Question about Energizer ER-HM650 UPS System
Shuts off when power goes out
My UPS immediately turns off, along with everything plugged into it, as soon as the power goes off. It doesn't keep things on for 16 minutes or anything. I have to look for purchase info to see how long I had it.
Rose Coen rose.coen@verizon.net
Replace the battery here is a battery from a decent seller http://www.refurbups.com/s.nl/it.A/id.9156/.f there are 5 phillips screws in the bottom, flip it back over and pull th lid off carefully, pull out the battery wires (they are snug) and put in the new battery and put the screws back in.
Posted on Jul 18, 2008
Not Working During Power Outage
Bad battery in the UPS. To test unplug all equipment. Check outgoing power with voltage meter. Should read around 115vAC. Then unplug from the wall outlet. Check voltage again. If no voltage is present its a bad battery.
Sep 04, 2013 | CyberPower Computers & Internet
New motherboard still no power
Remove the main battery and try again, next sub out the ram one at a time and test, I would sub out the power supply to be sure it is basically the only thing left.
May 07, 2012 | Dell XPS M1330 Notebook
Error light in my apc smart ups sc 1500va ups
1. Four beeps every 30seconds (On Battery LED will be illuminated)
This alarm indicates that the Battery PowerSupplied outlets are now supplying battery power as opposed to power from theutility. If the UPS determines that the input utility power is unsafe for yourcomputer equipment, the UPS will switch to battery power.
Note: Ifthe power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will beilluminated)
This alarm indicates that a Low Batterycondition has been reached and that the UPS will soon shutdown. Once the UPStransfers to On Battery operation, it can only stay on battery for a limitedamount of time. The UPS will sound this alarm about two minutes before thebatteries are totally exhausted. Once exhausted, the UPS will shutdown and turnoff its output power to your equipment. If you hear this tone you shouldimmediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (BackUPS OFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected anOverload condition after it has performed a self-test during start-up.
4. Continuous Two-Tone Beep
This alarm indicates a severe Overload wasdetected while the unit was on-battery operation. This tone will continue tosound until the unit shuts down.
5. Continuous Tone (On Battery LED will beflashing)
This alarm indicates that the battery-poweredoutlets are overloaded.
6. Continuous Tone (On Line and On BatteryLEDs flashing) Back UPS OFFICE 350,400, and 500 ONLY
This alarm indicates that an internal UPS faulthas occurred.
Dec 08, 2011 | APC Smart-UPS SC 1500VA UPS System
Hi, I have an Opti-UPS ES 1000C. When power goes off, it beeps and shuts down. Everything plugged into it shuts off. It does not convert to battery power. What's wrong?
The Batteries are bad. It can't convert to battery because the batteries are bad. Plug the UPS back in then pull the plug. If if goes off the batteries are bad
Sep 06, 2011 | Opti -UPS PowerES 1000 UPS System
How do I set up my Ups? When I try to test it, it turns everything off. And when the power goes out, it shuts off everything.
You must install the software that came with your UPS on the computer that will be connected to the UPS, either via serial or USB. Within the software you can configure when to shut the computer down in case of a power failure.
Jul 10, 2010 | Tripp Lite AVR550U (AVR550U-EA) UPS System
My APC BE500U keeps resetting
It certainly indictes a problem with the APC unit a replacement bettry may or may not solve the problem. Do you really need one as you have an anti surge protector?
Sep 18, 2009 | APC 500VA BE500U Back-UPS ES...
UPS Does not Store Power
Ok, it sounds like the battery could be dead, easiest is to open it up and check using a multimeter. run it parellel with the battery, reading should be 12VDC, connect the power, if it goes to 13+ VDC then we know the charging circuit is ok. also disconnect the battery and check the voltage on it.
Jun 08, 2009 | Computers & Internet
Newpoint battery backup
check whether the batterries are ok, if  yes check whether the system is charging.
Aug 19, 2008 | Newpoint (200897) (DHN200897) UPS System
XBox 360 power problem
The power brick has most likely died.
Dec 14, 2007 | Microsoft Xbox 360 Console
Energizer ER-HM650 UPS System Logo
359 people viewed this question
Top Energizer Computers & Internet Experts
Tom Chichester
Michel Laprise Sr
Are you an Energizer Computer and Internet Expert? Answer questions, earn points and help others
