Question about HP LaserJet 2840 All-In-One Printer
Speed I fixed the page too complex by turning off the high speed USB but now there is a 30 second delay between pages printing. Is there a way to fix that problem?
  • 525 Answers
Try this.....
Turn printer on.
On your printer, press the Menu button
Press 2 (on the fax dial pad)
Press the right arrow (next to Enter button) until you arrive at "High Speed USB.
Press Enter
Press right arrow to select "Off."
Press Enter.
Press Enter again.
The printer will reboot automatic.
I hope this help!..
Posted on Feb 13, 2015
  • 138 Answers
Add memory to the machine and it should resolve your issues. The 2840 comes with 96MB built-in and has one slot open for additional memory located under the right side cover. It can take a max of 224MB total. I would recommend adding a 128MB memory card to max out the machine. It takes 100 pin, 133MHz, SDRAM.
Don't by it from HP as they list it at $500.00 or so. Buy the clone memory for around $25.00 for 128MB.
Here's a link to source the memory:
http://www.memory.com//net/System.aspx?model=23451
Hope that helps you.
Posted on Aug 05, 2008
Getting "Page too complex" message
fixing this one is easy. Go to the unit and press the menu. Then with the arrows go to service and press ok / enter, with the arrows look for high speed usb and press enter, then look for ''off'' and press enter. The unit will reboot and you will be able to print
Aug 26, 2010 | HP LaserJet 2840 Printer
"Page Too Complex" message
Press ENTER to clear the message.
Allow the device to finish the job, or press CANCEL to cancel the job.
Lower the USB speed on the product by turning off "High Speed USB". Following are instructions on how to do this from the Secondary Service Menu:
To access the Secondary Service Menu press the Menu button.
Now press the #2 button and use the < arrow to navigate to the High Speed USB selection.
Press Enter and then use the arrow key to go to Off and press Enter again.
Press the Cancel button twice to exit the Secondary Service Menu.
Feb 15, 2010 | HP LaserJet 2840 All-In-One Printer
I am getting page to complex to print for documents that were printing previously
After using this printer for two years with high speed USB turned on, I began getting the same error message. It is not a memory issue.
The solution was to get into the machine menu and turn off high speed USB. I can only assume that HP broke something with a firmware update.
How to turn off High Speed USB.
Push the Menu button on the printer. Scroll over to the "Service" menu. Push "Enter". Scroll to High Speed USB, push "enter". Turn High Speed USB "OFF". It fixes it but makes everything sloooow.
HP no longer manufactures or supports this machine and I have been unable to get Windows 7 software other than the generic universal driver.
This will be my last HP. It has been a good machine but HP software sucks!
Jan 30, 2010 | HP LaserJet 2840 Printer
2840 printer -- can't print because document is
Basically it is telling you it doesn't have the memory required to process the page (usually because of graphics). If this is the case, you can try setting the resolution in the print driver to a lower setting (sometimes referred to as quality) so that the memory can handle the graphics.
Jan 30, 2010 | HP LaserJet 2840 All-In-One Printer
''Page too complex'' message on HP color laserjet 2840 Multifunct.
On the printer, hit the menu button
Then navigate using your left arrow button until you see Main Menu - Service, then hit enter
then use the right arrow to navigate to high speed usb and hit enter.
it should now show on, use the right arrow once to change it to off and hit enter 2 times
let the printer reboot and its should be fixed
Nov 15, 2008 | Office Equipment & Supplies
HP 2840 Page to Complex (Ethernet Printing)
Try using a PCL driver
At this HP link
This link above is for windows XP
Jul 15, 2008 | HP LaserJet 2840 All-In-One Printer
Page too Complex
Sometimes you may come across this type of a problem when the device is not able to print the current page because of its complex nature.
The speed of the USB on the product needs to be lowered. This can be done by turning off the “High Speed USB”.
Given below are instructions to follow from the Secondary Service menu:
Press MENU button to access Secondary Service Menu.
Press the #2 button and use the < arrow to navigate to the High Speed USB selection. Press Enter > OFF > Enter.
Jul 10, 2008 | HP LaserJet 2840 All-In-One Printer
HP officejet d135 delayed printing
Both the printer and the computer are machines and it solely depends upon the speed of the computer as to in how much time thye data is transmitted to the prinetr to print. Check the speed of the processor, RAM,USB port(if connected with usb cable), length of the usb cable /ethernet cable, distance of the router from the computer and the printer, size of the dcument/image.
Dec 24, 2007 | HP OfficeJet D135 All-In-One InkJet...
HP 2840
Go to Service section from the Main Menu then go to "High-Speed USB" and set it to OFF
Dec 12, 2007 | HP LaserJet 2840 Printer
HP LaserJet 2840: Page 'Too Complex'
Description
The device could not print the current page because of its complexity.
Recommended action
Nov 11, 2007 | HP LaserJet 2840 Printer
HP LaserJet 2840 All-In-One Printer Logo
71 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
