Question about Whirlpool Refrigerators
The ice maker in my Whirlpool Ultra seems to be frozen and I need to remove it to thaw it out.
    Sergeant:
    Champion:
  • 330 Answers
Turn off the freezer for a while then you can remove it.
Posted on Jul 10, 2008
Whirlpool ice maker will not fill with water
1st check to see if fill tube is frozen that goes through back freezer wall to feed water to ice maker. If it is, thaw it and replace water valve. If not frozen, then you must determine if water valve or ice maker is bad. You must determine if Ice maker is sending voltage to valve. If it is, replace valve. If it's not, replace ice maker.
Sep 03, 2017 | Whirlpool Refrigerators
Ice sheet on back of ice maker & in ice bucket
Happy 20th Birthday Refrigerator. Time to replace.
Jun 25, 2017 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice maker not getting water. Everything else seems to work fine. I can put water manually into the ice maker and get ice. But no water from the line. It is a KSRS251 superbra side by side Kitchenaid model.
You will have to remove the icemaker and look inside the water fill tube at the rear wall of the freezer.
The water line may be frozen closed.
If so,take a hair dryer and thaw it out.
This manual will explain other test to complete.
http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
Nov 09, 2009 | KitchenAid KSRS25IL Side by Side...
Whirlpool GR2FHTXVQ00 fridge. Water dispenser
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
You can thaw out the fill tube and replace the inlet valves.
Oct 13, 2009 | Freezers
Frigdaire side by side ice maker is a block of ice
Hi, You can remove the ice maker by removing the two screws on the top that fasten to the wall and most models have a screw on the under side.
Did you have to turn the water source off to stop the water from going into the ice maker? Sometimes a cube will not release and block the ice maker from turning.
Please let me know if I can assist you further.
Vic
May 29, 2009 | Frigidaire FSC23F7D Side by Side...
Ice Maker Not Working
have you checked the inlet to the ice mAchine inside of the freexzer to see if its frozen up. use a hair dryer to thaw it out. the main cause of this is a leaking solinoid valve on the outside of the unit.
Feb 03, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool GS6SHAXMQ Side by Side Refrigerator - Ice Maker Problem
This happened to me after i had to move the freezer and it was unplugged for a while. When it was plugged back in the ice maker would not work.
Assuming both the ice maker itself and the rear water AC solenoid switch are actually not broken and are functional, and you are getting water from front door dispenser, then check the inside supply tube (black) is not frozen and blocked. Check with q-tip or feel to see if frozen.
If supply tube is frozen, thaw by holding up small full clear glass of heated water placing the frozen tube into the heated water. The clear glass will allow you to see when ice slips out.
Next try resetting the freeze cycle. Turn off the ice maker switch, remove the maker by carefully disconnecting the inside power cord. You will need to remove the inside door flap. Rinse the maker with warm water, allow to come to room temp.
Re-install maker, connect power cord. Turn on ice maker switch. Make sure Infrared sensor is not blocked. Now wait for temp change and listen for water to fill tray. It took maybe ten minutes for me. You will be able to hear the water fill with the door closed.
Again, this assumes nothing is actually broken.
This worked for me. Good luck.
Jan 18, 2009 | Whirlpool GS6SHAXMQ Side by Side...
Ice maker nor making ice
hi thanks for the question use a hair blower to thaw the tube and then pull the tube out clean and reinstall thanks te appliance doc
Aug 10, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker water line appears to be frozen on gd5sha. ice maker won't function.
thaw the whole refrigerator for a whole day to thaw the ice inside the water line. it will reset also the timing of the ice maker.
Jul 05, 2008 | Whirlpool Refrigerators
Whirlpool fridge model WF-NL300 ice maker not working. No water in icemaker. Black water supply tube that fills icemaker was frozed solid with ice. I thawed it in a cup of hot water. Unsure if line could...
Turn ice maker off for 24 hours to thaw out any additional frozen lines.
Make sure that you do have water from source to unit. Water valve grit screen may be clogged with debrie or water valve is bad.
Feb 29, 2008 | Refrigerators
Refrigerators Logo
32 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
