Question about LG WM-2277HW Front Load Washer
Thank-you Just wanted to thank-you for your solution to the LG 8013F washer that wouldn't spin or drain properly. I'm in Australia and I did what you suggested in removing the front left hand lower panel and declogged the lint filter (bath mat passed it's prime) and now it works a treat. You're a legend! Thank-you again
  • 489 Answers
You're very welcome.
Posted on Jul 23, 2008
The washer will drain but not completely ..leaves a litlle bit of water in machine
Make sure the spin is working. If its not working you wouldn't know it since it spins during the middle and end of cycle.
If not check lid switch
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 17, 2011 | Frigidaire FEX831CS Top Load Stacked...
My front loader washer gets stuck on its last spin and wont drain properly. I am trying to wash a comforter and blanket. This is the 1st time its happened. Thank you
You may to mention the brand and model of machine. Mine is an Lg, I just shut off machine. Turn it back on and then press the no spin and start, this drains the washer. You may have too much clothes in the machine.
Mar 06, 2011 | LG WM-2277HW Front Load Washer
1 1/2 year old lg WM2496H showed oe error code while washing a heavy unbalanced load. I removed the wet blanket (sitting in water) and tried drain/spin command with empty washer but washer will not go into...
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!!!!!!!!!!!!
Jun 09, 2010 | LG WM2496H Front Load
Lg intellowasher wd-8013f is very noisy
You suspect right.
It is a complete strip down job. I have just finished mine.
taking apart and reassembling is not too dificult.but you need to make up a tool to remove and replace the bearings which are two different sizes. It consists of a lenghth of studding, bolts and washers.
Download the manual from LG.
Good Luck
Mar 17, 2010 | Washing Machines
LG WD 8013F drains then won't spin
  • Hi,
  • Try these:
  1. Test the lid switch
  2. Test the timer control
  3. Test the centrifugal switch
  4. Test the water level switch
  5. Inspect the motor coupler
  6. Inspect the drive belt (belt drive only)
  7. Inspect under the washer for soot (clutch)
  8. Test the motor
  9. Inspect the pulley
  10. Test the transmission
please rate my suggestion...
May 21, 2009 | LG Washing Machines
I have a LG WF-764STP which wont spin the clothes or drain properly after. Where is the filter?
THE NUMBERS YOU HAVE PSOTED YEILD RESULTS FOR ALL TYPES OF APPLIANCES AND IS DIFFICULT TO HELP. SEE AND POST THE CORRECT MODEL NUMBER OF YOUR WASHER FOR FURTHER ASSISTANCE.THANK YOU
Apr 24, 2009 | LG WFT1071TP Top Load Washer
Washing machine will not spin
HI mate , if your model is an LG 8013F . I had the same problem . evrything is control by the CPU and it cannot be repaired .
What i had done is to replaced the Control board completly and it works perfectly .
I have one unit extra if u are interested let me knw , i can sell it for $60 + PP
THanks
Hans
Nov 13, 2008 | Washing Machines
Lg Front loading washing machine
most times on the Lg washer the lint trap is clogged and something may be hitting the impeller on the pump and causing it not to drain. remove the plastic cover on the lower left bottom and unscrew the black lint filter at the pump. you will get water on the floor there is no way to avoid that. clean the trap and make sure there is nothing inside the housing to block the pump impeller. replace the trap and run a rince cycle to check for proper draining.
Aug 04, 2007 | LG WD-1080FD Front Load Washer
LG WM-2277HW Front Load Washer Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
