Question about Garmin GPS III
Garmin GPS III Pilot to PC communication problem
I have a Garmin III pilot which has suddenly stopped communicating with both of my computers. I have a PC that uses Windows XP and a laptop that uses Windows Vista (both are home editions). The lead from the GPS was used to connect to a previous computer’s serial port, but now has an additional converter lead attached so I can use the USB ports (which has worked in the past).
The program I’m using is called G7towin.exe, which is a widely used program which downloads waypoints to Garmin GPS units.
If I try to connect to the Garmin I get one of the following messages depending on which COMM port "n" I try :-
"in asyncinit 1 \\.\com"n" error: 2. The system cannot find the file specified"
"in aysncinit 1; com "n"; error 5 access is denied" – [On Vista machine only]
"serial port timeout"
"No Protocol Array and Protocol not in Table program can’t continue"
The Garmin interface is set to "Garmin" and the transfer mode is set to "Host".
I know the serial port to USB converter lead is working correctly as it successfully connects to an .ICG logger.
The PC has Microsoft ActiveSync with the "Allow serial cable or infrared connection to this COM port" unticked so it doesn’t interfere with the other com settings. Also, it may be relevant that I connect to the internet on both computers via a modem through a USB port, but the problem persists even with the USB line to the modem disconnected.
Any help you can give me would be greatly appreciated,
Thank you in anticipation,
Tony Crowden.
  • 1,606 Answers
If it were doing this just on the Vista machine I would say it was Vista related but since you are getting it from an xp machine as well the problem is either cable or the gps unit. You don;t say if this just started happening or ? If you can try out the cable on something else to make sure so you can eliminate it. About the only thing you can do is to make sure the port settings in the pilot are set correctly. Generally the slower the better if you are having communication problems as this makes the signal timing not as critical. Try 9600 baud to start. Make sure that the data bits are also set roght. This is the 8n1 or 7n1 thing you see. I can;t think of what the default is on the garmin but as long as both pc and garmin have speed, bits, parity, and stop but set the same they should talk.
Try to download from the unit as well as upload.Unfortunetly you can only change the speed and protocal or reset the unit. You won't be able to fix it if is a hardware thing. If you are using a USB to Serial adapter then I would say that is your problem or could be. Cheaper ones just don't work often on higher port speeds. You might want to try the gps on a pc with a actual serial port if you are using one. If it works then you should try a different brand of adapter or really slow down the speeds.
This won;t solve it unless you luck out but it should let you know where the problem is.
Posted on Mar 09, 2009
Computer not acknowledging garmin gps
Are you using a Mac or PC and which OS with any service paks?
Try Install the Garmin Communicator Plugin.
You may also want to contact Garmin Support for assistance.
Nov 04, 2011 | Garmin Nuvi 2300LM GPS Receiver
I have a street pilot C330 Garmin - I am trying to update with the latest maps, etc - but I am confused on how to do this. Please help - I am very happy with this Model and mostly because it is user...
Register your Garmin at - from here Garmin guides you to download the webbrowser plugin to communicate with your Garmin StreetPilot C330 over a USB cable.
When your Garmin StreetPilot C330 is connected through your webbrowser - it will show compatible map updates. These can be ordered on DVD or downloaded.
Note that downloading the map update will take a very long time and requires at least 5 Gb of disk space on your PC/Mac. The internet connection needs to be fast and stable enough to complete the huge download. Otherwise its better to order the update through DVD.
Jul 09, 2011 | Garmin StreetPilot C330 GPS Receiver
Battery charging with computer. Do I have to leave the unit on when it's plugged into the computer Garmin Street Pilot C330
Yes just leave the unit power ON and when the charging is done the unit will stop charging automatically.
Jun 17, 2010 | Garmin StreetPilot C330 GPS Receiver
GPS III Pilot? will not power up
Try the dc plug too (also make sure the battery connections are good in the caste). IF still no power up, the internal battery may be shorted. Lots of info online for replacing the internal battery. Good Luck!
Sep 13, 2009 | Garmin GPS III
I need an owners manual for our garmin 360 street pilot gps
Here you go
Apr 01, 2009 | Garmin n vi 360 GPS Receiver
Garmin Street Pilot C330 - Produces Deafening Noise!
suddenly froze can not turn it off what to do thanx
Jul 27, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin street pilot c340 battery appeared low, used USB cable to hook up pilot with my computer but device doesn't appear to turn on, computer cannot locate device on Drivers, can I rechare steet pilot...
I followed the instructions of the Online manual for the Garmin Street Pilot c-340, I removed the faceplate of the Street Pilot and then using my thumb pressed down on the reset button. I then pressed the power on button on the side of the device- the screen lit up, I then plugged one end of the USB cable into my computer and the other end into the device. The information on the screen of the device indicated the Lithium Battery was charging properly.
Jul 14, 2008 | Garmin GPS
Update 2009 for Street Pilot c330
2009 upgrade data is too large for garmin 330 must have sd card
Jun 08, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin Street Pilot III map source data card not accessible
Garmin has issues with the newer (ROHS Compliant) cards, so If you recently bought this card get a replacement from garmin.
I had these issues too with a 256 MB, garmin replace the card with 2 128MB cards, worked fine after that.
Mar 26, 2008 | Garmin Streetpilot ColorMap GPS Receiver
Garmin GPS III Logo
777 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
