Reset Airlive WH-5400CPE
I need to reset an airlive WH-5400CPE because i don't remember ip address on the lan. I have also open it but I didn't found any botton. Please help me. Thank you.
Luca
  • uedrav Jul 11, 2008
    I don't find the reset button, where is it. The model is Airlive WH-5400CPE. Many thanks. Luca
  • rtsv Nov 20, 2009
    i foreget my password now i want to reset my password
I had the same problem and got the resettor software,it still did not reset the cpe, i took matters into my own hands and shorted the sw1 jumper on the board for about 30 secs.
There 5 small silver strips, 3 are right next to each other ,the other 2 are apart and also next to each other. Short the 2 that lie side by side for about 30 secs and your cpe is reset to factory default.Reset Airlive WH-5400CPE - 0747e01.jpg
Posted on Jul 01, 2010
  • 1 more comment
  • beno_007 Apr 05, 2011
    thank you very much . it was helpful
    Can you help me to configure this wireless adaptor ,,because i tried to do this but it was difucult,,i am not very good at computer using ,,
  • controlesdes Aug 31, 2011
    Buen Dia , saludos cordiales , me puedes enviar el software resettor a mi correo, tengo el mismo problema olvide la contraseña del equipo y no consigo resetearlo desde ya muchas gracias (controlesdeseguridad@gmail.com)
Well, for you to reset that product you will need a software called Resetor. this you can get from your Local Major Agent/Distributor. that has been the only way ever. i happen to know this because i am a Destributor in Nigera.
Moses London
2348060725397
Posted on Dec 16, 2009
  • 1 more comment
  • mw_royal5
    mw_royal5 Dec 16, 2009
    you cant reset this product even when logged on to it by telnet or web browser. you can only reboot, and do any other thing in it. but to reset to like Factory default, you will have to use the software cd that came with it and install what is called AP locator. this locator can even detect the device without changing your computers IP to its range(just in case the IP Address has been changed from default). select the devise name you want to reset from the window and click on factory default. but it will ask you for password.
    what if in a case where you lost the password? then you will have to use the first solution i provided up there.
    Moses
  • chackojsp Dec 10, 2010
    i reset ma dlink .. that y i need ur help.. if u can plz send the resetor.. thank u
    send software resetor plz , my email is controlesdeseguridad@gmail.com see you..!!
  • 13,433 Answers
Hold down the reset button for 30seconds about.
Posted on Jul 10, 2008
  • Ekse Jul 11, 2008
    As this is a outdoor unit I don't think there is one.
    The default is 192.168.1.20
    AP Configuration Using Web User Interface
    Before Setup...
    ™ Verify the IP address setting
    You need to configure your PC’s network settings to obtain an IP address.
    Computer use IP addresses to communicate with each other across a network,
    such as the Internet.
    1. From the taskbar, click the Start button, select Settings > Control
    Panel. From there, double-click the Network connections icon.
    2. Right click the Local Area Connection icon Properties; select the
    TCP/IP line for the applicable Ethernet adapter. Then, click the
    Properties button.
    3. Click the IP Address tab page, select USE the following IP
    address, type 192.168.1.123 ( but, 192.168.1.20 for the device
    use) in the IP Address field and 255.255.255.0 in the Subnet
    Mask field, then click OK button.
    Start Setup by Browser...
    1. After getting the correct connection, start the web browser (make
    sure you disable the proxy) and type 192.168.1.20 (outdoor unit
    ip Address) in the Address field. Press Enter.
    2. Enter the factory default User name and Password fields:
    User Name: Admin
    Password: (leave blank)
    3. You will enter the Utility homepage.
    read more in the user manual
    http://www.airlive.com/products/WH-5400C...
  • Ekse Jul 11, 2008
    you can reset the device in the web setup / control panel / user interface.
I have WH_5400CPE-ESD this cpe using for wireless clint mode
i have router and switch when i put the direc router the CPE working
But when i put the on switch i can type websit or net conect
why its not working with switch?
How can fix it the problem?
please help me
Mail-nasar_vu@yahoo.com
Posted on Jul 06, 2010
I have its salotion please cal me 03225108812
shahid_aziz_77@yahoo.com
Posted on Apr 22, 2012
I 6 air live devices located at head office and 3 on each branch located not more than 1km from the headoffice.
everthing was working find on friday now all the antenna's show DOWN on the status.
havent been moved or anything. THey use a RC Injector for poweer.
