Question about Copystar CS-1620 Copier
WHAT DOES J00 CODE MEAN
MY MACHINE IS FLASHING CODE J00. CANNOT DECIDE WHAT THIS MEANS.
  • marci glynn Jul 10, 2008
    copier is a copystar cs1620
  • 523 Answers
Jam 0 means there is one of your switches not working good, it shows that there is jamming but there is no paper, so u have to check which switch is not in right place and fix it.
Posted on Jun 23, 2009
Km2035 error J00 kyocera mita
J00 is an unidentified jam. Means that a paper jammed in the machine and the user switched the machine off and then on again. So the machine lost the ability to inform the user where the jam is. As a result the user has to find out where the jammed paper or piece of paper is.
Jul 16, 2014 | Kyocera Mita Drum Cleaning Blade Km 1620...
Flashing lights.
The Flashing lights indicate several different things. 1 flashing red light means its time to charge your unit. if it is still flashing after charging then you will more than likely need to change the battery. A flashing red and green light means that the unit is overheating which could happen if the filters need to be washed, or that there is a blockage or if your machine has been left in direct sunlight. Allow 1 hour for machine to cool down. 3 flashing lights indicated that the pre-filter has been put on incorrectly. I hope this helps. If you do decide to wash your filter dont use any type of soap it is not needed and allow fiter to dry for atleast 24 hours. putting a wet or damp filter in will damage your machine.
Sep 18, 2011 | Dyson DC16 Root 6 Bagless Handheld...
Copystar CS1810 shows error code J00. How do I fix this?
J00 means that the machine did not pick. remove the cassette and the put back and press start again
Feb 15, 2011 | Copystar CS-1810 Copier
Display is showing J00, what is meaning??
J00: means the paper is jammed in the paper pickup step, remove the cassette and pull the paper softly. and reinstall the cassette again. the message will be cleared.
Dec 25, 2010 | Copystar CS-1510 Copier
J00 Error Code
Means that it never fed the paper from the cassette.Sugest that you ensure that the paperr is loaded correctly and that the cassette is correctly adjusted.May need the feed rollers cleaned.
Nov 21, 2010 | Kyocera KM-1510 Copier
How do I fix error code j00 flashing?
J00 is flashing on my Kyocera KM-1500 copier, i checked but can't see any paper jam
Sep 26, 2010 | Kyocera Copystar CS-1620 Black and White...
What does it mean 2 and f flashing on my copier
An F2 code means you've either got the incorrect toner cartridge inserted into the machine or toner cartridge is faulty (there's a chip on the toner cartridge that identifies it to the copier). Please make sure what you've loaded is AR-016TD.
Sep 02, 2009 | Sharp Office Equipment & Supplies
Error code j00 flashing
Open the drawer and left cover and check for any misfed paper. there is probably a small piece of paper jammed in a sensor actuator.
Jun 06, 2009 | Kyocera Copystar CS-1620 Black and White...
Error code J00
Code J00 is paper tractions error, either one of the traction wheel or one of the sensor is stuck or defective, often you need to take apart the printer to fix this.
Jan 07, 2009 | Kyocera KM-1510 Copier
Copystar CS-1620 Copier Logo
710 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Tammie Duggan
Tammie Duggan
Timothy Van Der...
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
