Question about Compaq Presario Notebook
Compaq presario A75206OM
The computer will not connect to the internet via the internal nic card and the sound doesn't work. I have tried re-installing the drivers but cannot connect to the internet or get the light which indicates a sound problem to go off. I just cleaned the machine up after it was attacked by the pcprivacy virus.
  • 813 Answers
Hi friend u need to contact 24 hour hp chat technision support
Posted on Jul 10, 2008
New motherboard makes my wireless nic loose signal.
It sounds like a driver issue.
I assume you mean the card worked previously on an old motherboard.
Remove the wireless NIC driver and then re-install it. I assume their are no yellow exclamation marks agianst your NIC in windows system properties? To see sys properties right-click "My Computer" select Properties/Hardware/Device Manager. Look for the network adaptors section. You can update drivers from here on your wirless card or even try the Troubleshooter tab.
if you don't have the driver CD let windows go onto the internet and search for a driver.
If you rely on the wireless card to connect to your internet connection, perhaps you can connect your computer to the internet modem or router via your computers LAN/network connection?
If that's not possible, download the driver from the NIC cards manufacturer website and pop it onto a USB thumb drive which can then be installed onto your new computer.
Last thought, make sure you are only using one controlling application for your NIC ie you use either the Windows Zero Config Utility OR the NIC cards manufacturer utily eg D-Link, Netcomm, etc etc
That is not both at once as windows has a major hissy fit.
See:
http://forums.whirlpool.net.au/forum-replies-archive.cfm/438290.html
http://www.netcomm.com.au/__data/assets/pdf_file/0020/17291/61_Using.pdf
http://forums.whirlpool.net.au/forum-replies-archive.cfm/1378157.html
Cheers,
Steve
Mar 07, 2010 | Abit AV8 Motherboard
Dell Inspiron ethernet card plug bad, either send tower to Dell for 3 weeks or replace and bypass with new ethernet card PCI, any problems with doing this?
There should not be any problem with you buying your own PCI ethernet card and install it yourself. They are not that expensive. www.newegg.com has on for only $7.99 and it will work fine in your computer. It does not need to be from Dell.
Nov 19, 2009 | Dell Ethernet Card Network Adapter
Hello!After reinstalling WindowsXP on my computer (Had problems with viruses) can not connect to the Internet. O2 Installation CD says FAILED NETWORK ADAPTER. When selecting Control Panel and then Network...
I would check out the Internet for the updated driver for the NIC in the suspect machine, download it on another machice, copy over with flash disk. Remove the driver, install the new driver, **** down, reboot. If there is nothing physically wrong with the machine and you just re-installed the OS, sounds like you have a corrupted device driver for you NIC.
Sep 19, 2009 | Computers & Internet
I have a dell deminsion 3000. I have high speed
ya sure u can.
i don't know why people are afraid of such things.
Aug 14, 2009 | Dell Ethernet Card Network Adapter
How do I replace the nic card in my computer?
a Nic card is a simple device (Network Interface Card) presumably a desktop machine I suppose. Just go to a local ABC warehouse or Walmart and by a new Network Adapter "NIC" PCI card and install with the drivers provided. Should be around $12-25.00 depending on the model... this should work:
http://www.walmart.com/catalog/product.do?product_id=2067722&findingMethod=rr
Aug 04, 2009 | HP Pavilion 523n (P9851AR#ABA) PC Desktop
My computer (Dell) unknow Network Card
i) Click on Start button ---->Select option Control Panel------>Select Network Connections----->
  a new window appears showing the "internet connections icon " Such as:
  Local Area Connection 1 or 2 or 3 and since you are not connected it will show this icon as:
eg1: Local Area Connection 1 or 2 or 3
  Network Cable Unplugged, Firewalled
  VIA compatible Fast Ethernet
  in this case u can download VIA network drivers....from internet..
  or
  eg2: Local Area Connection 1 or 2 or 3
  Realtek RTL8139 Family Fast Ethernet NIC
  in this u can download "Realtek RTL8139" network drivers.... from internet(which is showing model     no: RTL8139 through google search engine )
        (OR)
ii) Click Start button ---->Select RUN option ----> type in the text box devmgmt.msc --->Select               Network Adapters....
    but this will show wheter ur network adapter or NIC is VIA or Realtek or......but doesnt show the           correct Model NO: of VIA or Realtek....
    so i would suggest to follow the step (i)
Thanking you
M.Sridhar
Dec 25, 2008 | Dell Ethernet Card Network Adapter
Dell Ethernet Network Adapter not being recognised
                      or
                                         (OR)
           but this will show wheter ur network adapter or NIC is VIA or Realtek or......but does show the             correct Model NO: of VIA or Realtek....
Thanking you
M.Sridhar
Nov 23, 2008 | Dell Ethernet Card Network Adapter
Can I add a NIC card to my compaq presario pc sr5250nx? I keep loosing my internet connection every five minutes and have to reboot the computer to reconnect
you should be able to
http://h10032.www1.hp.com/ctg/Manual/c00840496.pdf
if your system is still within warranty I would think twice about opening the case yourself to installing a new network card.. you will be voiding your warranty.. so think about it
another thing i would try before deciding on going for another network card is to check your onboard network adapter has updated drivers... or you may want to reinstall the drivers for that adapter.. either one of those may probably fix your issue assuming is not a hardware failing given that your system may not be that old.... make sure you check the windows update and look for any new hardware driver for your network adapter that may be avaliable through windows update.
before you install your new network pci card you may have/want to disable the one on board going into your bios for that. so to ensure there's no resource conflicts when installing the driver for your new card (it may not be a problem even if you don't but if you run into problems while installing the new card consider this suggestion)
Oct 02, 2008 | Compaq Computers & Internet
Network adaptor and lack of sound
It sounds like you need to install the drivers for your NIC and your sound card.
Since you won't be able to connect to the internet with that computer until you have the NIC drivers, you will have to download them from a different computer, and copy them to a memory stick (pen drive) and then load them into your computer.
You will need to know the type of network card and sound card you have to be able to download the correct drivers.
Aug 30, 2008 | Computers & Internet
Installing internal board dell d600 nic hardaware
The wireless card bay is located under a panel on the bottom of the machine. It will have two leads (wires) the plug onto it. There will be only one place that the card fits and you will know it when you see the two wires. After installing the card, then you will need the drivers in order for it to work properly, you can find the drivers at driverguide.com using the make and model of the card. Also, the two leads will only work properly if connected correctly. The card will work if connected wrong but the reception will be lousy. If you find that you're not getting a good signal after everything is installed and working, try switching the wires.
Jun 25, 2008 | Dell Latitude D600 Notebook
Compaq Presario Notebook Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
