea to repeat the Auto convergence function when the
HD Monitor's been running for at least an hour. See page 38 for more
information about Auto convergence.
1. Press OK to begin auto convergence.
2. When the auto convergence is complete, the Red center convergence menu
appears. The cross in the middle of the screen should be yellow. If it is not,
use the arrow buttons to move the red cross to overlap the green cross.
Press OK when adjustments are complete.
3. The Blue center convergence menu appears with a cyan cross in the middle
of the screen. If it is not, use the arrow
Sep 23, 2008 | RCA R52WM24 52" HDTV Projection Television
Samsung rear projection tv
It probably is see if you can align the convergence manually or auto if available, you can order just the convergence ic's or the convergence amp board, whichever you prefer. check pricing and availability. also check Blue crt for faded picture, usually dirty crt fluid, makes picture dark and discoloured. If it is you may need to replace the blue crt also. this gets a little expensive, again check pricing hope this gets you started RFT
Jan 06, 2008 | Samsung HCM4215W 42" Rear Projection...
Jvc av56pw74 blue shadow
You are going to need a full convergance alignment to rectify this issue.
Aug 09, 2007 | JVC AV-27720 27" TV
Convergence problem????
Yes Its the stk Packs,They are usally 18
Jul 23, 2007 | Toshiba 42H82 42" Rear Projection...
Hitachi FDX Series 43FDX10B 43" Rear Projection Television Logo
96 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