Posted on Sep 13, 2010
Hi people I have an airlive radio the power and wlan led are working whith the indicator of the wlan blinking but the Lan indicator light is off i have no wired connection to my computer.
The failure lies on the LAN side. You need to check back towards the server, somewhere there is a disconnection.
Does it supply Power Over Ethernet?
The radio only provides access to the server/router over the LAN.
If it cannot log on to the LAN it will not work.
Feb 22, 2015 | Computers & Internet
How to reset Barracuda 330 link balancer?
The Barracuda Link Balancer is assigned a default LAN IP address of 192.168.200.200. You can change this IP address in one of three ways:
  • In the web interface, go to the BASIC > IP Configuration page.
  • Connect a VGA monitor and a keyboard to the back of the Barracuda Link Balancer. Use the serial console. (username admin, password admin)
  • Press the RESET button on the front panel.
Pressing RESET for five seconds sets the LAN IP address to 192.168.200.200. Pressing RESET for eight seconds changes the LAN IP address to 192.168.1.200. Pressing the button for 12 seconds changes the LAN IP address to 10.1.1.200. You will notice the three LEDs on the front panel flash at the same time intervals.
Mar 10, 2014 | Barracuda Link Balancer 330 with 1-Year...
I have a asus wl-600g. i sometimes do a power off, and power on again. two days ago, i did a power off, and i kept it disconnected, since the morning until the afternoon. When i connected it again a few...
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Sep 07, 2011 | ASUS WL-600g Wireless Router
How do i reset my password on my modem? I haven't used it for about a year and a half and i can't remember the password... please help, it is a Belkin G Wireless Router
Thanks for the info.
That's quite a problem huh!
There is no such things you can change your password in your modem if you didn't remember it. But i do have one solution.
First, you must have to reset the modem to its default value. the default password there is "admin" without a quote. That, if your willing to reset your modem.
If you want to reset, then you must find the small button at the back of your modem, just press it for 10 seconds. But if you dont remember the IP address, then try this default Ip address: 192.168.1.1 192.168.0.1 192.168.1.0
Access your modem using this Ip address.
hope it helps.
Thanks
Jul 15, 2011 | Computers & Internet
I have a linksys router and my IP address is 192.168.1.1 how can I locate my passowrd/WEP?
The Linksys configuration URL is http://192.168.1.1 and if you cannot Login or remember the password then you can reset the router back to the factory defaults by -
Power up the Linksys and pressing and holding the pinhole reset button at the back of the Linksys for 30 secs. The router will restart.
Username Login = admin
Password = admin
You can now change the admin password and configure the wireless settings ie SSID, WPA or WPA2 encryption etc.
Don't forget to configure the wireless card in your computer with the router's wireless dettings so the computer can connect to the Linksys.
Apr 04, 2010 | Linksys Wireless-G Broadband Router
My G Mimo Plus adapter won't pull and IP address. Any suggestions?
Is there a RESET button on the back of the router, if so power it up and press the RESET button until all the LEDs flash and reconfigure the router.
Try a different LAN cable, the other could be faulty
Install the latest LAN and wireless card drivers (this problem sometimes occurs when you install a new router).
Check the LAN and wireless cards are functioning correctly in Device Manager.
Open the DOS cmd window.
Test the NIC - loopback test address - ping 192.0.0.1
Ping the router's IP configuration address
Type ipconfig to see what IP address you get (if any)
Type inconfig /renew all - this will (should) get a new IP address from the router's DHCP
Let me know how things work out.
Dec 24, 2009 | Belkin Wireless-G Plus MIMO Router with...
AP always restart
I checked it out and it seems you don't have to manually reset/reboot it. You just have to log on to the AP, then choosing REBOOT after you are done, then the changes will that place annd you should be fine.  Note: due to the built-in internal directional patch antenna, repeater mode and WDS option do not apply in WH-5400CPE.
I hope this helps you. Enjoy!
http://69.64.87.53/airlive_fileserver/uploads/English/support/SD1218435928270.pdf
Jan 02, 2009 | Computers & Internet
Problem password airlive wh 5400-cpe
There should be a reset button in it. Have a look around, when you find it, press and hold it for 30seconds, after that it should return to default settings.
Mar 25, 2008 | Computers & Internet
How to reset back to factory default Airlive WH-5400 CPE
There should be a reset button somewhere in the access point.
Can you tell me your brand and model so i can provide more assistance.
Mar 18, 2008 | Computers & Internet
Computers & Internet Logo
5,826 people viewed this question
David Payne
David Payne
