Question about Goldstar MV-1715 1000 Watts Microwave Oven
Heat up Mic.goes through motions,(sounds & lights)but fails to heat up.HELP
  • luckyluca1 Jul 11, 2008
    Gold Star MVH1670ST
    Aug.2007
    ser#708TAQP01532
    As I stated,The unit sounds normal, like it is running
    It lights up inside,turn table and all the dial lights work
    It does everything but get hot
    thank you,luca
  • William Miller
    William Miller May 11, 2010
    Do the inside light and turntable come on when you try to cook?
    Is it making any unusual noise or is it louder or quieter than normal?
    Please reply back with your brand and model number so we can help you.
  • Goldstar Master
  • 9,098 Answers
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
In this case, the magnetron is the most likely suspect, but other suspects would be :
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit http://www.lgservice.com.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 11, 2008
Magic chef microwave just stopped heating, can you tell where the fuse is so i can check it, and i am open for any suggestions. model # hdm111ow
Sounds like the magnetron has failed, if it were the power supply or capacitor or fuse, it would have failed to heat straight away, not faded out. Probably more economic to replace the machine.
Feb 22, 2017 | Magic Chef Microwave Ovens
After many years of good service my Dimension 4 does not microwave. It goes through all the motions but doens not heat the food. the convection and grill functions are working fine. HELP!
Hi Michael,
i think something wrong with its high-tension circuit or your magnitron is bad.
the minor fault is open of therm stat for protection.
or burnt fuse in circuit.
regards,
nuwan.
Jan 09, 2014 | Panasonic NN-T888S Convection/Microwave...
Microwave taking much longer to heat food
The microwaves are produced by what is known as a KLYSTRON TUBE. Like anything, early failure is possible. There is also the possibility that the transformer or electronic circuit providing the correct voltage to the KLYSTRON has failed, either from over-use, manufacturing defect, or leakage from the KLYSTRON enclosure, which creates heat.
With microwaves being as CHEAP as they are, replacement should not be an issue.
Feb 03, 2010 | Microwave Ovens
Model #GLEB27M9FBB. Microwave interior light goes
Sounds like you Magnetron or PSU has failed, or perhaps it is just a sensor.
DO NOT try to repair this yourself.
These items MUST be repaird by an authorised person. They are leathal!
Take it to a reputable repair shop and get a diagnosis.. more often than not, though, it is cheaper to simply buy a new one. Oh get a warrenty too.
Jan 18, 2010 | Microwave Ovens
Microwave does not heat. The light goes on, the turntable turns, it makes a sound and beeps when done. It just doesn't heat.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
dytdt
Oct 12, 2009 | Dacor PCOR30 Convection/Microwave Oven
Loud pop and microwave doesn't heat anymore
I have a GE Profile Spacemaker model JVM3670WF001, purchased I think in 2003. Pop sound, no Heat. Light goes on, carousel goes around,
Repair or new microwave
Jun 03, 2009 | GE Profile Spacemaker Over-the-Range...
The micowave will not heat or cook anything
PLEASE HELP ME TO FIX THS PROBLEM....
Mar 10, 2009 | GE Microwave Ovens
Microwave turns on goes threw the motions but wont heat up..
If it is running, including plate rotating, and there is no heat, then you need to replace either a part called magnetron, or one called high voltage capacitor (HV cap.).
The magnetron is located behind a protective plate on the internal side of the owen. The high voltage capacito is in microwave circuits behind the main wall.
Both parts are not expensive.
Here you see a general diagram, and you can also buy the parts. Browse with the mouse on top of the picture to see the magnetron.
Here you can also get parts and diagrams.
See also here.
If you want to call atechnician you can use the number listed on the owner manual.
Oct 11, 2008 | GE JVM2050 Microwave Oven
Kenmore 89942 Microwave no longer heating food
Grass...I'd go for checking the fuses and the thermosensor...a black plastic button with two wires coming out of it that is about the diameter of a dime and 3/8 inch thick. If either is open, no power to the magnetron. Your unit may have a diagram inside. Have a look. The magnetron...? I doubt it.
Dec 16, 2007 | Kenmore 80882 Microwave Oven
Sharp Carousel Convection Microwave R-9H56 suddenly stops heating
at highvoltage section wiring may bae problem, check wiring and connectrors of magnetron and capacitor and transformer.
Dec 11, 2007 | Sharp R-510HW Microwave Oven
Microwave Ovens Logo
73 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
