Question about GE Washing Machines
WE HAVE A GE TOP LOAD WASHER, MOD.#WCSR2070T6WW. RECENTLY, IT WILL GO THRU ALL CIRCLES BUT WON'T SPIN. IT STARTS TO, BUT WITHIN 5 SECONDS, YOU HEAR A CLICK AND IT STOPS SPINNING. I PULLED THE FRONT PANEL. THE PUMP IS WORKING FINE. I ALSO CHECKED AND ADJUSTED THE LID SWITCH AND IT STILL DOES THE SAME THING. DO YOU KNOW WHAT COULD BE WRONG? HELP.
  • 481 Answers
  • it could be a problem with the water level switch; this switch keeps it from spinning until the water has drained.
  • or the motor itself could be bad.
  • the click you hear is probably the start switch on the side of the motor kicking off due to the motor pulling too many amps.
Posted on Jul 10, 2008
GE top load profile washer won't spin. It starts
The tub hangs on 4 support rods. Lateral movement is kept in check with 4 bungy cords bolted to the top of the tub. If that washer is not level the tub will hang to one side and the fancy controls will declare an error. Make sure all your rods are good (they drag the base of the machine when worn out and make a heck of a racket) and the bungys are not stretched and the machine is level.
Aug 04, 2012 | Washing Machines
Ge top load washer won't agitate or spin after
what is your model number is then we can started then okay
Sep 15, 2011 | GE Washing Machines
Washer fills up and starts. Once it gets to rinse cycle and spin cycle is makes a loud humming noise but wont spin. If i open the top lid and wait a second or two and close it, it starts the cycle. Been...
If you have a direct drive washer made by Whirlpool, your washer transmission has what is called a neutral drain built into it. It is designed to pump water out before it starts to spin. After water has drained out, the timer has a pause in it where motor shuts off for about 5 seconds. When motor comes back on, transmission is then in gear to spin. If timer never pauses, then washer never goes in gear to spin. Timer is most likely defective.
Sep 14, 2017 | Whirlpool WTW5100S Top Load Washer
Put in load with which must have been to heavy, washer didn't spin out clothes, tried to put through another spin cycle, won't do it. unplugged washer, tried restarting cycle after removing clothes, will...
You can try to reset control board///unplug washer for one min/plug unit back in within 5 seconds open and close lid 5 times after you do that wait a min then unplug wait a min plug back in and lets hope she works..hope this helps good luck need more help contact me.. thanks for voting
Mar 21, 2011 | GE Profile WPRE6100G Top Load Washer
My GE washer (mod WHSE5240D0WW) will not spin. It
sounds like the motor or the programer has packed up on you more (likley to be motor,) buzzing is the motor trying to turn but cannot,
Oct 26, 2009 | GE WHSE5240D Top Load Washer
Spin Basket Spins Along with Agitatdor in GE Profile Washing Mach
if washer is newer version remove front panel and ck if has a gearcase it's probably bad if it has what ge calls a mode shifter it's probably bad it has a coil with connection to motor bd..look on bd for flashing green 4 flashes means open mode shifter coil
Dec 17, 2008 | Kenmore 24032\24036 Top Load Washer
How do you reset the washer?
I have a GE WBSR3000GWS Model and it stopped spinning at one point as well. My service guy came out and did the procedure below and reset it with in minutes.
How to Reset your GE Washer :
1. Turn the dial like your going to wash a load but do not pull the knob.
2. Unplug the washer from the wall and wait for 30 seconds.
3. Plug the washer back into the wall.
4. Lift the lid 5 times to at least 6 inches high. Open/Close within 15 secs.
5. Pause… You should here a click. If you do not, then repeat 1 – 5 again.
6. Insert a towel or garment into the washer and then pull knob to start the wash cycle.
7. Check the wash cycle to make sure the washer is agiating and spinning during its cycle.
GE Answer Center : 1-800-626-2000 opt 3 - for more information
Lale
Jun 20, 2008 | GE WBSR3140DW Top Load Washer
Drain pump starts and stops prior to final spin cycle
Jayron, is the motor jogging? start to spin, stop, start to spin stop. If so, your motor is jogging between the high and low start windings. The motor during spin should start on the high speed windings and stay there until most of the water is drained. GE came out with a new motor, harness and run cap because of this. If you have a meter, there should be a white and white/red wire going to the motor. If you have a steady 120V and it's doing this jogging, replace the motor with the kit...Let me know if this the issue, Catriver..post back.
Nov 05, 2006 | GE WWSE5200B Top Load Washer
Washing Machines Logo
70 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
