Question about Frigidaire ATF6000ES Front Load Washer
Mine just started - same Model ATF7000ES!
Did you get a solution to this problem?
I have a Frigdaire Gallery model front loader. It is leaking underneath the machine. It is 7years old. Does this model haave a history of rusting out? Roy Ingham
Posted on Aug 02, 2008
We have a frigidaire model atf7000es, it just started when the cycle starts it goes to perm press no matter what starts at 48 goes to 32 stops than goes to 38 starts back to 32 and repeats its self
Hello Ken, thank you for your post!
I understand that your Frigidaire washer is going directly into the perm press cycle no matter which option is selected. I would suggest performing a reset on the washer and you can do that by disconnecting the power from it for at least ten minutes. If the reset does not correct your issue, you may need to have the control panel or a wiring harness replaced. If you need help disassembling your washer I would recommend seeking a professional technician. You can locate a technician by contacting your manufacturer. Hopefully this information is helpful to you. -Matt
Apr 26, 2016 | Frigidaire Washing Machines
Our dryer says it locked how do I get that off
Good Morning Friend,
I understand that your Frigidaire Affinity dryer, model# ATF7000ES, states that it locked and you want to know how to get it off. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
Jun 23, 2014 | Frigidaire Affinity ATF7000ES Front Load...
Machine starts beeping when not in use
Good Afternoon Eylene,
I see that you are having trouble with your Frigidaire Affinity washer, model# ATF7000ES, beeping while it is not in use. I suggest giving your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for at least 2-3 minutes. When power is restored to your washer, if it is still beeping while not in use, I suggest you contact your local authorized technician. I hope this is helpful.
-Best Regards-
Apr 18, 2014 | Frigidaire Affinity ATF7000ES Front Load...
I need to know if there is a drain on the bottom of my washer that should be cleaned once a year
Most washers have a filter which needs to be cleaned often .unfortunately i am not familiar with your model
Jun 10, 2010 | Frigidaire Affinity ATF7000ES Front Load...
How to diagnose
Sounds like your motor is blown. That's going to require a repairman.
Mar 31, 2009 | Frigidaire Affinity ATF7000ES Front Load...
I am experiencing an error code during my wash cycle of E10... I have a frigidare affinity series washer.
Clean the cold water filter on the back, then try again. This should work. Mine was doing the same thing and the repairman had no idea what it meant.
Jan 08, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire Mod ATF7000es
if its the electronic control model the control panel board bad
Jan 22, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
101 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
