Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
Help Our Dyson does not pull itself or self-propel, and you can't push it forward. ANy suggestions?
  • 65 Answers
Dyson vacuums are not self propelled. and if you cannot push it on your carpet then the pile of your carpe is more than what the vacuum can handle.
Posted on Nov 30, 2008
The power that pulls my Dyson vacuum is not working
I don't know of any Dyson models that are self-propelled. What is your model number?
Sep 01, 2017 | Dyson Vacuums
Self propelled clicking noise
check the cable that connects from the handle to the power drive. you might have broken a fastener between the two.
Dec 26, 2012 | Vacuums
I have the Hoover, self propelled vacuum. I have only used the self propel function a few times, but our babysitter used the feature and now the vacuum only works on the highest carpet setting. The middle...
Move the carpet height control switch to a higher position if the vacuum is difficult to push. If the setting is too low for the carpet being cleaned, the brushes press against the floor preventing the vacuum from moving easily.Set to a medium-high height setting then check.Slide the "Self-Propel" button to the "ON" position if the cleaner does not self-propel. -----------
The self-propel feature operates only when the cleaner switch and the self propel button are both ON. ---------- Try this settings and check.This should help.Thanks.Helpmech.
Jun 24, 2011 | Hoover Self-Propelled WindTunnel Bagless...
Hoover wind tunnel won't self propel
There are really two reasons why the self-propelled wouldn't work. It could either be the belts on the vacuum cleaner are stretched or broken. The belts on this model control both the self-propelled transmission, as well as the brush roller. Here's a video that shows you how to inspect the roller brush and belts to make sure that they are installed properly and working. Try this repair first, as this is the easier one to fix.
The other problem if the belts are installed properly that would cause the self-propelled wouldn't work would be the self-propelled actuator arm. There is a cable that starts at the handle of the vacuum, and runs all the way down to the floor head of the vacuum that controls the transmission. As you pull backwards on the handle of the vacuum, the cable pulls this actuator arm backwards, which then turns the wheels backwards, and when you push forward it turns the wheels forward.
The problem with the way it's designed however, is that if you pick up the vacuum cleaner by the handle of the machine rather then using the carrying handle on the back of the vacuum, it causes too much tension on the actuator arm, and will cause the cable to rip right out of the arm.
This is a VERY common problem on this model. To check and see if this part is broken on your vacuum, step on the handle release pedal so that the handle is in the vacuuming position, push the pedal a second time so the machine lays flat on the floor.
Now if you look right behind the height adjustment switch, and the rug / floor switch where the floor part meets the upright part, you should see a cable that connects into the actuator arm. Pull up and down on the handle and look for movement. Is the cable loose with only a nut attached to it, or is it resting in the actuator arm?
Here's a very helpful link that shows you exactly how to replace the actuator arm:
How to Replace the Actuator Arm on Hoover Self-Propelled Windtunnel
If this didn't help you, and the problem is still happening, please just use the add a comment form here on Fixya and let me know that you're still having problems. I'd be honored to go through and do some more advanced diagnosing with you.
I hope this we helpful to you. If you did find this helpful, please be so kind and leave feedback for me. This is why repair professionals like myself continue to come back and give free repair advice, to get the recognition of a job well done.
Thanks so much,
Chris Jones
GoVacuum.com
Apr 17, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
My Dyson Absolute has started making a loud noise and the has gotten progressively more difficult to push. I'm guessing the self-propel has stopped working. Is there a quick fix?
Hi its Darran at Dyson.
Try making sure the brush bar is turning when in the vacuuming position. It is possible that the brush bar is obstructed which can cause your machine to make this noise.
Check out our online help at www.dyson.co.uk/support.
Kind regards
Darran
Dyson Customer Service.
Apr 13, 2010 | Dyson DCO3 Absolute Bagless Upright...
When pushing foreward the vacuum is hard to push and if pushed on to hard it will turn over on itself.
Check the brush. That could be the problem. Check the belt also. Your brush roller may need to be lubed or even replaced.
Sep 04, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Doesn't propel forward anymore
if not the height setting, then
there is an obstruction or the brush is getting worn out.
Aug 04, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
My dyson vacumn is hard to push on carpeting. How do i fix it?
This happens when the bristles in the brush roll get worn down too short. Put in a new brush roll and the machine will pull itself over the carpet, so you hardly have to push at all.
May 19, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
192 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
