Question about Dryers
Kenmore dryer model 11097320100 spins but doesn't heat. I have the breakdown diagram and a meter. What parts do I test for continuity?
  • 481 Answers
First check to make sure you are getting a full 220v at the outlet (if  electric dryer). then check every switch you see in the back of the machine for continuity. the only one that will not need continuity is the resister near the cycling thermostat. kenmore dryer model 11097320100 spins - 8c25d6a.jpg
Posted on Jul 10, 2008
Six year old kenmore clothes dryer spins but won't heat
Dear Lynn,
Clothes dryers today have many safeguards built in to prevent overheating and fires.
First , I'll tell you the most likely cause of the problem, then move on to the other causes.
Most likely is a failed heating element.
You can check this by removing the back of the machine, and take a multi-meter or an ohm meter and test the heating element for continuity, (with the wires removed from it.)
Next most common is a blown fuse or an overheated thermostat. (There may be as many as 5 on your machine)
If you discover either the fuse or one of the thermostats has failed, you should check further to be sure all the vent pipes are clear, both inside the machine and from the machine to the outside air.
Each of these need to be checked with the meter, just like you did with the heating element.
Unplug the wires, and check for continuity.
Least common is a broken or burnt wire.
The element, the fuse, and the thermostats are available from an appliance parts store, or from "Sears Parts Direct" online.
God bless your efforts.
Nov 09, 2015 | Kenmore Dryers
Dryer spins but no heat
Conventional dryers are usually accessed by removing the rear panel. I would think these would be the same. Unplug the dryer and remove wires from heating element. Test for continuity with an ohmmeter. If there is no reading, the heating element is bad. Disconnect wires from the hi temp thermostat and test with an ohmmeter and if no reading it is bad. Sears has these parts available.
Nov 07, 2013 | Kenmore Dryers
2001 kenmore elite dryer is not heating
Hello there and welcome to fixya
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. To determine if the heating element is burned out, watch the part testing video at the bottom of this page. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) To determine if the thermal fuse has blown out, watch the part testing video at the bottom of this page.
Dec 31, 2011 | Dryers
Sears Kenmore dryer model number 96310100 runs but not heating. How do you check the thermostat??
Click on the below link to see the diagram where the thermostat is located.
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11096310100/0582/0151200/00064690/00002?blt=06&prst=&shdMod=
Part number 8 is the thermostat on the diagram. If the unit is not getting hot, you can use an Ohm Meter to check for continuity. If the thermostat reads open or no connection, the unit is bad. If you do not have an Ohm Meter you can temporarily tape the connection on one of the thermostats leads to the other to see if it starts to warm up. I would suggest you use electrical tape and perform this operation with the unit unplugged then plug the unit back in order to test it. Do not run the dryer for more than a few minutes, or you may have to call the fire department. If it warms up after a few minutes the thermostat is defective and needs to be replaced.
Jan 06, 2011 | Dryers
Dryer wil not spin
Hope this info helps, ps don't forget to give me a rating thanks!!
For an electric dryer that runs but doesn’t heat, follow this repair roadmap:
Flip the circuit breaker off and then back on. Electric dryers run on a two-pole, 240v breaker. A common problem is for one of the legs to break which cuts the 240v that the elements need to heat up but it still supplies the 120v for the motor. The result is that the dryer runs but doesn’t heat.
If the breaker checks out, then it’s time to do some surgery. Unplug the dryer and open it up.
. Use your ohm meter to test the thermostats. All should show continuity.
Measure the resistance of the heating element with your ohm meter. Normal readings are in the neighborhood of 30 ohms.
In rare cases, the centrifugal switch in the motor can fail which breaks the power circuit for the heating elements. If this is the case, then the entire motor must be replaced since the centrifugal switch is built into the motor.
May 08, 2009 | Dryers
Kenmore gas dryer model #76812690 will not heat.
does the dryer heat initially when you first turn on the dryer Or no heat at all?
the first thing i would check is tthe thermal fuse thats located on the back of the unit. test it with a multimeter and see if it has continuity, if it doesnt then replace that and your operating thermostat. the check to be sure you venting to the outside of your house is not clogged
Apr 29, 2009 | Kenmore Dryers
Kenmore dryer 62932 wont heat
repairclinic.com has a comprehensive parts diagram for almost any machine. A dryer with no heat is a very common problem, there are several thermostats and safety cutoffs that can make dryers not heat. Thankfully they are reletivly easy to diagnose. All you need are some basic hand tools and most important, an ohm meter. Most of the time all the thermostats will be in one section of the cabinet (top, bottom, back) to test them, make sure the power is OFF, unplug the wires from the thermostat(s) and put one lead of the ohm meter on each connector, if it shows anything put 'ol' or open line, your thermostat should be good. Keep going until you find the faulty one. If all thermostats test good, try testing the element(s). the element is tested in the same manner as the thermostats, if it tests bad, replace it and enjoy doing laundry!!
Jan 22, 2009 | Kenmore Dryers
I have a Kenmore Elite Model number 110.64992300. The dryer turns on and spins but does not heat. I have the bottom panel off am looking at the heat element. What should I do to test everything? I have a...
You need to make sure you have 220V first all the way to the dryer. Make sure you have no blocks (lint blockage). Check your thermostats for continuity. Make sure all the wires are disconnected when testing. If they show good check your heating element not only with the ohm meter but take it out and visually inspect it. They can be bad and show continutiy.
Jan 07, 2009 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
73 people viewed this question
Top Dryers Experts
