Question about Olympus Audio Players & Recorders
Olympus Digital Recorder
When I try to save my files to my computer, I'm having a problem getting the folders to appear on the screen. I know it works because I have used it before with absolutely no problem. Up until today, things were fine. Please help!
    Problem Solver:
  • 7 Answers
Does it show up as a removable drive, it should. If the computer "sees it" but the software dosent, try this.
Go to Disk Manager and find the drive it thinks it is and verify by un pluging and re pluging . Reassign this drive letter to one that is not used, further down the alphabet, away from any mapped drives.
I have run into this on several ocasions and this is the fix to get its own (always) drive letter.
Posted on Jul 16, 2008
Olympus ds 40 can't display recorded voice folders on pc
There are a total of eight folders in the recorder that are in a tree format. Under the “Root” folder
are “Folder A” through “Folder E”, “Audible” and “Music” folders, and recorded or transferred
Language and music data from a computer can be saved as “files”. “Folder A” through “Folder E”
are voice-recording folders, so choose one of these five folders when recording on this recorder.
Up to 200 files can be saved in each folder, and up to two layers can be created within the “Music” folders.
Feb 14, 2010 | Olympus DS-40 Digital Voice Recorder
Olympus DW 90 VN series. I have been using the
get switch audio converter software from www.nch.com.au
works for us like a charm
Aug 30, 2009 | Olympus VN-4100PC Digital Voice Recorder
I deleted date from Olympus VN-4100PC
When the Digital Wave Player application copies the files to yourcomputer, the default location is under My Documents>Digital WavePlayer>Message. There, you will see FolderA, FolderB, etc. +Recording & Schedule folders.
If the files are not there, use a file recovery application, such as PhotoRec to recover the deleted files.
Jun 21, 2009 | Olympus VN-4100PC Digital Voice Recorder
The Olympus DS-330 read only memory lock
You may need to format the recorder to clean the file system on the recorder. Follow the directions below to format: If you format the recorder, all function settings will return to their defaults*. All files** stored in the recorder will be deleted. If you have important files that you want to save, connect the recorder to a computer and transfer those files from the recorder to the computer before formatting the device. * Date and time settings won't be cleared, so you won't need to set them again. ** Locked files will also be deleted. 1 Press and hold the FOLDER/MENU button for 1 second or longer. The menu opens. 2 Press the up or down arrows button to choose "FORMAT". 3 Press the REC/SET button again. 4 Press the FF or REW to choose "START". 5 Press the REC/SET button. Formatting starts. "FORMAT DONE" displays when formatting ends.
Jun 11, 2009 | Olympus DS-330 Digital Voice Recorder
Digital voice recorder connection problem
There are many steps in installing Digital Wave Player on VISTA, it is important to follow every step since installing Digital Wave Player on VISTA is dependent on this process.
Install a VN recorder on VISTA
1. Make sure the device has been uninstalled in device manager
2. Make sure the old version of digital wave player is uninstalled.
{Delete Temp files in Internet Explorer --Tools--Internet Options --Delete Files-- Delete offline content--OK}
3. Install digital wave player (The newest Version).
http://www.olympusamerica.com/files/DigitalWavePlayer.zip
4. Install the 2.1.4 vista update
http://olympusamerica.com/cpg_section/software_results.asp?id=1291&os=w
5. Restart the computer.
6. Plug in the VN recorder to the USB port and turn the recorder on.
"Found new hardware" will appear,
7. install automatically.
This may fail, if you see VNUSB device, skip the final steps and proceed to Digital Wave Player to Download files from the Digital Voice Recorder.
If you will see "Other devices" listed in Device manager with "digital voice recorder" underneath it.
8. Right click on the "digital voice recorder"
9. Select update driver from the pop up menu.
10. Choose the browse computer Option
11. In the next window browse to the location that you downloaded the Digital Wave Player application to
12. Click Next
A security warning window will open,
13. Choose "install anyway" and the device will install.
When successfully installed you will see the "other devices" disappear and a VNUSB device with a "VN series device"
underneath it appear at the bottom of the device manager list. There will be a blue question mark next to the device. At this point you can close the device manager and the properties window and open Digital Wave Player. You will see the recorder listed underneath the recorder folder and be able to download and use the program normally now.
Jun 02, 2009 | Olympus VN-2100PC Digital Voice Recorder
Olympus WS-100 Handheld Digital Voice Recorder I uploaded all my files onto my mac laptop and deleted them from the recorder. now when I turn on the voice-recorder, the screen says that "no...
Have you tried to go to the menu and format the voice recorder? This should reset the recorder back to its factory default settings. If that does not happen then the recorder may need to be sent for repair as Olympus would have to reimage the device.
Dec 05, 2008 | Olympus Computers & Internet
How do I transfer files to computer from Olympus VN-3100PC?
11. Browse to the location on your computer where you downloaded and saved the Digital Wave Player files from Step 3
12. Click Next
Nov 29, 2008 | Olympus VN-3100PC Digital Voice Recorder
Unable to transfer recording from File B
All files should be set for transfer when using the Olympus software.  There is a way you can check folder B in my computer by locating the program folder where the olympus software resides.  If folder B is empty, the recording could have landed in A, C, or D folder.
Oct 07, 2008 | Olympus VN-2100PC Digital Voice Recorder
Olmpus Digital Wave Machine Files
In the program folders of your computer is a folder called Olympus. In that folder, there are four folders for audio files. They correspond to the audio folders you have on you voice recorder. Each file is save with a time a date stamped file name. The files should be saved as wavetable file or wav. These files can be played using windows media player and can be emailed under most cases as well provided the file size for the attachment is acceptable to the recipients e-mail address.
Usually what I have to do is link the folders using ITues. Then files can be synched and converted to mpeg3. That way if someone wants to listen to them on an Ipod or any other mp3 player there easy to transport.
Let me know what you find.
Tim
Aug 03, 2008 | RCA RP5010 Digital Voice Recorder
Files do not appear on PC
the computer not support the file format. use DSS player to convert the file format to wav and then to any other audio format. or use the SONY LAS VEGAS 7.0 OR 8.0 to convert it into required format.
best of luck.
Dec 14, 2007 | Olympus WS-100 Digital Voice Recorder
572 people viewed this question
Top Olympus Audio Players & Recorders Experts
pankaj rautela
pankaj rautela
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
