SOURCE: Pinnacle MovieBox USB Power
You can use a universal one but it has to be 3.3 Volts at 3 AMPS and the tip of the plug must be positive. If you have a radio shack by you they should be able to get you the correct adaptor.
Thanks,
Mark
SOURCE: Does moviebox usb work with studio 14 and vista?
This is the latest hardware device that can used for Studio 14.
Check the list.
USB based
PCI based
Are you using vista 32 or 64 bit system? If Vista 64 bit there is no driver for your device and the only available is 32 bit only. Aside from that you can check also the video cable you were trying to used. If firewire under import/capture tab of Studio 14 you need to select the name of your camcorder or dv camcorder. Check that out and try.
SOURCE: i have the Moviebox USB and i am running Studio 14
Have you installed the Moviebox Win 7 Drivers?
SOURCE: I need a MovieBox DV (1394)driver compatible with
Pinnacle Software has a Vista Patch to use with their applications that you have to download and install. I had this same problem when I used Pinnacle for my remote camera system.
SOURCE: I have the Moviebox USB
I have the same problem. If you have an earlier version of Studio (i.e.; Studio 12) with which Moviebox USB works, then retain that version for capture. For all else, use Studio 14 by retrieving your captured footage from your hard drive.
