Question about Coffee Makers & Espresso Machines
Wiring diafram for Gaggia cubika
I have tryed to get the above but I'm getting no were fast.
I'm an electronics egineer now retired, and I dont see the necesity for paying over E100 inh orther to change the 3 SWTs in the above. Unfortunally, my wife through away the diagram that I made when the SWTs were removed. It took over 2 months to get the 3 swts and the shop that sold me the above sayed that there was no diagrams fo the coffee maker (not very hepful.
thanks if you can help.
jose poveda
josepoveda@rtv.ie
Posted on Aug 20, 2008
  • 515 Answers
What kind of Gaggia do you have?
Posted on Jul 10, 2008
Airless does not have sucktion
diafram is stuck ( if gun is not new replace diafram on head )novice painters are known to not clean airless guns as well as they should and the diaframs all ways stick .....some times you can loosten it by removing the pick-up hose and inserting a blunt object inthe hole to loosen it ( dont push real hard or you will puncture diafram}
Jan 22, 2011 | Campbell Hausfeld Airless Spray Guns &...
I have a gaggia cubika 74511, its new but when i put it on for the first time it will not release water from the coffee dispenser.. I have tried it with the coffee filter and without... No water is being...
I had the same problem but it was not a new machine (about 1 year old). I found the solution by replacing the valve inside the group head. It cost a matter of a few pounds and very easy to fit. In the middle of the spreader shower plate there is a screw. Undo this and take off the shower plate and you will find a threaded bolt that has the thread that holds the screw you just took out. Carefully undo the bolt and the valve drops out. This is the part that I replaced. Replace with the new valve and re-fit the shower plate. Be careful not to overtighten the valve as it can snap. It worked for mine and has worked well ever since. It might be worth taking the current valve out and wash it then put it back before ordering a new one. It could just be blocked.
Dec 27, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
I don't have an instruction book with my Gaggia Cubika and I can't find one online. Help? Elaine
http://www.coffeeitalia.co.uk//prodimages/manual/gaggia/24_cubika.pdf
There you are..
enjoy
Feb 06, 2010 | Gaggia Classic Espresso Machine
Retrive check egine codes 1994 subaru legesy
under the drivers dash are 2 loose black plugs, and 2 loose green plugs, put the black ones together and switch on ignition, dont start it, ecl will flash, slow flashes are 10's and fast ones are 1's. codes can be found on bba-reman.com
Jan 03, 2010 | 1994 Subaru Legacy Outdoor
There is no steam coming out of the spout....CUBIKA GAGGIA...and it steams from the main body of the machine. please help!! Thanks
Check the end of the wand that might be blocked, use a paperclip to clear. If that does not work then the valve needs to be replaced.
Oct 27, 2009 | Gaggia Classic Espresso Machine
1999 gmc jimmy. The heater control is stuck on HOT.
if the knob wont move replace it junk yard may have used part but if it moves and hot air keeps blowing out u may need a servo that opens and closes heater box door under dash i dont think that trucks system works off vacuum but if it does it probably electronic related problem inquire junk/salvage yard about knob and servo for heater box door and problem it may be common and u may get info if he,s a nice guy
Mar 28, 2009 | 1999 GMC Jimmy
Fast idle
hi how are you. your auto choke is bad will need to replace.depending on wich one you have it may only be the vacume choke diafram ( high idle cut off). or it is the electric choke
Feb 13, 2009 | 1988 Chevrolet Caprice
Gaggia cubika, weak coffee.
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Nov 08, 2008 | Gevalia 35411 / 50433 Coffee Maker
Coffee Makers & Espresso Machines Logo
394 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
